Home » Eclipse Projects » Eclipse Platform » swt: how to add to a TableViewer
swt: how to add to a TableViewer [message #145727] Fri, 17 October 2003 10:03 Go to next message
Originally posted by: tcn.spamgourmet.com
Hi!
How do I dynamically add lines to a TableViewer? I don't have to setInput()
an array with all lines everytime I want to add one, do I?
Timo
Re: swt: how to add to a TableViewer [message #145991 is a reply to message #145727] Fri, 17 October 2003 16:26 Go to previous messageGo to next message
Nope.
// Where
private StructuredViewer viewer;
// and
private List content;
// and you've initially done
viewer.setInput(content);
// thereafter doing
content.add("stuff");
//followed by a refresh
Display.getDefault().syncExec(
new Runnable() {
public void run() {
viewer.refresh();
// should work.
HTH
Rich
Re: swt: how to add to a TableViewer [message #146113 is a reply to message #145991] Sat, 18 October 2003 04:11 Go to previous messageGo to next message
> // thereafter doing
And what's content? setInput() requires a plain Object (something I yet
don't understand by the way :), the wizard per default passes
REsourcesPlugin.getWorkspace() to setInput().
Re: swt: how to add to a TableViewer [message #146131 is a reply to message #146113] Sat, 18 October 2003 05:44 Go to previous messageGo to next message
Hi Timo,
Pass it a List of Objects that you want it to show (or a list of any
subclass of Object) - keep a reference to that List (hence the...
in the earlier snippet) so that changing the content of "content"
(combined with the rest of the earlier bits) will change the content of
your table.
rich
Re: swt: how to add to a TableViewer [message #146141 is a reply to message #146131] Sat, 18 October 2003 05:57 Go to previous messageGo to next message
> your table.
But this makes either the entire table to be redrawn or the content list to
be iterated for changes each time.
Re: swt: how to add to a TableViewer [message #148684 is a reply to message #145727] Thu, 23 October 2003 14:14 Go to previous message
Originally posted by: John_Arthorne.oti.com_
Use TableViewer.add(Object) to add items to your table. This is usually
done from your content provider, whose job is to keep your domain model
in sync with the viewer.
Timo Nentwig wrote:
> Hi!
> Timo
Previous Topic:catching output and displaying in a progress dialog
Next Topic:classloading error after defining package prefixes
Current Time: Mon Sep 22 05:58:54 EDT 2025
Powered by FUDForum. Page generated in 0.04246 seconds
