Re: Import And Scoping [message #1009084 is a reply to message #1009078] |
Thu, 14 February 2013 11:58 |
Alexander Nittka Messages: 1193 Registered: July 2009 |
The comparison with java does not work out!
a) not the file B.java extends the the file A.java, but the class B defined in B.java extends the class A in A.java
b) you don't use an import mechanism in java, but qualified names. The imports are only used to allow short names instead of the fully qualified names.
c) getABC() can be used in C because the scoping walks up the type hierarchy.
a) and b) is exactly what Xtext's qualified name fragment does for you. Resources (model files) export elements under a qualified name, other resources can reference these elements without explicitly having to import the containing files (as needed with the URI import).
c) you'll have to implement yourself using scoping because Xtext does not attach any meaning to a reference defined in the grammar.
Alex
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext@itemis.de
FUDForum. Page generated in 0.03316 seconds
