| Can it has bidirectionl sychronization? [message #1004565] |
Wed, 23 January 2013 08:14  |
Assume we use the EMF to model a simple class diagram. It has a class named "Example" with an attribute named "name" which is EString type.
Example
With EMF, we will generate methods "setName()" and "getName()" in the code template Example.java.
I just wonder if I change methods "setName()" and "getName()" to "setDescription()" and "getDescription()", can the ecore model will change the attribute name from "name" to "description" automatically?
Thanks for your attention.
Best Regards,
Lucy Chan
| Re: Can it has bidirectionl sychronization? [message #1004569 is a reply to message #1004565] |
Wed, 23 January 2013 08:25   |
Lucy,
No, there's no automatic reverse engineering from generated code to the
Ecore model. But, if you define your model with Xcore, you can refactor
the "name" feature in the Xcore source and it will invoke Java
refactoring on the generated code and that refactoring will also rename
all the hand written uses of all the renamed things, including the use
of constants in the generated package. Xcore supports refactoring of
all named elements.
http://wiki.eclipse.org/Xcore
If you don't use Xcore, you should refactor your Java code to rename the
getter and setter (that's important only if you have hand written code
that uses the old name), rename the feature in Ecore, and then
regenerate the model.
> Example
> Best Regards,
> Lucy Chan
FUDForum. Page generated in 0.04016 seconds
