Re: SWT Browser (IE9) F12 Developer Tools [message #1015451 is a reply to message #1008446] |
Thu, 28 February 2013 15:50 |
Grant Gayed Messages: 2150 Registered: July 2009 |
Hi James,
The F12 developer tools are part of IE, not of its embeddable control,
so this won't work in the context of eclipse.
Perhaps Firebug lite could help you here? I believe that it can run in
the context of an IE-based Browser.
Grant
On 2/12/2013 10:01 AM, James Clark wrote:
> I'm currently trying to utilise the SWT Browser to embed a browser in my
> Java application. One of the requirements of this browser is that we can
> add custom javascript into the DOM and then to debug the execution of
> this script.
> Experimenting with the SWT Browser has shown that the DOM interaction
> should be fine, however I'm struggling with providing the means to debug
> the script. Ideally I'd like to use well-established Developer Tools
> such as those with IE9, Chrome or Firebug. I've gone down the XULRunner
> route and it seems giving the browser access to a firebug extension is a
> no go (please correct me if I'm wrong).
> I thought that as a last alternative, we'd be able to use the Developer
> Tools bundled with IE9. However, attempting to bring up the tools in the
> SWT browser control results in nothing happening after pressing F12.
> Registering a KeyListener on the browser shows that when pressing F12,
> no KeyPressed event is received (a KeyReleased event is however). I
> suspect this is not the issue though as none of the shortcuts F-key
> shortcuts do anything apart from F5 causes a refresh and F10 puts focus
> on the menu.
> Anyone provide any help towards getting a Javascript Debugger attached
> to the browser or provide insight into why previous attempts are failing?
> Thanks for any help,
> James
Re: SWT Browser (IE9) F12 Developer Tools [message #1015968 is a reply to message #1012763] |
Mon, 04 March 2013 12:48 |
James Clark Messages: 4 Registered: February 2013 |
Wolfgang Groiss wrote on Fri, 22 February 2013 02:44Hi James,
I see it's been only a few days and there are no replies in this forum. Sadly, I also cannot help but I'm having the same need (use IE9 Developer Tools in an IE embedded via SWT) and was wondering whether you might have found a way to do this yet.
Wolfgang
Hi Wolfgang,
Apologies, I've been on vacation and have only just returned to find your message. I am still currently investigating this however I think things don't look too positive. I'll update this post in the event I do find something.
Konstantin and Grant, thanks for your replies. Unfortunately one of the requirements of what I'm trying to do is that a user will be able to enter some Javascript and then run that script (with the host application injecting in certain objects). I want the user to then be able to debug their script. Using CEF in the C++ world, this was made possible via the user of the Chrome Developer Tools. It's proving tricky in the Java world however!
I'll keep investigating, thanks.
James
FUDForum. Page generated in 0.03242 seconds
