Re: Cannot create SWT browser after eclipse exit and restart [message #1016244 is a reply to message #1016096] |
Tue, 05 March 2013 15:48 |
Alexander Mitin Messages: 5 Registered: March 2011 |
Any logs available for Designer tab is not working?
Can you determine which browser render it tries to use when design tab fails?
Running Eclipse using command line:
./eclipse -vmargs -Dorg.eclipse.swt.browser.XULRunnerPath=/usr/lib64/xulrunner-1.9.2.27/
should use xulrunner-1.9.2 as browser renderer eclipse-wide, including Welcome Screen and WBP.
Other two options:
-Dorg.eclipse.swt.browser.UseWebKitGTK=true
-Dorg.eclipse.swt.browser.DefaultType=mozilla
have no effect for WBP.
To use WebKitGTK in WBP you should have libwebkitgtk-1.x.x.so installed in the system and have "Use WebKit if available" WBP preference enabled.
[Updated on: Tue, 05 March 2013 16:00] Report message to a moderator
Re: Cannot create SWT browser after eclipse exit and restart [message #1016292 is a reply to message #1005823] |
Tue, 05 March 2013 21:19 |
Rich Fleck Messages: 8 Registered: July 2009 |
Alexander
Your comment helped me stumble on an odd workaround.
SUSE packages libwebkit as Library for rendering web content, GTK+ Port
ll /usr/lib64/libwebkit*
lrwxrwxrwx 1 root root 23 Jan 18 20:21 /usr/lib64/libwebkit-1.0.so -> libwebkit-1.0.so.2.17.9
lrwxrwxrwx 1 root root 23 Jan 18 20:21 /usr/lib64/libwebkit-1.0.so.2 -> libwebkit-1.0.so.2.17.9
-rwxr-xr-x 1 root root 18678416 Nov 30 20:58 /usr/lib64/libwebkit-1.0.so.2.17.9
I thought creating links for libwebkitgtk-1.0.so would help.
Kind of the reverse of your suggested fix in the google-web-toolkit group.
No Luck
Then I found this bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=359296
Just the act of checking the Web Browser setting prior to trying to
open a Designer Tab works.
If I check the Web Browser setting first it is set to
Uee Internal web browser
and the Designer Tab works
with the command line message
*** nss-shared-helper: Shared database disabled (set NSS_USE_SHARED_DB to enable).
window = 139872075739088
Browser ready.
If I open eclipse and try the Designer Tab I get the SWT error
and checking the Web Browser setting has the
Use external web browser
selected and the
grayed out
with the following appearing in the command line after I eclipse.
/usr/java/latest/bin/java: symbol lookup error: /usr/lib64/gtk-2.0/2.10.0/immodules/im-cedilla.so: undefined symbol: gtk_im_context_simple_get_type
Crazy but it is reproducible.
Thank You for your help and interest.
Rich
[Updated on: Tue, 05 March 2013 21:20] Report message to a moderator
FUDForum. Page generated in 0.04247 seconds
