Migration to 3.0 - birt-charts problem [message #1014735] |
Tue, 26 February 2013 11:11 |
k z Messages: 71 Registered: October 2012 |
Member |
Problem with Hudson BIRT Charts Plugin after migration to from Hudson 2.2.0 to Hudson 3.0.0. Indeed /home/tomcat6/.hudson/plugins/birt-charts folder is empty when META-INF is expected in it. Hudson Plugin Manager shows Hudson BIRT Charts Plugin is installed successfully
Feb 26, 2013 10:13:17 AM hudson.model.Hudson$5 onTaskFailed
SEVERE: Failed Inspecting plugin /home/tomcat6/.hudson/plugins/birt-charts.hpi
hudson.util.IOException2: Plugin installation failed. No manifest at /home/tomcat6/.hudson/plugins/birt-charts/META-INF/MANIFEST.MF
at org.hudsonci.inject.internal.plugin.SmoothiePluginStrategy.createPluginWrapper(SmoothiePluginStrategy.java:98)
at org.hudsonci.inject.internal.plugin.DelegatingPluginStrategy.createPluginWrapper(DelegatingPluginStrategy.java:62)
at hudson.PluginManager$1$3$1.run(PluginManager.java:194)
at org.jvnet.hudson.reactor.TaskGraphBuilder$TaskImpl.run(TaskGraphBuilder.java:146)
at org.jvnet.hudson.reactor.Reactor.runTask(Reactor.java:259)
at hudson.model.Hudson$4.runTask(Hudson.java:647)
at org.jvnet.hudson.reactor.Reactor$2.run(Reactor.java:187)
at org.jvnet.hudson.reactor.Reactor$Node.run(Reactor.java:94)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:679)
Caused by: java.io.IOException: Plugin installation failed. No manifest at /home/tomcat6/.hudson/plugins/birt-charts/META-INF/MANIFEST.MF
at hudson.ClassicPluginStrategy.createPluginWrapper(ClassicPluginStrategy.java:109)
at org.hudsonci.inject.internal.plugin.PluginWrapperFactory.create(PluginWrapperFactory.java:86)
at org.hudsonci.inject.internal.plugin.SmoothiePluginStrategy.createPluginWrapper(SmoothiePluginStrategy.java:95)
... 10 more
[Updated on: Wed, 27 February 2013 14:46] Report message to a moderator
FUDForum. Page generated in 0.02510 seconds
