Home » Eclipse Projects » Plugin Development Environment (PDE) » exportWizards, control the "Export select" window(plugin project, how to control the "Export select" window)
exportWizards, control the "Export select" window [message #1015532] Fri, 01 March 2013 01:59
Today, I created a Plugin Project, what a new export type that will use for.
In the "Export select",after select the export type, I will click the "next" button, then, the new window which I created will open,and I want the "export select" window closed or hidden. Since the "export select" window is not created by myself, i do not know how to close it.
Now thw question is, how to close the "export select" window.
Previous Topic:Problem with Bundle-Localization
Next Topic:Access methods in .so file from eclipse plugin
Current Time: Wed Jul 30 19:15:44 EDT 2025
Powered by FUDForum. Page generated in 0.04561 seconds
