No un-/redeploy possible in Tomcat and WebSphere [message #1015638] |
Fri, 01 March 2013 13:53 |
we have the problem, that it is not possible for us or our clients to
un-/redeploy our app the usual way (tomcat manager or websphere
console). Our environment is Tomcat 7 (windows) or Websphere 8 (suse
linux), RAP 1.5.
When undeploying the app it seems, that not everything get deleted. In
Tomcat some artifakts remain in folder "/work" and on websphere in the
folders "myprofile/temp", "myprofile/wstemp" and "myprofile/config". The
result is, that we and our clients have to undeploy, shutdown the
server, start the sever, and the deploy then deploy the application. So
all webapps of the server are temp. not available while updating the RAP
app.
Some investigation in tomcat shows, that the problem only occurs if
session are open on the app. Expiring the sessions first does not lead
to the problem in tomcat.
It is also reproducible with the rapdemo.war provided in the help, but
this already includes RAP 2.0 and we use 1.5:
http://rap.eclipsesource.com/download/rapdemo.war
I found some rather old links in google regarding a similiar or the same
issue for equinox server side:
http://www.eclipse.org/forums/index.php/mv/msg/158401/500404/#msg_500404
https://bugs.eclipse.org/bugs/show_bug.cgi?id=190279
Does anyone have the same issue or a solution for this?
Markus
Re: No un-/redeploy possible in Tomcat and WebSphere [message #1015991 is a reply to message #1015638] |
Mon, 04 March 2013 14:11 |
I just found the follwing sentence in the RAP developer documentation:
"If you are re-deploying, make sure to delete the work directory of your
servlet engine (e.g.
<tomcat_install>/work/Catalina/localhost/<webapp_name> in Tomcat)."
So is this known already?
Am 01.03.2013 14:53, schrieb Markus Krüger:
> linux), RAP 1.5.
> app.
> Regards,
> Markus
Re: No un-/redeploy possible in Tomcat and WebSphere [message #1016483 is a reply to message #1016348] |
Wed, 06 March 2013 15:54 |
May its a windows issue for tomcat, but this shows some incorrect behavior.
I can reproduce it by doing the following starting from scratch:
1. download tomcat from
http://mirror.lwnetwork.org.uk/APACHE/tomcat/tomcat-7/v7.0.37/bin/apache-tomcat-7.0.37-windows-x86.zip
2. unzip into d:
3. configure tomcat-users.xml with <user username="admin"
password="admin" roles="manager-gui"/>
4. start with startup.bat
5. deploy rapdemo via http://localhost:8080/manager/html
6. open http://localhost:8080/rapdemo/examples with two browsers
7. refresh http://localhost:8080/manager/html
8. see two sesseions active
9. undeploy without expirering sessions
the following plugins now still exist in
D:\apache-tomcat-7.0.37\work\Catalina\localhost\rapdemo\eclipse\plugins:
- org.eclipse.rap.rwt_2.0.0.20130205-1612.jar
- org.eclipse.rap.examples_2.0.0.20130124-1720.jar
and the following errors occur
06.03.2013 16:49:49 org.apache.catalina.session.StandardManager stopInternal
SCHWERWIEGEND: Exception unloading sessions to persistent storage
java.lang.IllegalStateException: Resources directory not configured
at
org.eclipse.rap.rwt.internal.resources.ResourceDirectory.getDirectory(ResourceDirectory.java:48)
at
org.eclipse.rap.rwt.internal.resources.ResourceManagerImpl.getDiskLocation(ResourceManagerImpl.java:176)
at
org.eclipse.rap.rwt.internal.resources.ResourceManagerImpl.getRegisteredContent(ResourceManagerImpl.java:114)
at
org.eclipse.swt.graphics.ImageSerializer.getImageBytes(ImageSerializer.java:79)
at
org.eclipse.swt.graphics.ImageSerializer.writeObject(ImageSerializer.java:68)
at org.eclipse.swt.graphics.Image.writeObject(Image.java:436)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.io.ObjectStreamClass.invokeWriteObject(ObjectStreamClass.java:945)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1469)
at
java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1400)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1158)
at
java.io.ObjectOutputStream.defaultWriteFields(ObjectOutputStream.java:1518)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1483)
at
at java.io.ObjectOutputStream.writeArray(ObjectOutputStream.java:1346)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1154)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:330)
at java.util.HashMap.writeObject(HashMap.java:1001)
at
at
at
at
at
at
org.apache.catalina.session.StandardSession.writeObject(StandardSession.java:1671)
at
org.apache.catalina.session.StandardSession.writeObjectData(StandardSession.java:1077)
at
org.apache.catalina.session.StandardManager.doUnload(StandardManager.java:432)
at
org.apache.catalina.session.StandardManager.unload(StandardManager.java:353)
at
org.apache.catalina.session.StandardManager.stopInternal(StandardManager.java:518)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:232)
at
org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5479)
at
org.apache.catalina.manager.ManagerServlet.undeploy(ManagerServlet.java:1359)
at
org.apache.catalina.manager.HTMLManagerServlet.undeploy(HTMLManagerServlet.java:674)
at
org.apache.catalina.manager.HTMLManagerServlet.doPost(HTMLManagerServlet.java:215)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at
org.apache.catalina.filters.CsrfPreventionFilter.doFilter(CsrfPreventionFilter.java:213)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at
at
org.apache.catalina.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:581)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:936)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1004)
at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at
org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1852)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
06.03.2013 16:49:50 org.apache.catalina.startup.HostConfig
deleteRedeployResources
INFO: Undeploying context [/rapdemo]
06.03.2013 16:49:50 org.apache.catalina.startup.ExpandWar deleteDir
SCHWERWIEGEND:
[D:\apache-tomcat-7.0.37\work\Catalina\localhost\rapdemo\eclipse\plugins] could
not be completely deleted. The presence of the remaining files may cause
problems
SCHWERWIEGEND:
[D:\apache-tomcat-7.0.37\work\Catalina\localhost\rapdemo\eclipse] could
problems
SCHWERWIEGEND: [D:\apache-tomcat-7.0.37\work\Catalina\localhost\rapdemo]
could not be completely deleted. The presence of the remaining files may
cause problems
cause problems
Re: No un-/redeploy possible in Tomcat and WebSphere [message #1016713 is a reply to message #1016483] |
Thu, 07 March 2013 12:58 |
Just tested the same steps in a tomcat in linux.
The directory completly gets deleted here.
So for Tomcat it seems to be an issue only on windows. But For WebSphere
we also have the same Problem in Linux.
Am 06.03.2013 16:54, schrieb Markus Krüger:
> 2. unzip into d:
> stopInternal
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> SCHWERWIEGEND:
> problems
> SCHWERWIEGEND:
> problems
> cause problems
> cause problems
FUDForum. Page generated in 0.04208 seconds
