Simple way to save the list of files opened in editor? [message #1001427] |
Wed, 16 January 2013 17:15 |
Blaine Fredrickson Messages: 1 Registered: January 2013 |
It happens every day. I need to do a fix or mod on our software.
I have about 10 different "features" that I work with. Each has between 3 - 10 files that typically need to be worked on or referenced. Some of them are .java, some .js, and some .htm . What's worse, they're often scattered across multiple directories. Unfortunately, we have thousands of class files!!!
Is there any way that once I have all the files located and open for a given "feature", I could save that list under a given name. Then, when I need to work on this "feature" next time, I could just open that "feature", and all the files I've associated with that "feature" would automatically be opened?
I'm using Eclipse 4.2 currently. I've tried Working Sets, and that's a step in the right direction, but doesn't open the specific files I need. I still have to look through the directories and find the files associated with that "feature".
Any help on this would be appreciated by all the "coders" in our group!
Re: Simple way to save the list of files opened in editor? [message #1001520 is a reply to message #1001427] |
Wed, 16 January 2013 21:29 |
> of class files!!!
I think there are tools built atop Mylyn that do stuff like this. It's
not something you'll find among Eclipse technology proper, but added on.
For example, Perforce plug-ins do this because Perforce manages changes
via changelists.
Keep looking, but be open to outside sources as well.
FUDForum. Page generated in 0.07821 seconds
