Home » Modeling » TMF (Xtext) » How to obtain the Eclipse automatically-updated EMF model?
How to obtain the Eclipse automatically-updated EMF model? [message #1005011] |
Thu, 24 January 2013 10:10 |
Marco Naddeo Messages: 62 Registered: November 2012 |
Member |
Hi all.
If I understood well, Eclipse has a component called reconciler which is a background process in my DSL editor responsible for updating the model when the user takes a break from typing; the kinds of things it should update include elements displayed in the outline view, error markers, folding regions, etc.
So, the EMF model representing the source code that the programmer modifies in the editor is continuously updated by this process, so much so that typing in the editor and modifying for example a method signature, you can see the outline view updated in real time.
Now, I have 2 questions about this:
1) this process of "reconciliation" is done by default incrementally on regions of code that have been modified, or the parser is always triggered on the whole source, so that the EMF model is continuously replaced by new result of parsing?
2) how can I obtain this updated model to work on it? I know that, starting form an editor part, I'm able to obtain the model in this way:
IFile file = (IFile) editorPart.getEditorInput().getAdapter(IFile.class);
IProject project = file.getProject();
URI uri = URI.createPlatformResourceURI(file.getFullPath().toString(), true);
ResourceSet rs = resourceSetProvider.get(project);
Resource r = rs.getResource(uri, true);
DSLModel model = (DSLModel) r.getContents().get(0);
but in this way I obtain the model updated to the last file saving , and not to the actual content of the editor in this moment! My only idea was to parse from zero the source code in the editor to obtain an updated EMF model representation... but since this model is continuously updated from Eclipse, I want to know if there's a way to obtain it!
Thanks in advance,
Marco
Re: How to obtain the Eclipse automatically-updated EMF model? [message #1005043 is a reply to message #1005011] |
Thu, 24 January 2013 11:16 |
Ed Merks Messages: 33142 Registered: July 2009 |
Marco,
If you have the XtextEditor instance you can use this to get read access
to the resource containing your model
xtextEditor.getDocument().readOnly
(new IUnitOfWork.Void<XtextResource>()
public void process(XtextResource state) throws Exception
// Read state of model here...
On 24/01/2013 11:10 AM, Marco Naddeo wrote:
> Hi all. :)
> true);
> but in this way I obtain the model updated to the last file saving :?,
> obtain it!
> Thanks in advance,
> Marco
Ed Merks
Re: How to obtain the Eclipse automatically-updated EMF model? [message #1005332 is a reply to message #1005011] |
Thu, 24 January 2013 22:11 |
Jan Koehnlein Messages: 760 Registered: July 2009 Location: Hamburg |
1) We do partial parsing on the smallest possible region and thus try to
replace the smallest possible subtree in the model. Note that the
efficiency of this approach depends a lot on how you design your
grammar. As a rule of thumb, it's more efficient if you keep the
parser's lookahead low.
2) You can get the model as Ed suggested, or register an
IXtextModelListener to the editor. In addition, we have our own dirty
state management. Explore the code around the classes
IExternalContentSupport and IDirtyStateManager if you want to learn more.
Am 24.01.13 11:10, schrieb Marco Naddeo:
> Hi all. :)
> true);
> Thanks in advance,
> Marco
Get professional support from the Xtext committers at www.typefox.io
Re: How to obtain the Eclipse automatically-updated EMF model? [message #1005581 is a reply to message #1005469] |
Sat, 26 January 2013 18:45 |
That would be a bad idea, as many UI components rely on the semantic
model to be intact (outline, validation, etc.)
Am 25.01.13 16:03, schrieb Marco Naddeo:
> Thanks, Ed and Jan! :)
> And is it possible to disable temporarily the automatic update of the
> EMF model in an editor (on user typing)?
> I need to update on an action the source code, and its model, manually,
> and then restore the automatic management.
> Marco
Current Time: Fri Apr 26 08:06:41 GMT 2024
Powered by FUDForum. Page generated in 0.04061 seconds
