Re: Error while building a grails app [message #1008105 is a reply to message #1007895] |
Sat, 09 February 2013 02:02 |
Winston Prakash Messages: 534 Registered: August 2011 Location: Fremont, CA USA |
Hi nem,
I released grails version 1.7-h-1 and uploaded it to plugin center. You can updated it from your Hudson's update center. I tested the plugin and it seems to work fine in Hudson 3.0.0. Here is a sample output
[workspace] $ /Users/wjprakash/grails/2.1.1/bin/grails test-app --non-interactive --plain-output
|Loading Grails 2.1.1
|Configuring classpath
|Environment set to test
|Installing zip webxml-1.4.1.zip...
|Installed plugin webxml-1.4.1
|Resolving plugin JAR dependencies
|Compiling 2 source files
|Compiling 40 source files
|Compiling 21 source files
|Compiling 1 source files
|Running 6 unit tests...
|Running 6 unit tests... 1 of 6
|Running 6 unit tests... 2 of 6
|Running 6 unit tests... 3 of 6
|Running 6 unit tests... 4 of 6
|Running 6 unit tests... 5 of 6
|Running 6 unit tests... 6 of 6
|Completed 6 unit tests, 0 failed in 6382ms
|Packaging Grails application
|Tests PASSED - view reports in /Users/wjprakash/Hudson/Hudson3-plugins/grails-plugin/work/jobs/grails-test/workspace/target/test-reports
Finished: SUCCESS
Winston Prakash
Eclipse Hudson team
FUDForum. Page generated in 0.03272 seconds
