Re: [CDO] id generation client side & raw replication [message #1005961 is a reply to message #1005949] |
Tue, 29 January 2013 12:13 |
Ricky de Klerck Messages: 295 Registered: January 2011 |
Eike Stepper wrote on Tue, 29 January 2013 06:39Am 29.01.2013 12:19, schrieb Ricky de Klerck:
> Eike Stepper wrote on Tue, 29 January 2013 05:50
>> Am 29.01.2013 11:31, schrieb Ricky de Klerck:
>> > If that's true I should use that one I suppose..
>> > We also have a problem when 'raw replication' is set to true. When starting the clone > it keeps making new
>> sessions > with the message 'replication failed, retry in 2 seconds'. > But not in normal replication mode? That's
>> weird. I'd need more details about your > problem to be able to judge.
> In normal replication there are no errors indeed.
> I'm using your master/clone test code. What do you need to judge the problem?
Hard to tell exactly. The exception that causes the log message would be a good start.
> I enabled tracing and this a part of the output:
> CDORepositorySynchronizer [debug.repository] Connected to master.
> CDORepositorySynchronizer [debug.repository] Synchronizing with master...
> CDORepositorySynchronizer [debug.protocol] Writing CDOIDObject of subtype 4 (UUID)
> net4j-Thread-2 [debug.protocol] Reading CDOIDObject of sub type 4 (UUID)
> CDORepositorySynchronizer [debug] Registering http://www.eclipse.org/emf/CDO/Eresource/4.0.0 -->
> org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@6c522a (name: eresource) (nsURI:
> http://www.eclipse.org/emf/CDO/Eresource/4.0.0, nsPrefix: eresource)
> CDORepositorySynchronizer [debug] Registering http://model/1.0 -->
> smartapps.smartstore.emf.model.impl.ModelPackageImpl@15faadb (name: model) (nsURI: http://model/1.0, nsPrefix: model)
Is it possible that you add/commit new packages after the initial replication? Unfortunately that's not supported!
Cheers
/Eike
http://www.esc-net.de
> CDORepositorySynchronizer [debug.repository] Replication attempt failed. Retrying in 2 seconds...
> CDORepositorySynchronizer [debug.repository] Disconnected from master.
Hmm.. I must have done something wrong because I copied your code again and now it works fine. My mistake..
[Updated on: Tue, 29 January 2013 12:14] Report message to a moderator
FUDForum. Page generated in 0.03936 seconds
