Home » Archived » BIRT » render PDF / WORD / PDFCreator(render PDF / WORD / PDFCreator)
render PDF / WORD / PDFCreator [message #1001250] Wed, 16 January 2013 05:21 Go to next message
I get a difference between a report that I execute through BIRT in PDF an the same report through BIRT in WORD then PDFCreator.
I do'nt get the same fonts (less in PDF than in WORD/PDFCreator)
Any explanation ?
Any solution ?
Dominique
Re: render PDF / WORD / PDFCreator [message #1001407 is a reply to message #1001250] Wed, 16 January 2013 11:45 Go to previous messageGo to next message
Can you give some more detail? How are you executing the BIRT reports and what version are you using?
Re: render PDF / WORD / PDFCreator [message #1001414 is a reply to message #1001407] Wed, 16 January 2013 11:53 Go to previous messageGo to next message
BIRT 2.3.0
rcp report designer for create .rptdesign
It's run through an insurance ERP (CLEVA)
Dominique
Re: render PDF / WORD / PDFCreator [message #1001420 is a reply to message #1001414] Wed, 16 January 2013 12:03 Go to previous messageGo to next message
Dominique
Is the ERP version using the BIRT runtime API or the Viewer? Any chance you could try with a later version of BIRT?
Jason
Re: render PDF / WORD / PDFCreator [message #1001445 is a reply to message #1001420] Wed, 16 January 2013 13:13 Go to previous messageGo to next message
No chance
but anyway we get the same problem through the RCP designer !!
Re: render PDF / WORD / PDFCreator [message #1001940 is a reply to message #1001445] Thu, 17 January 2013 10:33 Go to previous message
Can you reproduce the issue with a sample report that we can run?
Jason
Previous Topic:Conditional statement not works in dynamic text
Next Topic:Code Completion for external JavaObjects in JavaScript - BIRT Designer
Current Time: Sun Nov 09 02:36:40 EST 2025
Powered by FUDForum. Page generated in 0.03425 seconds
