Home » Archived » BIRT » PDF Page Numbers
PDF Page Numbers [message #1008780] Wed, 13 February 2013 15:55 Go to next message
Hello. I am having an issue with page numbers in BIRT 4.2. I need to have page numbers on my report when I output the report to a pdf. With every method that I have tried, the page number variable appears to increment only when there is a page break that I specified in the report design. When there are multiple pages because a table ended up being bigger than usual, both pages with have the same page number. I first tried putting <viewtime-value-of>pageNumber</viewtime-value-of> in the footer. I have also tried adding onCreate and onRender scripts to the footer to increment a global variable and then put it in the footer, but this has the same problem. Does anyone have a method for getting around this problem?
Re: PDF Page Numbers [message #1008785 is a reply to message #1008780] Wed, 13 February 2013 16:05 Go to previous messageGo to next message
Are you using fixed layout or auto layout (General property for the report)? Standard autotext page number should work fine here.
Jason
Re: PDF Page Numbers [message #1009136 is a reply to message #1008785] Thu, 14 February 2013 09:17 Go to previous messageGo to next message
Hi Jason. I am using fixed layout. I tried autotext, and it does work. Thanks for the help.
Re: PDF Page Numbers [message #1009219 is a reply to message #1009136] Thu, 14 February 2013 12:35 Go to previous message
Can you reproduce the issue with the sample db and post the design?
Jason
BIRT-Exchange
Previous Topic:BIRT report w/ parameter fails when ? placed in SQL where clause
Next Topic:Tribix PPT emitter for BIRT WebViewer v4.2.1
Current Time: Thu Sep 25 12:59:05 EDT 2025
Powered by FUDForum. Page generated in 0.03286 seconds
