Home » Archived » BIRT » HTML Emitter - How to get the axis description of the charts(Read out Information about the chart!)
HTML Emitter - How to get the axis description of the charts [message #1010944] Mon, 18 February 2013 09:24 Go to next message
I'm modifying the HTML emitter and want to know if there is any possibility to get the axis description of bar charts. Better would be information about the dataset.
I want to read out the entire Information about charts.
In this class:
org.eclipse.birt.report.engine.emitter.html.HTMLReportEmitter.java
is a method startImage() which receives an image with some informations about the bars but I also need the information about the axis, about the chart type and so on.
How does the startImage() method works and how the method is called?
[Updated on: Mon, 18 February 2013 09:37] by Moderator
Re: HTML Emitter - How to get the axis description of the charts [message #1011051 is a reply to message #1010944] Mon, 18 February 2013 13:32 Go to previous messageGo to next message
Samet
Try something like:
public void startImage( IImageContent image )
ExecutionContext exeContext = ( (ReportContent) image.getReportContent( ) ).getExecutionContext( );
Object genby = image.getGenerateBy();
if( genby instanceof ExtendedItemDesign){
ExtendedItemDesign mychart = (ExtendedItemDesign) image.getGenerateBy();
long deh = mychart.getHandle().getID();
ReportDesignHandle rdh = image.getReportContent().getDesign().getReportDesign();
ExtendedItemHandle eih = (ExtendedItemHandle) rdh.getElementByID(deh);
try {
Chart cm = (Chart) eih.getReportItem( ).getProperty( "chart.instance" );
System.out.println("test");
} catch (ExtendedElementException e) {
// TODO Auto-generated catch block
e.printStackTrace();
Jason
Re: HTML Emitter - How to get the axis description of the charts [message #1011110 is a reply to message #1011051] Mon, 18 February 2013 16:55 Go to previous messageGo to next message
Hi Jason,
Thank you for replying.
I just copied your code in the method and got following error:
org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
AxisFault
 faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
 faultSubcode:
 faultString: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
 faultActor:
 faultNode:
 faultDetail:
	{http://xml.apache.org/axis/}stackTrace:org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
	at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1115)
	at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:943)
	at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
	at org.eclipse.birt.report.service.actionhandler.BirtRunAndRenderActionHandler.__execute(BirtRunAndRenderActionHandler.java:76)
	at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
	at org.eclipse.birt.report.presentation.aggregation.layout.EngineFragment.doService(EngineFragment.java:318)
	at org.eclipse.birt.report.presentation.aggregation.AbstractBaseFragment.service(AbstractBaseFragment.java:76)
	at org.eclipse.birt.report.servlet.BirtEngineServlet.__doGet(BirtEngineServlet.java:116)
	at org.eclipse.birt.report.servlet.BaseReportEngineServlet.doGet(BaseReportEngineServlet.java:185)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
	at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
	at org.eclipse.birt.report.servlet.BaseReportEngineServlet.service(BaseReportEngineServlet.java:116)
	at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
	at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
	at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
	at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
	at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:384)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
	at org.eclipse.jetty.server.Server.handle(Server.java:350)
	at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)
	at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:890)
	at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:944)
	at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:630)
	at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)
	at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
	at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606)
	at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)
	at java.lang.Thread.run(Thread.java:722)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
	at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2265)
	at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:190)
	at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
	at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:937)
	... 38 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/birt/chart/model/Chart
	at org.eclipse.birt.report.engine.emitter.html.HTMLReportEmitter.startImage(HTMLReportEmitter.java:3033)
	at org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.startImage(CompositeContentEmitter.java:274)
	at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.startContent(ContentEmitterUtil.java:74)
	at org.eclipse.birt.report.engine.layout.html.buffer.DummyPageBuffer.startContent(DummyPageBuffer.java:126)
	at org.eclipse.birt.report.engine.layout.html.HTMLLeafItemLM.start(HTMLLeafItemLM.java:67)
	at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:139)
	at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
	at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
	at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
	at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
	... 40 more
	{http://xml.apache.org/axis/}hostname:SGOEKBAYRAK
	{}:org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
	... 38 more
	... 40 more
	at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
	at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(BirtUtility.java:777)
	at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:94)
Caused by: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
	... 35 more
	... 38 more
	... 40 more
I debugged the Emitter with your code.
In this line :
 Chart cm = (Chart) (eih.getReportItem().getProperty("chart.instance"));
it jumps out of my code and I get the error above.
It's not jumping in the catch block.
When I try this:
System.out.println(eih.getReportItem().toString());
				System.out.println(eih.getReportItem().getProperty("chart.instance"));
I do get a output without an error.
Samet
[Updated on: Tue, 19 February 2013 11:24] by Moderator
Re: HTML Emitter - How to get the axis description of the charts [message #1011534 is a reply to message #1011110] Tue, 19 February 2013 13:39 Go to previous messageGo to next message
You need to import the chart model package in the plugin manifest. Here is what mine looks like (My versions will most likely be different than yours):
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Csv Plug-in
Bundle-SymbolicName: org.eclipse.birt.report.engine.emitter.csv;singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: org.eclipse.birt.report.engine.emitter.csv.CsvPlugin
Bundle-Localization: plugin
Require-Bundle: org.eclipse.birt.report.engine,
com.ibm.icu;bundle-version="4.2.1",
org.eclipse.birt.data;bundle-version="2.6.1"
Eclipse-LazyStart: true
Bundle-Vendor: Eclipse.org
Export-Package: org.eclipse.birt.report.engine.emitter.csv
Import-Package: org.eclipse.birt.chart.model
Jason
Re: HTML Emitter - How to get the axis description of the charts [message #1011905 is a reply to message #1011534] Wed, 20 February 2013 08:17 Go to previous messageGo to next message
Hii Jason,
Perfect, It works now Smile
I just added the "Import package: org.eclipse.birt.chart.model" but I didn't add the Bundle : com.ibm.icu, is that also necessaray? I couldn't add it because it wasn't in the list.
Now I got some Information I need, for example the definition for the legend or the row description for the axis (row['QUANTITY'] and so on).
Now I'm looking for the values which are used to generate the chart.
I just found the dataset name but that is not enough. There are just sample data but I still couldn't find it.
Do you have any Idea how I can find the values of the series and the labels for the axis?
Samo
Re: HTML Emitter - How to get the axis description of the charts [message #1012149 is a reply to message #1011905] Wed, 20 February 2013 20:06 Go to previous messageGo to next message
You could try running the query for the chart as described in the following thread, but that will cause the query to run twice.
http://www.eclipse.org/forums/index.php/mv/msg/244685/737144/
Jason
Re: HTML Emitter - How to get the axis description of the charts [message #1012371 is a reply to message #1012149] Thu, 21 February 2013 07:37 Go to previous messageGo to next message
Nice. That's it. Even though I have to run the query twice it works. I guess I gotta use this or do you know an alternative?
But receive some Information twice, it's like:
1980s Black Hawk Helicopter
5330
5330.0
1980's GM Manhattan Express
5099
5099.0
I couldn't find any additional information about this columns in my report.
Samet
Re: HTML Emitter - How to get the axis description of the charts [message #1013171 is a reply to message #1012371] Fri, 22 February 2013 18:47 Go to previous messageGo to next message
Samet
Did you look at the column bindings for the item. You probably have additional ones there.
Jason
Re: HTML Emitter - How to get the axis description of the charts [message #1014786 is a reply to message #1013171] Tue, 26 February 2013 08:18 Go to previous messageGo to next message
Hi Jason,
yes, I already checked it and there are just these bindings. Isn't it correct?
index.php/fa/13561/0/
If I delete them I don't get a chart anymore.
Samet
  • Attachment: Bindings.png
    (Size: 63.99KB, Downloaded 812 times)
Re: HTML Emitter - How to get the axis description of the charts [message #1015244 is a reply to message #1014786] Wed, 27 February 2013 16:11 Go to previous messageGo to next message
The bindings look ok. Can you print out the column name?
(rsmd.getColumnName(i+1)
Jason
Re: HTML Emitter - How to get the axis description of the charts [message #1015338 is a reply to message #1015244] Thu, 28 February 2013 04:35 Go to previous messageGo to next message
Hi Jason,
this is the print:
18th Century Vintage Horse Carriage
PRODUCTNAME
5992
QUANTITYINSTOCK
5992.0
row[QUANTITYINSTOCK]_Sum
SG
Re: HTML Emitter - How to get the axis description of the charts [message #1016051 is a reply to message #1015338] Mon, 04 March 2013 12:49 Go to previous messageGo to next message
Samet
The last one looks like an aggregation element in the chart. You could just look for the row[... and throw it away.
Jason
Re: HTML Emitter - How to get the axis description of the charts [message #1016761 is a reply to message #1016051] Thu, 07 March 2013 10:45 Go to previous message
Okay, I will do it.
SG
Previous Topic:Layout Table Complex
Next Topic:How to pass my collection to the report?
Current Time: Sat Aug 30 22:16:10 EDT 2025
Powered by FUDForum. Page generated in 0.06071 seconds
