Home » Language IDEs » Java Development Tools (JDT) » Stable JDT anywhere(Eclipse is not working in Red Hat Linux)
Stable JDT anywhere [message #1000444] Mon, 14 January 2013 14:37 Go to next message
Since Eclipse is not working in the Red hat environment, crashes every time I enter "this.", bugs (bug 397782) generated with logs show no interest let alone resolution, does anyone know a stable JDT that is available?
Re: Stable JDT anywhere [message #1000543 is a reply to message #1000444] Mon, 14 January 2013 19:44 Go to previous messageGo to next message
Some comments:
- please apply a bit more patience, a few days wait doesn't imply nobody cares
- this clearly is not a question about a stable JDT, the problem is in the browser integration of SWT
- their are options to use a different browser than mozilla, you should try Preferences > General > Web Browser (do you have WebKit installed?)
- it would be interesting if you could try several JVM's to see if IcedTea is to blame.
OTOH, I can only say that on Kubuntu I haven't seen that problem, which at least indicates it's not a general Linux problem.
HTH,
Stephan
Re: Stable JDT anywhere [message #1000715 is a reply to message #1000444] Tue, 15 January 2013 05:08 Go to previous messageGo to next message
> available?
JDT is stable but your install is probably not. It looks like the same
problem as reported in https://bugs.eclipse.org/385035 . Please read the
comments in there, they have hints on how to fix the Web browser install.
Dani
Re: Stable JDT anywhere [message #1000796 is a reply to message #1000444] Tue, 15 January 2013 07:51 Go to previous messageGo to next message
I am restricted to using Red hat. There is no browser being used in the application nor is a browser being run in the background. All that is required for the crash is to type: this.
Re: Stable JDT anywhere [message #1000801 is a reply to message #1000796] Tue, 15 January 2013 07:56 Go to previous messageGo to next message
Just believe Dani and your stacktrace: Eclipse was internally trying to create browser widget for displaying some information.
The rest you'll find in the bug Dani mentioned.
S.
Re: Stable JDT anywhere [message #1000814 is a reply to message #1000796] Tue, 15 January 2013 08:12 Go to previous messageGo to next message
JDT uses a Browser-Widget to e.g. show JavaDoc!
Tom
Am 15.01.13 13:51, schrieb Lance Mead:
Re: Stable JDT anywhere [message #1001425 is a reply to message #1000444] Wed, 16 January 2013 12:12 Go to previous message
I have posted on the other bug report, no response. I don't have any of the files on my computer that they request I search for but still have the issue. Following the thread is seems that there are others with this problem. Bottom line it seems Eclipse will be unuseable for weeks.
Previous Topic:Eclipse freezes after opening wsdl in design( gui ) mode on Arch Linux + Openbox
Next Topic:Error occur when delete a file from package explorer
Current Time: Fri Sep 12 08:55:01 EDT 2025
Powered by FUDForum. Page generated in 0.04247 seconds
