Home » Eclipse Projects » GEF » KeyListeners in ClassDiagram Using Draw2d
| KeyListeners in ClassDiagram Using Draw2d [message #147685] |
Mon, 16 August 2004 02:47  |
Originally posted by: mazharshaikh.iopsis.com
I have created a class diagram using the Reference article mentioned
in GEF. I also added the functionality of Grabhandle and Dragging of
ClassDiagram using connection, decorations and etc using Draw2d API. Its all
working fine.
Now i want to add the Functionality as follows ::
1) When I create a classdiagram through grabhandle and others ... So i
needed a functionality that will allow me to select multiple classdiagram
when pressed Key of "CONTROL" and i can drag all the selected classdiagram.
2) Since all the classdiagrams are visible..so if we go on creating many
classdiagrams using grabhandle.. it shows many classdiagrams with
connections and all others.
So i need a functionality that will allow me to Hide the classDiagram , when
another class diagram is created through grabhandle. And when clicked on
View all it should display all classdiagrams .. otherwise only the created
classdiagram should be visible, rest all hidden.
| Re: KeyListeners in ClassDiagram Using Draw2d [message #148629 is a reply to message #148506] |
Wed, 25 August 2004 11:31   |
There's no example of conversion from Draw2D to GEF, if that's what you
mean. But it shouldn't be too difficult to figure out once you understand
how GEF works and the MVC pattern it employs. You should be able to reuse
chunks of your code (esp. the Model and some, if not most, of the View).
Start out by reading some documentation (Redbook?) and then look at the code
of a simple example: the new shapes example in the repository.
"Mazhar" <mazharshaikh@iopsis.com> wrote in message
news:cgh6o0$tna$1@eclipse.org...
> Hello Sir,
> I have checked the newsgroup, I wanted the perfect example
of
> classdiagram Using GEF ... I have implemented the whole code Using draw2d
> and now i wanted it using GEF ..
> Can u provide me any samples or directions regarding the above question...
> "Guy Slade" <gaslade@yahoo.com> wrote in message
> news:cgfd0b$4k5$1@eclipse.org...
> > I you trawl through this newsgroup you will find numerous postings
> > regarding examples and where to find them..... it will take you 5 mins
> > to do this.
> > Guy
> > Mazhar wrote:
> > > Hello,
> > > I have check this site. I have also checked the examples of
GEF
> but
> > > it is difficult to understand the full code.
> > > Can u provide any ONE example in GEF that will help me to draw the
> > > classdigram and put the required functionality of Dragging, Key Select
> and
> > > Window Select using GEF ??
> > > "Randy Hudson" <none@us.ibm.com> wrote in message
> > > news:cgdhev$edj$1@eclipse.org...
> > >> http://www-106.ibm.com/developerworks/opensource/library/os- gef/
> > >>news:cgc3ot$r52$1@eclipse.org...
> > >>>Hello,
> > >>>Yes, Know i will use GEF for the functionality of Window select and
> > > Hiding
> > >>>of class Digram ..
> > >>>So do i did to re-implement my full code of ClassDiagram using Draw2d
> > > API
> > >>>into GEF .. or any other solution is there ??
> > >>>Can u provide me any sample or direction of how to proceed further ??
| Re: KeyListeners in ClassDiagram Using Draw2d [message #148701 is a reply to message #148629] |
Thu, 26 August 2004 01:58   |
Can u provide any one example on GEF which has the Functinality of
"Dragging' , "Window Select" and "Hiding of Diagrams" .. I have checked the
examples of Logic and Flow but the code is difficult to understand ...
Can u provide any sample or direction ??
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:cgib7h$uog$1@eclipse.org...
code
> > Hello Sir,
> of
draw2d
question...
> > > to do this.
> > > Guy
> > > Mazhar wrote:
> > > > Hello,
> GEF
> > but
Select
> > and
> > > >>>Hello,
> > > > Hiding
> > > >>>of class Digram ..
Draw2d
> > > > API
| Re: KeyListeners in ClassDiagram Using Draw2d [message #148734 is a reply to message #148701] |
Thu, 26 August 2004 11:21   |
Dragging: org.eclipse.gef.examples.shapes example is available on the GEF
CVS repository. To find out how you can connect to the respository, look at
the FAQ on your website. Code to start looking at: getDragTracker() for
EditParts.
I am not sure what you mean by "Window Select."
Hiding of Diagrams: You can hide items on the palette (which is also a GEF
viewer) via the customize dialog. Set a breakpoint in
DefaultEntryPage#handleHiddenSelected and follow the trail to see how it
does this.
news:cgjtqg$769$1@eclipse.org...
> Hello,
the
understand
reuse
> code
> > > Hello Sir,
example
> > of
> draw2d
> question...
mins
> > > > to do this.
> > > > Guy
> > > > Mazhar wrote:
> > > > > Hello,
of
> > GEF
> > > but
> Select
> > > and
> > > > >>>Hello,
and
> > > > > Hiding
> > > > >>>of class Digram ..
> Draw2d
> > > > > API
further
| Re: KeyListeners in ClassDiagram Using Draw2d [message #148894 is a reply to message #148734] |
Mon, 30 August 2004 01:27   |
"Window Select" Functionality means that when we drag the mouse over
some area or the diagram and the figures that are selected ..
Can u provide the example of classDiagram with GEF ??
news:cgkuv6$593$1@eclipse.org...
> EditParts.
> does this.
> > Hello,
> the
you
> understand
> reuse
View).
the
> > code
> > > > Hello Sir,
> example
> > > of
> > draw2d
> > question...
> mins
> > > > > to do this.
> > > > > Guy
> > > > > Mazhar wrote:
> > > > > > Hello,
examples
> of
> > > GEF
> > > > but
the
> > Select
> > > > and
> > > > > >>>Hello,
> and
> > > > > > Hiding
> > > > > >>>of class Digram ..
> > Draw2d
> > > > > > API
> further
| Re: KeyListeners in ClassDiagram Using Draw2d [message #148949 is a reply to message #148894] |
Mon, 30 August 2004 09:54   |
Originally posted by: gaslade.yahoo.com
....... I think we have exhaustively established there there is no
example of classDiagram with GEF!
It's difficult to tell from your incomplete description but it sounds
like you are talking about the marquee selection when you talk about
Window Select. Take another look at the logic example, it uses marquee
selection.... you can point and click somewhere on the free form surface
and then, holding the mouse button down, drag the mouse over an area.
Objects in this area are selected.
Guy
Mazhar wrote:
> Hello,
> at
>>EditParts.
>>does this.
>>>Hello,
>>the
> you
>>understand
>>reuse
> View).
> the
>>>code
>>>>>Hello Sir,
>>example
>>>>of
>>>draw2d
>>>question...
>>mins
>>>>>>to do this.
>>>>>>Guy
>>>>>>Mazhar wrote:
>>>>>>>Hello,
> examples
>>of
>>>>GEF
>>>>>but
> the
>>>Select
>>>>>and
>>>>>>>>>Hello,
>>and
>>>>>>>Hiding
>>>>>>>>>of class Digram ..
>>>Draw2d
>>>>>>>API
>>further
| Re: KeyListeners in ClassDiagram Using Draw2d [message #149515 is a reply to message #149143] |
Tue, 31 August 2004 17:13  |
There is a new simple example available in CVS. See the FAQ for loading
code from CVS.
It will be in a build some time next week.
"Amit Saxena" <amitsaxena@iopsis.com> wrote in message
news:ch1fah$e43$1@eclipse.org...
> hello,
> Yes, exactly that i wanted .. is there any seperate example for the
marquee
> in gef .. but it is difficult to understand the whole code of Logic Any
> seperate exmple is available ??.
> Secondly, i wanted a right click menu on any Object (i.e Figures) and
> contains menus of Hide & View ..
> So that i can Hide and View all Figures or Objects.
> Can u provide any examples or directions ??
> news:cgvml0$q1k$1@eclipse.org...
surface
> > Or, is he talking about changing z-order on select? Who knows, but
asking
> > the right question (the right way) get's you a lot better answers.
> > > Guy
Current Time: Thu Nov 06 10:58:48 EST 2025
Powered by FUDForum. Page generated in 0.09115 seconds
