[CDO] setting signal Timeout causes timeout exception. [message #1010982] |
Mon, 18 February 2013 10:54  |
We try to increase the signal timeout, we suspect our application gets a
signal timeout, during high memory load and subsequent Garbage
Collection. We can set the signal timeout on the server. This works.
On a client however, when setting the timeout we get an exception which
seems to occurs after the timeout period. (So if we set it to 60L *
1000L ) the exception occurs after 1 minute, after opening a Session
with the created SessionConfiguratiom. Id like to reproduce this on the
CDO testbed. Is there already a Test case, I can expand upon?
Thank you,
Christophe
[ERROR] java.util.concurrent.TimeoutException
org.eclipse.net4j.util.WrappedException:
at org.eclipse.net4j.util.WrappedException.wrap(WrappedException.java:54)
org.eclipse.net4j.signal.SignalProtocol.sendSetTimeout(SignalProtocol.java:507)
org.eclipse.net4j.signal.SignalProtocol.doAfterActivate(SignalProtocol.java:265)
org.eclipse.net4j.util.lifecycle.Lifecycle.deferredActivate(Lifecycle.java:248)
org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:80)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:162)
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:114)
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:104)
org.eclipse.spi.net4j.ChannelMultiplexer.initChannel(ChannelMultiplexer.java:229)
at org.eclipse.spi.net4j.Connector.initChannel(Connector.java:332)
org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:145)
org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:1)
at org.eclipse.net4j.signal.SignalProtocol.open(SignalProtocol.java:150)
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.createProtocol(CDONet4jSessionImpl.java:198)
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.openSession(CDONet4jSessionImpl.java:223)
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.doActivate(CDONet4jSessionImpl.java:126)
org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:76)
org.eclipse.net4j.util.lifecycle.ShareableLifecycle.internalActivate(ShareableLifecycle.java:43)
org.eclipse.emf.internal.cdo.session.CDOSessionConfigurationImpl.openSession(CDOSessionConfigurationImpl.java:359)
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionConfigurationImpl.openNet4jSession(CDONet4jSessionConfigurationImpl.java:104)
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionConfigurationImpl.openSession(CDONet4jSessionConfigurationImpl.java:110)
com.netxforge.netxstudio.data.cdo.CDODataProvider.openSession(CDODataProvider.java:207)
com.netxforge.netxstudio.server.ServerCDODataProvider.openSession(ServerCDODataProvider.java:77)
com.netxforge.netxstudio.server.ServerUtils$ServerInitializer.initResources(ServerUtils.java:309)
com.netxforge.netxstudio.server.ServerUtils$ServerInitializer.initialize(ServerUtils.java:305)
com.netxforge.netxstudio.server.ServerUtils$ServerInitializer.access$0(ServerUtils.java:304)
com.netxforge.netxstudio.server.ServerUtils.initializeServer(ServerUtils.java:276)
com.netxforge.netxstudio.server.ServerUtils$ServerElementProcessor$1.notifyLifecycleEvent(ServerUtils.java:352)
org.eclipse.net4j.util.lifecycle.LifecycleEventAdapter.notifyEvent(LifecycleEventAdapter.java:34)
at org.eclipse.net4j.util.event.Notifier.fireEventSafe(Notifier.java:167)
at org.eclipse.net4j.util.event.Notifier.fireEvent(Notifier.java:113)
org.eclipse.net4j.util.lifecycle.Lifecycle.deferredActivate(Lifecycle.java:261)
org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:213)
org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:116)
org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:63)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
at java.lang.Thread.run(Thread.java:722)
Caused by: java.util.concurrent.TimeoutException
org.eclipse.net4j.util.io.IOTimeoutException.createTimeoutException(IOTimeoutException.java:46)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:257)
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:431)
org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
org.eclipse.net4j.signal.SignalProtocol.sendSetTimeout(SignalProtocol.java:503)
... 43 more
Caused by: org.eclipse.net4j.util.io.IOTimeoutException
org.eclipse.net4j.buffer.BufferInputStream.computeTimeout(BufferInputStream.java:216)
org.eclipse.net4j.buffer.BufferInputStream.ensureBuffer(BufferInputStream.java:189)
org.eclipse.net4j.buffer.BufferInputStream.read(BufferInputStream.java:116)
at java.io.DataInputStream.readBoolean(DataInputStream.java:242)
org.eclipse.net4j.signal.SetTimeoutRequest.confirming(SetTimeoutRequest.java:48)
org.eclipse.net4j.signal.SetTimeoutRequest.confirming(SetTimeoutRequest.java:1)
org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
... 47 more
!ENTRY org.eclipse.net4j.util 4 0 2013-02-18 16:49:19.234
!MESSAGE java.util.concurrent.TimeoutException
!STACK 0
... 43 more
Re: [CDO] setting signal Timeout causes timeout exception. [message #1012761 is a reply to message #1010982] |
Fri, 22 February 2013 02:39  |
Am 18.02.2013 16:54, schrieb Christophe Bouhier:
> Hello,
> We try to increase the signal timeout, we suspect our application gets a signal timeout, during high memory load and
> subsequent Garbage Collection. We can set the signal timeout on the server. This works.
> On a client however, when setting the timeout we get an exception which seems to occurs after the timeout period. (So
> if we set it to 60L * 1000L ) the exception occurs after 1 minute, after opening a Session with the created
> SessionConfiguratiom. Id like to reproduce this on the CDO testbed. Is there already a Test case, I can expand upon?
Please look at these methods that I found with JDT's call hierarchy (Shift+Alt+H):
org.eclipse.net4j.signal.SignalProtocol.setTimeout(long)
org.eclipse.emf.cdo.tests.config.impl.SessionConfig.Net4j.configureSession(CDOSession)
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.createProtocol()
org.eclipse.emf.cdo.tests.SessionTest.testSetProtocolTimeout().new ContainerEventAdapter()
{...}.onAdded(IContainer<ISession>, ISession)
org.eclipse.emf.cdo.internal.workspace.CDOWorkspaceImpl.openLocalSession()
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.setSignalTimeout(long)
org.eclipse.emf.cdo.tests.bugzilla.Bugzilla_241464_Test.testBugzilla_241464()
org.eclipse.emf.cdo.tests.bugzilla.Bugzilla_246442_Test.testBugzilla_246442()
org.eclipse.emf.cdo.tests.CompareTest.testFromEmptyBranches()
org.eclipse.emf.cdo.tests.SessionTest.testProtocolTimeoutChangedEvent()
org.eclipse.emf.cdo.tests.bugzilla.Bugzilla_258933_Test.testWithValue(String, Object, boolean)
org.eclipse.net4j.tests.SignalStreamWrappingTest.testXORStreamWrapping()
org.eclipse.net4j.tests.SignalStreamWrappingTest.testXORStreamWrappingWithMultipleSignals()
Cheers
/Eike
http://www.esc-net.de
> Thank you,
> Christophe
> org.eclipse.net4j.util.WrappedException: java.util.concurrent.TimeoutException
> at org.eclipse.net4j.signal.SignalProtocol.sendSetTimeout(SignalProtocol.java:507)
> at org.eclipse.net4j.signal.SignalProtocol.doAfterActivate(SignalProtocol.java:265)
> at org.eclipse.net4j.util.lifecycle.Lifecycle.deferredActivate(Lifecycle.java:248)
> at org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:80)
> at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:114)
> at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:104)
> at org.eclipse.spi.net4j.ChannelMultiplexer.initChannel(ChannelMultiplexer.java:229)
> at org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:145)
> at org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:1)
> at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.createProtocol(CDONet4jSessionImpl.java:198)
> at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.openSession(CDONet4jSessionImpl.java:223)
> at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.doActivate(CDONet4jSessionImpl.java:126)
> at org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:76)
> at org.eclipse.net4j.util.lifecycle.ShareableLifecycle.internalActivate(ShareableLifecycle.java:43)
> at org.eclipse.emf.internal.cdo.session.CDOSessionConfigurationImpl.openSession(CDOSessionConfigurationImpl.java:359)
> at
> at
> at com.netxforge.netxstudio.data.cdo.CDODataProvider.openSession(CDODataProvider.java:207)
> at com.netxforge.netxstudio.server.ServerCDODataProvider.openSession(ServerCDODataProvider.java:77)
> at com.netxforge.netxstudio.server.ServerUtils$ServerInitializer.initResources(ServerUtils.java:309)
> at com.netxforge.netxstudio.server.ServerUtils$ServerInitializer.initialize(ServerUtils.java:305)
> at com.netxforge.netxstudio.server.ServerUtils$ServerInitializer.access$0(ServerUtils.java:304)
> at com.netxforge.netxstudio.server.ServerUtils.initializeServer(ServerUtils.java:276)
> at com.netxforge.netxstudio.server.ServerUtils$ServerElementProcessor$1.notifyLifecycleEvent(ServerUtils.java:352)
> at org.eclipse.net4j.util.lifecycle.LifecycleEventAdapter.notifyEvent(LifecycleEventAdapter.java:34)
> at org.eclipse.net4j.util.lifecycle.Lifecycle.deferredActivate(Lifecycle.java:261)
> at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:213)
> at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:116)
> at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
> at org.eclipse.net4j.util.io.IOTimeoutException.createTimeoutException(IOTimeoutException.java:46)
> at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:431)
> at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
> at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
> at org.eclipse.net4j.signal.SignalProtocol.sendSetTimeout(SignalProtocol.java:503)
> ... 43 more
> at org.eclipse.net4j.buffer.BufferInputStream.computeTimeout(BufferInputStream.java:216)
> at org.eclipse.net4j.buffer.BufferInputStream.ensureBuffer(BufferInputStream.java:189)
> at org.eclipse.net4j.buffer.BufferInputStream.read(BufferInputStream.java:116)
> at org.eclipse.net4j.signal.SetTimeoutRequest.confirming(SetTimeoutRequest.java:48)
> at org.eclipse.net4j.signal.SetTimeoutRequest.confirming(SetTimeoutRequest.java:1)
> at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
> at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
> ... 47 more
> !STACK 0
> at
> at
> ... 43 more
FUDForum. Page generated in 0.02616 seconds
