Home » Archived » Visual Editor (VE) » Editing Layouts
Editing Layouts [message #145758] Wed, 18 March 2009 17:41 Go to next message
How do I set the active card in a CardLayout?
How do I set the grid row/column size in a GridBagLayout?
MB
Re: Editing Layouts [message #145797 is a reply to message #145758] Wed, 18 March 2009 18:50 Go to previous messageGo to next message
I was able to set up the GridBagLayout using the constraints property in
the actual objects.
However, I still can't figure out how to set the active card in a
CardLayout.
MB
Re: Editing Layouts [message #145807 is a reply to message #145797] Thu, 19 March 2009 05:47 Go to previous messageGo to next message
> the actual objects.
> CardLayout.
> MB
I don't think it is possible to explicitly set the active card using VE.
The default card displayed tends to be the panel first in the list.
It is very easy to do programmatically. You can use the CardLayout's
show() method to set a specific panel active.
CardLayout layout = (CardLayout)cardPanel.getLayout();
layout.show(cardPanel, "activePanel");
Alternatively, the next() and previous() methods can be used to navigate
through the sequence of panels in the card layout.
Hope that helps,
Matt.
Re: Editing Layouts [message #145814 is a reply to message #145807] Thu, 19 March 2009 09:57 Go to previous message
If you want to switch between the cards while in the VE, just select the
card (or any component under that card) in the Beans viewer. It will
bring that card to the top.
Rich Kulp
Re: Editing Layouts [message #617337 is a reply to message #145758] Wed, 18 March 2009 18:50 Go to previous message
the actual objects.
CardLayout.
MB
Re: Editing Layouts [message #617338 is a reply to message #145797] Thu, 19 March 2009 05:47 Go to previous message
> the actual objects.
> CardLayout.
> MB
Hope that helps,
Matt.
Re: Editing Layouts [message #617339 is a reply to message #145807] Thu, 19 March 2009 09:57 Go to previous message
Rich Kulp
Previous Topic:Broken GUI Editor after adding field to frame.
Next Topic:Broken GUI Editor after adding field to frame.
Current Time: Sat Nov 08 02:04:00 EST 2025
Powered by FUDForum. Page generated in 0.05131 seconds
