Nodes with centred content don't work [message #1016133] |
Tue, 05 March 2013 08:04 |
serhat gezgin Messages: 243 Registered: January 2013 Location: Izmir |
Dear all
I'm new to Eugenia, GMF , Epsilon. I want to learn eugenia so i found tutorials from official site and perform tutorials step by step. But when i came to "Nodes with centred content" tutorial and "Nodes with images defined at run-time" tutorial I could not perform these, always get error from Ecore2GMF.eol file. And cant find these practise on svn.
dont understand what i must do. Anyone can help me to understand these tutorials.
[Updated on: Tue, 05 March 2013 08:48] Report message to a moderator
Re: Nodes with centred content don't work [message #1016665 is a reply to message #1016133] |
Thu, 07 March 2013 09:51 |
Hi serhat,
We have quite a few example projects over here. Have you had a look at them?
http://dev.eclipse.org/svnroot/modeling/org.eclipse.epsilon/trunk/examples/
I've had a look and it seems we had a few mistakes in the "Nodes with centred content" tutorial, both in the metamodel and the ECore2GMF.eol polishing transformation. I've fixed these issues and created a new set of example projects for it, all starting with "org.eclipse.epsilon.eugenia.examples.centred". These should work fine if you import them all into your workspace.
As for the "Nodes with images defined at run-time" example, it should work fine. Could you tell us what kind of error are you getting?
FUDForum. Page generated in 0.03325 seconds
