Memory leak in TrackableComputaionExt [message #1006373] |
Thu, 31 January 2013 02:20  |
I have a form editor extended from eclipse Form editor. After closing the editor I still see that the editor instance is alive. I saw the following in YourKit memory snapshot
Is there any way how I can dispose this object?
activePart of org.eclipse.ui.internal.expressions.ActivePartExpression
expression of org.eclipse.ui.internal.contexts.ContextService$UpdateExpression
runnable of org.eclipse.e4.core.internal.contexts.TrackableComputationExt
key of java.util.HashMap$Entry
[233] of java.util.HashMap$Entry[256]
table of java.util.HashMap
map of java.util.HashSet
value of java.util.HashMap$Entry
[177] of java.util.HashMap$Entry[256]
m of java.util.Collections$SynchronizedMap
listeners of org.eclipse.e4.core.internal.contexts.EclipseContext
context of org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl
val$part of org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$2
[46] of org.eclipse.swt.widgets.Control[1024]
controlTable of org.eclipse.swt.widgets.Display [JNI Global, Stack Local]
Panneer
FUDForum. Page generated in 0.08373 seconds
