Home » Modeling » UML2 » Migration from UML2 3.2.0 to 4.0 with Profiles and Stereotypes
Migration from UML2 3.2.0 to 4.0 with Profiles and Stereotypes [message #1007411] Tue, 05 February 2013 13:48 Go to next message
I upgraded to UML 4.0 and have some troubles reading the models when it comes to stereotypes.
The model was saved with UML2 3.2, (ergo XMI 2.1) and included a profile that was applied with the dynamic technique.
Now, when loading the model with UML 4.0, i receive the following exception:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException: Value '250' is not legal. (platform:/resource/example/Test.uml, 65, 132)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.emf.edit.domain.AdapterFactoryEditingDomain.loadResource(AdapterFactoryEditingDomain.java:405)
The line where loading fails is a stereotype, and the value an stored UMLPrimitiveTypes::String
Any idea why this happens?
Now, vice-versa, when I create a new model and save it useing UML 4.0, the values of the stereotypes (again, UMLPrimitiveTypes::String), are stored in a "strange" way:
<graphics:Shape xmi:id="_w4hNkPaXEeG_Gb8QAQ0kdw" x="ACED0005740003313830" y="ACED00057400023535" width="ACED0005740003363133" height="ACED00057400023534" base_Element="_wlI-kPaXEeG_Gb8QAQ0kdw"/>
Is this some sort of reference? If, so, I do not find where they point to.
Is there something I have not seen? I have read the migration guide, and I have tried to update the original profile specification, but it did not seem to change things.
Thanks for any help in advance!
Re: Migration from UML2 3.2.0 to 4.0 with Profiles and Stereotypes [message #1007425 is a reply to message #1007411] Tue, 05 February 2013 14:45 Go to previous messageGo to next message
I cannot comment on the first example that is specific to your models.
The XMI serialization of stereotype applications has always been wierd
in my opinion, using XMI directly to avoid defining a proper object.
Ed Willink
On 05/02/2013 18:48, Fredrik Robertssen wrote:
> exception:
> at
> at
> at
> at
> to.
Re: Migration from UML2 3.2.0 to 4.0 with Profiles and Stereotypes [message #1007680 is a reply to message #1007411] Wed, 06 February 2013 23:48 Go to previous messageGo to next message
Fredrik,
Both the exception and sample XMI seem odd to me. Are you doing this
with a standalone application or from the UML editor in Eclipse? Note
that there were a number of issues with support for legacy profiles in
4.0 which have been fixed in 4.0.x releases...
Kenn
On 13-02-05 1:48 PM, Fredrik Robertssen wrote:
> exception:
> at
> at
> at
> at
Re: Migration from UML2 3.2.0 to 4.0 with Profiles and Stereotypes [message #1008096 is a reply to message #1007680] Fri, 08 February 2013 17:39 Go to previous messageGo to next message
Hi Ken,
this happens in a plugin that loads UML models, within Eclipse. But I have tried to open the *.uml files also in the UML 2 Editor in Eclipse, with basically the same exception:
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value '180' is not legal. (platform:/resource/GUI.uml, 112, 131)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2671)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2725)
	at org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAttribs(SAXXMIHandler.java:79)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2200)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1337)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1475)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1026)
	at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:81)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
	at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:163)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:501)
	at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(AbstractXMLDocumentParser.java:179)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1343)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2756)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:647)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:511)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
	at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
	at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
	at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:253)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1529)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1308)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
	... 8 more
Caused by: java.lang.NullPointerException
	at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1121)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2666)
	... 36 more
Since you mentioned that some legacy issues have been fixed, I have tried with both UML 4.0.1 and especially 4.1.0 M5, with the same behavior. I have also re-applied the profile.
Is there anything else that has been changed from UML 3.2.0 towards 4.0 that could cause this?
The profile is stored in a plugin and contributed by a pathmap, via extension point org.eclipse.emf.ecore.uri_mapping.
Thanks for al feedback,
Fredrik
Re: Migration from UML2 3.2.0 to 4.0 with Profiles and Stereotypes [message #1008100 is a reply to message #1008096] Fri, 08 February 2013 18:04 Go to previous messageGo to next message
Hmm, it's hard to tell what's happening from the stack trace along. If
you can share a representative profile that demonstrates the problem
I'll try to debug it to figure out what's happening...
Kenn
On 13-02-08 5:39 PM, Fredrik Robertssen wrote:
> Hi Ken,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 8 more
> at
> at
> ... 36 more
> Fredrik
Re: Migration from UML2 3.2.0 to 4.0 with Profiles and Stereotypes [message #1053545 is a reply to message #1008100] Mon, 06 May 2013 09:10 Go to previous messageGo to next message
thanks for the hints, that helped to narrow the problem down. It seems to have to do with the primitive type that is used for one of the stereotype values. It should be a string, and the chosen type was like the following:
<eStructuralFeaturesxmi:type="ecore:EAttribute"xmi:id="_geG1w4uAEdytfOWtpACIqw"name="x"ordered="false"lowerBound="1"]]>
          <eTypexmi:type="ecore:EDataType"href="http://www.eclipse.org/uml2/3.0.0/UML#//String"/>
        </eStructuralFeatures]]>
However, when the profile is updated to this one, also UML 4 can import it:
<eStructuralFeaturesxmi:type="ecore:EAttribute"xmi:id="_f-IIgrZDEeKRqIn5WJZUCg"name="x"ordered="false"lowerBound="1"]]>
          <eTypexmi:type="ecore:EDataType"href="http://www.eclipse.org/emf/2002/Ecore#//EString"/>
I guess this has to do with the overhaul of the resources provided with UML 4, as explained here:
http://wiki.eclipse.org/MDT/UML2/UML2_4.0_Migration_Guide#Resources
Is there a "smart" way to fix this? I will try to experiment with updating the type references and profiles.
Thanks again for the help provided!
Fredrik
Re: Migration from UML2 3.2.0 to 4.0 with Profiles and Stereotypes [message #1053602 is a reply to message #1053545] Mon, 06 May 2013 13:06 Go to previous message
http://www.eclipse.org/emf/2002/Ecore#//EString seems like a really bad
idea for a 'UML' model.
Have you tried http://www.eclipse.org/uml2/4.0.0/Types#//String ?
Ed Willink
On 06/05/2013 14:10, Fredrik Robertssen wrote:
> the following:
> import it:
> Fredrik
Previous Topic:How to get default value of Enumeration Literal in UML?
Next Topic:how to migrate uml to new definitions
Current Time: Tue Nov 04 08:39:22 EST 2025
Powered by FUDForum. Page generated in 0.03626 seconds
