Home » Eclipse Projects » Eclipse 4 » Core expressions in compatibility mode
Core expressions in compatibility mode [message #1015990] Mon, 04 March 2013 09:11
As I wrote in my post here http://www.eclipse.org/forums/index.php/t/457783/ a few minutes ago, I'm running a pure e4 RCP as a part of an Eclipse 3 RCP. But not only the theme switching fails, but also evaluating the core expressions.
The RCP contains a Part (wit a TreeViewer) that includes a Popup Menu with core expressions to check the selected item's instance. The core expressions are defined as extensions in the plugin.xml:
<extension
         point="org.eclipse.core.expressions.definitions">
      <definition
            id="de.test.e4.editor.remove">
         <instanceof
               value="de.test.model.Item">
         </instanceof>
      </definition>...
This works for an pure e4 application, but not when I start the RCP as an e3 program. The rest of the Application.e4.xmi is included correctly.
Did somebody experience similar behaviour?
Best regards
Bastian
Previous Topic:e4 and 4.2.2?
Next Topic:Switching Themes in E3 mode
Current Time: Fri Nov 07 16:53:42 EST 2025
Powered by FUDForum. Page generated in 0.02890 seconds
