ArrayIndexOutOfBoundsException during XMI serialization with ASCII encoding [message #1014305] |
Mon, 25 February 2013 15:03 |
Silvestre Martins Messages: 84 Registered: July 2009 |
Member |
I have a test using a ChangeRecorder with setRecordingTransientFeatures(false).
If I try to serialize the ChangeDescriptor, using ASCII encoding, I get this error:
java.lang.ArrayIndexOutOfBoundsException: 8192
at org.eclipse.emf.ecore.xmi.impl.StringSegment.writeAscii(StringSegment.java:331)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeAscii(XMLSaveImpl.java:1016)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl.java:255)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLResourceImpl.java:331)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1417)
I'm using the ecore.xmi version 2.8.
I don't think the error is related to the usage of ChangeRecorder at all.
The reason is that in class StringSegment, the BUFFER is set to 8192 bytes. In my scenario I have an array with more than 12000 bytes.
I'm not sure if this is an error that might not have been noticed so far (because it only occurs if the buffer is reached), or if this BUFFER was defined as a limit, and thus this is the intended behavior (I don't think so...).
Can anyone comment please? Should I create a bugzilla for this?
(Unfortunately I can't provide a test case for this, but I assume that it can easily be reproduced by setting a low buffer).
[Updated on: Mon, 25 February 2013 15:06] Report message to a moderator
Re: ArrayIndexOutOfBoundsException when serialization the ChangeDescription from ChangeRecorder [message #1715240 is a reply to message #1014363] |
Fri, 20 November 2015 13:31 |
Noé A Rodríguez González Messages: 4 Registered: July 2013 |
Hi:
I have been experimenting this problem when I try to serialize a ecore model using XML. I Was wondering if the Problem has been reported as a bug in bugzilla, I have been searching on bugzilla but I have not found it yet. Have any one found a solution?
Exception:
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeAscii(XMLSaveImpl.java:1015)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl.java:260)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLResourceImpl.java:206)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1406)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:993)
[Updated on: Fri, 20 November 2015 13:33] Report message to a moderator
FUDForum. Page generated in 0.03090 seconds
