| iSeries Connection [message #1000488] |
Mon, 14 January 2013 16:48 |
If this is not the correct forum, i apolosige.
All i want to do is connect to my iseries, logon (of course), run a comand (like CRTLIB TESTING) and get the result message(s).
I have succefuly used:
VB, C, and C++, both on Windows and Linux (NOT VB of course), to run commands and APIs.
I have done some small java apps for android using Eclipse IDE.
I am and iSeries administrator and developer for over 15 years.
Now my company wants to move to Eclipse.
I have downloaded and installed the IBM Eclipse Developmente Package...
I have an Eclipse instalation with C, C++ and Java IDEs...
But still can't do a simple thing like connecting and logging on...
NOTE: I want to logon to the system, not connect to a database. That i can do (with JAVA).
With VB (the easiest) or C/C++ in windows i use the cwbx.dll and create an AS400 object.
Logon and issue commands or call APIs via .Command or .Run or .Call depending on the objective.
Example:
Dim i5Sys = CreateObject("cwbx.AS400System")
i5Sys.IPAddress = IPADRESS
i5Sys.UserID = USERID
i5Sys.Password = USERPASSWORD
Try
i5Sys.Signon()
Catch ex As Exception
msgbox(ex.Message)
Return
End Try
CommandText = "CRTLIB TESTING"
CommandToRun.system = i5Sys
Try
CommandToRun.Run(Trim(CommandText))
msgbox(ex.Message)
return
End Try
Can someone help me?
A tutorial would be great but any help is welcome...
Thank you.
A.Felix
FUDForum. Page generated in 0.08749 seconds
