Re: Detecting errors in XSD Parsing [message #13719 is a reply to message #13698] |
Tue, 11 March 2003 12:22 |
Hayden,
If you call XSDConcreteComponent.validate on your XSDSchema, it will validate
the whole schema. For this particular case, it will produce a diagnostic
indicating that gfgfd is not permitted.
Hayden Marchant wrote:
> I need to be able to detect bad xsd's during parsing. For example, if
> there is an XSD with a snippet like this:
> <xsd:complexType name="stim">
> <xsd:sequence>
> <xsd:gfgfd name="This" type="xsd:string"/>
> <xsd:element name="that" type="xsd:string"/>
> </xsd:sequence>
> </xsd:complexType>
> I would like the parser to notify me somehow that the first thing in the
> sequence is not a legal xsd construct. Instead it continues parsing with
> complex type and says it has just one element. I tried calling
> XSDSchema.getDiagnostics() but got an empty list. Does anyone know under
> what conditions getDiagnostics returns errors?
> Obviously there are a lot more things that can go wrong with parsing - can
> anyone point me in the right direction?
> Hayden Marchant
Re: Detecting errors in XSD Parsing [message #566222 is a reply to message #13698] |
Ed Merks Messages: 33141 Registered: July 2009 |
Hayden,
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> Hayden Marchant
Ed Merks
FUDForum. Page generated in 0.03470 seconds
