Re: Setup java visual editor [message #145699 is a reply to message #145689] |
Thu, 05 February 2009 01:55 |
Hello Cihat,
For Eclipse 3.4, please use Visual Editor 1.4.
Updatesite : http://update.soyatec.org/Ganymede/ve/1.4
I hope thats the resolution for your problem.
Cihat Eldeniz schrieb:
> Hello,
> I have never been able to see the empty form on which you put command
> buttons and other objects. I only see the empty palette. What happened
> was that, when I use the New Visual Class Wizard, I chose Composite
> under SWT and I had already included SWT in the library of the project.
> Right after I finished the selections in the wizard, the builder tried
> to build. It said setup java visual editor and it freezed at 25% and
> after some time "Parse error" appeared in the status bar. If I choose
> Shell rather than Composite [under SWT], then things get somewhat worse;
> it says "Loading..." and it directly gives the "Parse error" afterwards.
> I am writing down the OS and version information and your help in this
> is highly appreciated. Thanks in advance.
> OS: Windows XP Eclipse: 3.4
> Virtual Editor: 1.2
> EMF: 2.4
> GEF: 3.4
> Java EMF Model: 1.2
Re: Setup java visual editor [message #617327 is a reply to message #145689] |
Originally posted by: enricor.eclipse.gmx.de
Hello Cihat,
> Hello,
> Virtual Editor: 1.2
> EMF: 2.4
> GEF: 3.4
> Java EMF Model: 1.2
FUDForum. Page generated in 0.04459 seconds
