Re: Acceleo protected regions [message #1009489 is a reply to message #1008671] |
Fri, 15 February 2013 08:24 |
Alexander,
Protected areas have to be unique within each file. What you are doing here means that you're generating one protected area for each classifier of your model, each with the same id ('Test'). Make sure to generate a distinct (but constant for every generation) identifier for your areas. For example :
--[protected(c.name)]
--TODO:should be implemented
--[/protected]
Please also note that there should be nothing "after" the identifier, on the same line. Make sure you do not have extra whitespaces after the closing bracket (']') of the first line.
Laurent Goubet
Obeo
[Updated on: Fri, 15 February 2013 08:25] Report message to a moderator
FUDForum. Page generated in 0.03776 seconds
