Re: [ACCELEO] Dynamic templates generator deployment [message #1001910 is a reply to message #1001707] |
Thu, 17 January 2013 14:45 |
Romain Bernard Messages: 27 Registered: July 2009 |
Hi Stéphane,
Thank you for your response that helped me to understand better the problem nature...
Actually, in my plugin.xml, I reference the modules path with something like :
<templates path="src/folders/subfolders/mymodulesrootfolder"/>
But when exported as a plugin, the src folder is not here anymore ! In my exported jar plugin, .emtl files can be found next to .class files, in the folder "folders/subfolders/mymodulesrootfolder"...
So I tried to reference the path with "folders/subfolders/mymodulesrootfolder" (trimming the "src/"), but it does not work (+ warning in my plugin.xml, because this path does not exist in the development environment, and my generator modules are never called).
I also tried to export my src folder with the build.properties, but unfortunately, .emtl files are not exported by PDE in the src folder...
Is there another way to reference the path, or to include .emtl files in the src/ folder of a deployed generator plugin ?
Thanks in advance,
kind regards
Romain
FUDForum. Page generated in 0.24691 seconds
