Home » Archived » BIRT » Wrapped texts when export to ODP
Wrapped texts when export to ODP [message #1015639] Fri, 01 March 2013 13:58 Go to next message
Jan Krakora is currently offline Jan KrakoraFriend
Hi all,
I would like to export my report to a presentation. Since the MS Office 2010 is not supported with PPT emitter,
I'm trying to export to ODP.
But I have problems with text components. The ODP emitter somehow computes text width smaller it should be,
so almost all texts (bigger than 7pt) are wrapped.
index.php/fa/13640/0/
One can adjust the text's width with handles in the opened presentation. Adding minimal amount (something like 1 px) is sufficient
and the text gets inline. It's really annoying.
Do you have any idea how to fix that?
Edit:
Looking at OdpPage class, there is this comment
protected void drawText( String text, float textX, float textY, float baseline,
		float width, float height, TextStyle textStyle ) {
    // width of text is enlarged by 1 point because the text will be
    // automatically wrapped if the width of textbox equals to the width of
    // text exactly.
I don't know what that means, but it exactly happens to me, the text is wrapped.
[Updated on: Fri, 01 March 2013 14:07]
Report message to a moderator
Re: Wrapped texts when export to ODP [message #1015740 is a reply to message #1015639] Sat, 02 March 2013 01:49 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
It looks like a bug. What is your version? If not using 4.2.1, can you try downloading it and seeing if it has the same issue. If it does, please log a bug for it. Are you using fixed layout or auto layout?
Michael
Developer Evangelist, Silanis
Re: Wrapped texts when export to ODP [message #1015911 is a reply to message #1015740] Mon, 04 March 2013 09:04 Go to previous message
I'm using version 3.7.2, but the same happens with 4.2.2. I have filled a bug for this - https://bugs.eclipse.org/bugs/show_bug.cgi?id=402274
By the way, could you please answer me for my question here? If you don't, nobody does.
Previous Topic:Birt don't start
Next Topic:Replace string in various queryText
Current Time: Tue Mar 28 00:49:59 GMT 2023
Powered by FUDForum. Page generated in 0.01907 seconds
