Re: Limiting input in FormFields [message #1003954 is a reply to message #1003858] |
Tue, 22 January 2013 10:16 |
Urs Beeli Messages: 573 Registered: October 2012 Location: Bern, Switzerland |
Jeremie Bresson wrote on Tue, 22 January 2013 07:21Are you using Swing UI or SWT UI ?
My "Playground application" I use to learn all I can about Scout is using both Swing and SWT. Our "real" application will use SWT only.
Jeremie Bresson wrote on Tue, 22 January 2013 07:21have you see differences between both UI ?
=> If yes, one UI is probably not completely implemented and we need to fix it.
I've seen some differences between Swing and UI with regard to validation:
- StringField.execValidateValue without ValidateOnAnyKey (filtering out all input except for [A-Za-z]) works for both UIs when leaving the field
- StringField.execValidateValue with ValidateOnAnyKey (filtering out all input except for [A-Za-z]) is called after each keypress for both UIs, however the modified return value is not written back to the input field with either of them. When leaving the field, in SWT the value is then replaced, in Swing it isn't (but should be, I think)
- other than that, the two implementations seem to behave the same as far as I can tell
Jeremie Bresson wrote on Tue, 22 January 2013 07:21I am afraid that the kind of control you want to achieve requires
- Custom Fields and custom UI Renderer
- Modification of Scout
I think that you can do suggestions.[/quote]
Do you want me to make them here? Or should I open a bug report? (One of my colleagues has already opened a ticket for supporting ValidateOnAnyKey on Fields other than StringField (https://bugs.eclipse.org/bugs/show_bug.cgi?id=398283)).
The remaining suggestion would be that the mechanism of replacing the field contents with the return value of execValidateValue also function for ValidateOnAnyKey=true.
Re: Limiting input in FormFields [message #1005233 is a reply to message #1003954] |
Thu, 24 January 2013 17:26 |
Jeremie Bresson Messages: 124 Registered: November 2010 |
I appreciate the time you have taken to make a deep test of scout. Sharing on the forum let us know you, your concerns, your vision from Eclipse Scout. It is very challenging.
I have given my opinion on bug 398283.
Urs Beeli wrote on Tue, 22 January 2013 11:16
If you want to discuss something, or if you look for answers. The forum is the right place.
If you consider that something needs to be changed in the code (because it is a bug, or an enhancement request) a bug in bugzilla is necessary. Please add as much information as possible the bug (if necessary: minimal example, step to reproduce, platform...). This helps a lot to understand the request correctly.
You can also combine both approaches (if you link the bug and the forum post in both directions, there is no problem at all).
I can not assure you that every opened bug will be solved immediately, because there is a lot to do. But it is the only way to improve eclipse scout on the long term.
FUDForum. Page generated in 0.04609 seconds
