Home » Modeling » EMF » [CDO] Convert EObject to CDOObject *or* load ecore file as dynamic/native CDO object
[CDO] Convert EObject to CDOObject *or* load ecore file as dynamic/native CDO object [message #1015861] |
Sun, 03 March 2013 22:39 |
Kirsten M. Z. Messages: 132 Registered: July 2010 |
Hi there,
I am trying to figuring out more about the conjunction of regular EMF object (e.g. as loaded from files) and CDO objects. I understand the differences and can already work in both worlds, but I have no idea how these worlds can be connected (conversion/import/export). Either this is not supported well, or I haven't found the correct documentation/tutorial yet. In general, I want to work with dynamic/reflective (DynamicCDOObject) as much as possible (no GenModel).
What I am trying to do right now: loading an ecore file and save the structure within a CDO resource. I am failing, because I want to avoid the legacy mode (no legacy mode). Of course, if I load the Ecore file the regular way, I have EPackages (etc) which are not derived from CDOObject (would require legacy mode then). How is storing in the CDO repository possible then? I tried injecting in order to get DynamicCDOObjects:
EcorePackage.eINSTANCE.setEFactoryInstance(new CDOFactoryImpl(EcorePackage.eINSTANCE));
This does not work (still investigating why). I also tried changing the resource factory, but I think this is the wrong way...
Then I thought about converting, and I also found CDOUtil.getCDOObject(...). However, this method does not work recursivly, right?
Are there some import/export mechanisms?
I have many ideas... each idea means several hours of investigation Could someone help and tell me how this is intended to work? Is there a tutorial/manual about that topic?
Thanks in advance!
[Updated on: Sun, 03 March 2013 22:42] Report message to a moderator
Re: [CDO] Convert EObject to CDOObject *or* oad ecore file as dynamic/native CDO object [message #1015877 is a reply to message #1015861] |
Mon, 04 March 2013 06:20 |
Am 03.03.2013 23:39, schrieb Kirsten M. Z.:
> Hi there,
> (no GenModel).
> EPackages (etc) which are not derived from CDOObject (=> legacy mode). How is storing in the CDO repository possible
> then?
You can store instances of Ecore in CDO but you must use the legacy mode then.
This won't work.
> wrong way...
> recursivly, right?
No, it's a convenience method to get access to the CDOLegacyAdapter of a legacy object.
In CDO 4.2 we introduced a (resource) transfer framework but it also requires instances of Ecore to be wrapped by
CDOLegacyAdapters.
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: [CDO] Convert EObject to CDOObject *or* oad ecore file as dynamic/native CDO object [message #1015960 is a reply to message #1015877] |
Mon, 04 March 2013 12:26 |
So the main message is that there is no easy way to do that (yet)?
However, I am a little bit confused. For example, if I load a XMI file without static (code generated) model, then I get dynamic objects. Together with CDO, I can even get DynamicCDOObject. Is that correct so far?
Why is this strategy not applicable for ecore files themselves. Is it a special case because of the used code which must be aware of the ecore meta model?
Second question is... you talk about "legacy mode" like there is no big deal about it. However, I am wondering about drawbacks next to scalability (cp. http://wiki.eclipse.org/CDO_Legacy_Mode). Havn't read other details about legacy mode yet. Are all basic features supported in legacy mode (offline work, Audits etc.)? "Legacy" sounds like: "deprecated soon", "do not use it", "if you have to use it, you have a wrong application architecture"
Re: [CDO] Convert EObject to CDOObject *or* oad ecore file as dynamic/native CDO object [message #1015970 is a reply to message #1015960] |
Mon, 04 March 2013 12:52 |
Ed Merks Messages: 33142 Registered: July 2009 |
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
<body text="#000000" bgcolor="#FFFFFF">
Kirsten,<br>
<br>
It sounds like what you really want to do is create a subclass of
EFactoryImpl, override this method to create the dynamic CDO
versions, and setEFactory that on your dynamic model.<br>
<blockquote>org.eclipse.emf.ecore.impl.EFactoryImpl.basicCreate(EClass)<br>
</blockquote>
I imagine CDO has such a thing already...<br>
<br>
<br>
<div class="moz-cite-prefix">On 04/03/2013 1:26 PM, Kirsten M. Z.
wrote:<br>
</div>
<blockquote cite="mid:kh23t0$49t$1@xxxxxxxxe.org" type="cite">So
<br>
<br>
<br>
<br>
<br>
to scalability (cp. <a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/CDO_Legacy_Mode">http://wiki.eclipse.org/CDO_Legacy_Mode</a>).
have to use it, you have a wrong application architecture" ;)
<br>
</blockquote>
<br>
</body>
</html>
Ed Merks
Current Time: Fri Apr 26 11:01:59 GMT 2024
Powered by FUDForum. Page generated in 0.03310 seconds
