TABLE_PER_TENANT [message #1003831] |
Tue, 22 January 2013 04:38 |
sys alleys Messages: 3 Registered: January 2013 |
Anyone implemented TABLE_PER_TENANT strategy with Eclipselink coz I could not
find a basic tutorial of how to implement that? Though I tried but it is not working.
thanks in advance
[Updated on: Tue, 22 January 2013 04:39] Report message to a moderator
Re: TABLE_PER_TENANT [message #1005707 is a reply to message #1004102] |
Mon, 28 January 2013 11:04 |
Hi ,
thanks for your response. I have gone through your links but there is no clear indication. I put the environments and the code
pls. make a review if it is right but I am getting null pointer exception.
Environment:
Netbeans 7.2 , Glassfish 3.1, EclipseLink, version: Eclipse Persistence Services - 2.4.1.v20121003-ad44345
EJB:: Account.java
@Entity
@Multitenant(MultitenantType.TABLE_PER_TENANT)
@TenantTableDiscriminator(type=TenantTableDiscriminatorType.SCHEMA, contextProperty="eclipselink.mytenant1")
@Table(name = "ACCOUNT")
@XmlRootElement
@NamedQueries({
Stateless:: AccountServices.java
public EntityManager getEMF() {
if (em == null) {
// Non shared EMF
System.out.println("getEMF()-> emf is null");
HashMap properties = new HashMap();
properties.put(PersistenceUnitProperties.TRANSACTION_TYPE, PersistenceUnitTransactionType.JTA.name());
properties.put(PersistenceUnitProperties.MULTITENANT_SHARED_EMF, "false");
properties.put(PersistenceUnitProperties.SESSION_NAME, "non-shared-emf-for-mytenant1");
properties.put(PersistenceUnitProperties.MULTITENANT_PROPERTY_DEFAULT, "mytenant1");
em = Persistence.createEntityManagerFactory("tenantproj-ejbPU").createEntityManager(properties);
return em;
Persistence.xml
<persistence-unit name="tenantproj-ejbPU" transaction-type="JTA">
<jta-data-source>jndi/mytenant1</jta-data-source>
<exclude-unlisted-classes>false</exclude-unlisted-classes>
<properties>
<property name="javax.persistence.jdbc.driver" value="com.mysql.jdbc.Driver" />
<property name="javax.persistence.jdbc.url" value="jdbc:mysql://localhost:3306/mytenant1?zeroDateTimeBehavior=convertToNull" />
<property name="javax.persistence.jdbc.user" value="xxxx" />
<property name="javax.persistence.jdbc.password" value="mysqlxx" />
<property name="eclipselink.multitenant.tenants-share-emf" value="false"/>
<property name="eclipselink.session-name" value="non-shared-emf-for-mytenant1"/>
<property name="eclipselink.tenant-id" value="mytenant1"/>
</properties>
</persistence-unit>
</persistence>
Error
Calling EJB Services->CreateT()
javax.ejb.EJBException
at com.sun.ejb.containers.BaseContainer.processSystemException(BaseContainer.java:5215)
at com.sun.ejb.containers.BaseContainer.completeNewTx(BaseContainer.java:5113)
at com.sun.ejb.containers.BaseContainer.postInvokeTx(BaseContainer.java:4901)
at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:2045)
at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:1994)
at com.sun.ejb.containers.EJBObjectInvocationHandler.invoke(EJBObjectInvocationHandler.java:213)
at com.sun.ejb.containers.EJBObjectInvocationHandlerDelegate.invoke(EJBObjectInvocationHandlerDelegate.java:79)
at $Proxy173.createT(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at com.sun.corba.ee.impl.presentation.rmi.ReflectiveTie.dispatchToMethod(ReflectiveTie.java:144)
at com.sun.corba.ee.impl.presentation.rmi.ReflectiveTie._invoke(ReflectiveTie.java:174)
at com.sun.corba.ee.impl.protocol.CorbaServerRequestDispatcherImpl.dispatchToServant(CorbaServerRequestDispatcherImpl.java:528)
at com.sun.corba.ee.impl.protocol.CorbaServerRequestDispatcherImpl.dispatch(CorbaServerRequestDispatcherImpl.java:199)
at com.sun.corba.ee.impl.protocol.CorbaMessageMediatorImpl.handleRequestRequest(CorbaMessageMediatorImpl.java:1624)
at com.sun.corba.ee.impl.protocol.CorbaMessageMediatorImpl.handleRequest(CorbaMessageMediatorImpl.java:1486)
at com.sun.corba.ee.impl.protocol.CorbaMessageMediatorImpl.handleInput(CorbaMessageMediatorImpl.java:990)
at com.sun.corba.ee.impl.protocol.giopmsgheaders.RequestMessage_1_2.callback(RequestMessage_1_2.java:214)
at com.sun.corba.ee.impl.protocol.CorbaMessageMediatorImpl.handleRequest(CorbaMessageMediatorImpl.java:742)
at com.sun.corba.ee.impl.protocol.CorbaMessageMediatorImpl.dispatch(CorbaMessageMediatorImpl.java:539)
at com.sun.corba.ee.impl.protocol.CorbaMessageMediatorImpl.doWork(CorbaMessageMediatorImpl.java:2324)
at com.sun.corba.ee.impl.orbutil.threadpool.ThreadPoolImpl$WorkerThread.performWork(ThreadPoolImpl.java:497)
at com.sun.corba.ee.impl.orbutil.threadpool.ThreadPoolImpl$WorkerThread.run(ThreadPoolImpl.java:540)
at org.eclipse.persistence.descriptors.DescriptorEventManager.notifyEJB30Listeners(DescriptorEventManager.java:619)
at org.eclipse.persistence.descriptors.DescriptorEventManager.executeEvent(DescriptorEventManager.java:200)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerNewObjectClone(UnitOfWorkImpl.java:4287)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerNotRegisteredNewObjectForPersist(UnitOfWorkImpl.java:4264)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.registerNotRegisteredNewObjectForPersist(RepeatableWriteUnitOfWork.java:511)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.registerNewObjectForPersist(UnitOfWorkImpl.java:4206)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.persist(EntityManagerImpl.java:451)
at au.com.std.tenantproj.jee.services.AbstractServices.createT(AbstractServices.java:28)
at au.com.std.tenantproj.jee.services.AccountServices.createT(AccountServices.java:24)
at org.glassfish.ejb.security.application.EJBSecurityManager.runMethod(EJBSecurityManager.java:1052)
at org.glassfish.ejb.security.application.EJBSecurityManager.invoke(EJBSecurityManager.java:1124)
at com.sun.ejb.containers.BaseContainer.invokeBeanMethod(BaseContainer.java:5388)
at com.sun.ejb.EjbInvocation.invokeBeanMethod(EjbInvocation.java:619)
at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:800)
at com.sun.ejb.EjbInvocation.proceed(EjbInvocation.java:571)
at org.jboss.weld.ejb.SessionBeanInterceptor.aroundInvoke(SessionBeanInterceptor.java:49)
at sun.reflect.GeneratedMethodAccessor116.invoke(Unknown Source)
at com.sun.ejb.containers.interceptors.AroundInvokeInterceptor.intercept(InterceptorManager.java:861)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.doAround(SystemInterceptorProxy.java:162)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundInvoke(SystemInterceptorProxy.java:144)
at sun.reflect.GeneratedMethodAccessor115.invoke(Unknown Source)
at com.sun.ejb.containers.interceptors.InterceptorManager.intercept(InterceptorManager.java:370)
at com.sun.ejb.containers.BaseContainer.__intercept(BaseContainer.java:5360)
at com.sun.ejb.containers.BaseContainer.intercept(BaseContainer.java:5348)
at com.sun.ejb.containers.EJBObjectInvocationHandler.invoke(EJBObjectInvocationHandler.java:206)
... 19 more
Re: TABLE_PER_TENANT [message #1006048 is a reply to message #1005707] |
Tue, 29 January 2013 16:01 |
The null-pointer seems like the descriptor was not initialized.
It could be an issue with passing the properties to the createEntityManager, try removing this.
Also please try the latest patch, and log a bug if you still get the error, a null-pointer exception should never occur.
James : Wiki : Book : Blog : Twitter
FUDForum. Page generated in 0.02943 seconds
