| Re: Show header in all pages [message #147966 is a reply to message #147777] |
Fri, 24 March 2006 14:34  |
I'm trying to solve this issued. I found an attribute named headerRepeat
in the package org.eclipse.birt.report.engine.content.impl.TableContent
and the attribute repeatHeader in the package
org.eclipse.birt.report.engine.ir.TableItemDesign.
Is this anything to do with problem?
Carlos Dias
Carlos Dias wrote:
> Thanks for the answer Brandon, but that doesn't work for me.
> This must be, I hope so, a limitation of the default viewer. I'm going
> to check the code to see if I can found a solution.
> Any tips on this mater are welcome.
> Carlos Dias
> Brandon Shannon wrote:
>> I put them up on the Master Page in that Header section, which makes
>> them appear on every page. The only down-side to that is that you
>> know have to excplicitly size each column so that the headers and the
>> data rows line up nicely (since they are in different tables now).
>> Brandon
>> "Carlos Dias" <cdias@pontoc.pt> wrote in message
>> news:dvr9ko$7hq$1@utils.eclipse.org...
>>> How can I show the header section in all pages?
>>> Thanks,
>>> Carlos Dias
FUDForum. Page generated in 0.03701 seconds
