Re: Ecore Change [message #1008474 is a reply to message #1008444] |
Tue, 12 February 2013 16:01 |
Ed Merks Messages: 33218 Registered: July 2009 |
Andrey,
Comments below.
On 12/02/2013 3:13 PM, Andrey Mising name wrote:
> The instances are saved in tables. It is not possible to track as the
> tables are overwritten.
> JAVA API to extract the informations from these tables.
> By changes i mean for example: References are different (was from
> obejct1 to object2 now it is first to object3 and then to object2),
> Parameters changes (was name, label now id, label, description.)
Certainly with EMF you can track all changes made to objects that are
in-memory.
> Thank you,
> Andrey
Ed Merks
FUDForum. Page generated in 0.03485 seconds
