Re: Question about the OSGI console commands: packages& bundle [message #1011889 is a reply to message #1008320] |
Wed, 20 February 2013 12:38 |
Hello Aniruddha!
I'm not responding to your question only want to share my experience
with "packages" command - this command never gave me trustworthy
results. Often it says "No packages export" despite bundle actually
exports a lot of packages.
Maybe it will be worthwhile to file a bug with this inconsistency (in
that case repost bug ID here - I wish to follow up it).
Have a nice day!
Libor Jelinek
http://devblog.virtage.com/libor-jelinek/
On 11.2.2013 23:19, Aniruddha Shevade wrote:
> I am trying to see the packages being used by an eclipse plugin, using
> the eclipse osgi console
> The results given by the following 2 commands do not appear consistent
> a) When I use the "bundle" command for a plugin , I do not see a
> particular package listed as imported to eb specific ( javax.xml.bind )
> b) When I use the "packages" command it shows that this package is
> being used by the plugin mentioned above
> The given plugin does not directly import the package. So why would it
> be listed in the packages command?
> Which command should I use to find out is a particular package is being
> used by a plugin?
> Any help is appreciated
> Regards Ani
FUDForum. Page generated in 0.04101 seconds
