Home » Eclipse Projects » Plugin Development Environment (PDE) » Create a command line application
Create a command line application [message #1012409] Thu, 21 February 2013 09:12
Hi all,
I would like to create a command line application based on eclipse PDE. I have already created the application as a plugin and the same is being worked using eclipse. Now, I want it to be created as a command line application. How can I achieve it? Does it work similarly as a normal java application when invoked through command line.
Girish
Previous Topic:Resize Editor window
Next Topic:'Export Plug-ins' encounters a problem
Current Time: Wed Jul 30 19:15:49 EDT 2025
Powered by FUDForum. Page generated in 0.02937 seconds
