WritableList casting issues [message #1007435] |
Tue, 05 February 2013 20:41 |
James Teater Messages: 17 Registered: July 2011 |
Junior Member |
I am using a writable list to store data the user selects. I am using a writable list so that when users add or remove data my table viewers update.
This is part of the class that creates the writable list.
public class AplotDataModel {
IObservableList observableList = new WritableList();
private static AplotDataModel instance = null;
// Constructor //
private AplotDataModel() {
}// end Constructor
// SingletonSelectTable getInstance() //
public static AplotDataModel getInstance() {
if (instance == null) {
instance = new AplotDataModel();
return instance;
// add() //
public void add(TCComponentItemRevision tcRevision, TCComponentDataset selectedDataset) {
AplotDatasetData pp = new AplotDatasetData(tcRevision, selectedDataset);
if (!observableList.contains(pp)) {
observableList.add(pp);
// clearTableArray() //
public void clearTableArray() {
observableList.clear();
}// End Class
I am using the class AplotDataset to format the list.
Some of the class
public class AplotDatasetData {
TCComponentItemRevision rev;
TCComponentDataset componentdataset;
String markUp = "no";
// Constructor //
public AplotDatasetData(TCComponentItemRevision tcRevision, TCComponentDataset selectedDataset) {
rev = tcRevision;
componentdataset = selectedDataset;
}// end Constructor
// getDataset() //
public TCComponent getDataset() {
return componentdataset;
// getRev() //
public TCComponent getRev() {
return rev;
// equals() //
public boolean equals(Object o) {
AplotDatasetData p = (AplotDatasetData) o;
if (rev.equals(p.getRev()) && componentdataset.equals(p.getDataset())) {
return true;
else {
return false;
}// end equals()
Everything works as it should to this point.
In a different class I am trying to create a new ArrayList using data in my Writable List.
public void buildPlotArray() {
ArrayList<AplotDataModel.AplotDatasetData> tableData = new ArrayList<AplotDataModel.AplotDatasetData>(AplotDataModel.getInstance().getObservableList());//Getting Writable List
String yesECM = "yes";
String noECM = "no";
for(int i = 0; i < tableData.size(); i++){
TCComponentItemRevision rev = tableData.get(i).rev;
TCComponentDataset dataset = tableData.get(i).componentdataset;
String ecmCheck = tableData.get(i).getMarkupValue();
if(ecmCheck == "both"){
PlotData yfd = new PlotData(rev , dataset, yesECM);
plotData.add(yfd);
PlotData nfd = new PlotData(rev , dataset, noECM);
plotData.add(nfd);
else {
PlotData sfd = new PlotData(rev , dataset, ecmCheck);
plotData.add(sfd);
The code compiles, but I try to run specific operations. I get the following error.
ERROR: 11:31:00,591 - TcLogger$IC_LogListener.logging:? org.eclipse.core.runtime - org.eclipse.ui - 0 - Unhandled event loop exception org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.ClassCastExc eption: org.eclipse.core.databinding.observable.list.WritableList cannot be cast to com.lexmark.aplot.datamodels.AplotDataModel$AplotDatasetData)
etc .....
Caused by: java.lang.ClassCastException: org.eclipse.core.databinding.observable .list.WritableList cannot be cast to com.lexmark.aplot.datamodels.AplotDataModel $AplotDatasetData at com.lexmark.aplot.datamodels.AplotDataModel$AplotDatasetData.equals(A plotDataModel.java:167)
So what I know from the error. It is a casting issue with the Writable List.
The error is occurring in the equal method in AplotDatasetData
AplotDatasetData p = (AplotDatasetData) o; //Right here
return true;
else {
return false;
}// end equals()
I also know that the only place I am trying to cast the list is when I am trying to create the new ArrayList.
So at this point I don't know if I need to:
1. Work on the equals method, trying to get it to work with the writable list?
2. If I need to work on the place where I am trying to create a new ArrayList from the writable list?
3. If there is a better way to define the WritableList, when creating it?
I have to have the equals method, so the users can not put duplicate data in the list. I also have to have the writable list.
This issue is keeping me from be able to go live with my application.
Any help will be greatly appreciated!!
FUDForum. Page generated in 0.02709 seconds
