Multiple input files problem [message #1012818] |
Fri, 22 February 2013 09:24 |
n d Messages: 11 Registered: February 2013 |
Hi all,
I am exporting my xtext project to the command-line/standalone mode. This is achieved without a problem
but now I need to modify it in order to accept multiple files (in order to resolve cross-references
between files). To do this, I have implemented a version of the suggestion in
http://www.eclipse.org/forums/index.php/m/761659/?srch=standalone+multiple+files#msg_761659
in which the model of the secondary files are added for the Resource of the main file.
ResourceSet set = resourceSetProvider.get();
Resource compositeResource = set.getResource(URI.createURI(mainfilename),true);
for (String otherfilename : getOtherSourceFiles()) {
Resource modelFromFile = set.getResource(URI.createURI(otherfilename ), true);
compositeResource.getContents().addAll(modelFromFile.getContents());
List<Issue> list = validator.validate(compositeResource, CheckMode.ALL, CancelIndicator.NullImpl);
The problem is, although the validation works, I cannot get ride of this exception:
0 ERROR LazyLinkingResource - resolution of uriFragment 'xtextLink_::0.0.0.1.0::0::/3' failed.
org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException: index=0, size=0
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:346)
at org.eclipse.xtext.linking.lazy.LazyURIEncoder.resolveShortFragment(LazyURIEncoder.java:109)
at org.eclipse.xtext.linking.lazy.LazyURIEncoder.decode(LazyURIEncoder.java:89)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:166)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:197)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:257)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1473)
at org.xtext.example.mydsl1.myDsl1.impl.TestName2Impl.getName(TestName2Impl.java:73)
at org.xtext.example.mydsl1.myDsl1.impl.TestName2Impl.eGet(TestName2Impl.java:117)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1011)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1003)
at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.hasNext(EContentsEList.java:403)
at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryReferenceIsContained(EObjectValidator.java:782)
at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryDefaultConstraint(EObjectValidator.java:355)
at org.eclipse.emf.ecore.util.EObjectValidator$DynamicEClassValidator.validate(EObjectValidator.java:1420)
at org.eclipse.emf.ecore.util.EObjectValidator.validate(EObjectValidator.java:333)
at org.eclipse.xtext.validation.CompositeEValidator.validate(CompositeEValidator.java:126)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:159)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:137)
at org.eclipse.xtext.validation.CancelableDiagnostician.validate(CancelableDiagnostician.java:36)
at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:178)
at org.eclipse.xtext.validation.CancelableDiagnostician.doValidateContents(CancelableDiagnostician.java:48)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:162)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:120)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:108)
at org.xtext.example.mydsl1.generator.Main.runGenerator(Main.java:80)
at org.xtext.example.mydsl1.generator.Main.main(Main.java:39)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:58)
Does anybody encoutered this and have any suggestion to share?
Thanks a lot,
Nuno
Re: Multiple input files problem [message #1012833 is a reply to message #1012818] |
Fri, 22 February 2013 09:56 |
why do you do the compositeResource.getContents().addAll(modelFromFile.getContents()); at all?
"the model" is the set off all resources aka resourceset.
if you add all required resources to the resourceset you wont get errors like that.
you may call compositeResource.getContents().addAll(modelFromFile.getContents());
to resolve all lazy cross refs after you added all resources to the resourceset
Twitter : @chrdietrich
FUDForum. Page generated in 0.04569 seconds
