| Confused Newcomer [message #1002103] |
Thu, 17 January 2013 18:49  |
Hello, I just need some clarification please, nothing technical, except for my brain being able to understand. I've been taking C++, Java, HTML classes in college. This semester I'm taking a course on Mobile Apps. The book we're using is PhoneGap Essentials. If you could please explain, I need a SDK and an IDE plus something else like PhoneGap or Eclipse to build a mobile application? I'm really confused as to what I actually need to build anything. The book seems vague and when I found your site, I thought you might be able to give insight.
TYVM
Carol
| Re: Confused Newcomer [message #1002400 is a reply to message #1002103] |
Fri, 18 January 2013 09:02   |
Carol,
Generally you can install any package and then use Install New Software
to install additional things from other update sites, or, if the
software comes from Eclipse and was part of the release train, from the
release train's update site, e.g.,
http://download.eclipse.org/releases/indigo (which will be in the drop
down list by default).
> TYVM
> Carol
| Re: Confused Newcomer [message #1002457 is a reply to message #1002103] |
Fri, 18 January 2013 11:06  |
> TYVM
> Carol
In addition to what Ed says about being able to heap disparate tools up
in your Eclipse environment (or you can install separate versions of
Eclipse and just run the appropriate one for each project if you like
that idea better), there are good tutorials.
The best tutorials on just about everything Eclipse, including one on
Android to help you get started on satisfying your mobile requirement,
can be found at http://www.vogella.de.
FUDForum. Page generated in 0.09528 seconds
