Home » Modeling » GMF (Graphical Modeling Framework) » Display collapsed compartments by default
Display collapsed compartments by default [message #145157] Thu, 02 August 2007 09:31 Go to next message
I have a huge diagram with a lot of nodes and connections. The top level
node is a compartment.
When I initialize the diagram file for my model I want the compartments
to be displayed in a collapsed state.
I managed to sort of do this by changing the
MyCompartmentViewFactory.setupCompartmentCollapsed(View) method to this:
protected void setupCompartmentCollapsed(View view) {
DrawerStyle drawerStyle = (DrawerStyle)
view.getStyle(NotationPackage.eINSTANCE
.getDrawerStyle());
if (drawerStyle != null) {
drawerStyle.setCollapsed(true); // <-- Changed
This speeds up dramatically the initial display, but there's a glitch.
When I expand a compartment it only contains the nodes and no
connections between them. I suspect that this is a refresh problem.
Any ideas on how to solve this?
Robert
Re: Display collapsed compartments by default [message #145167 is a reply to message #145157] Thu, 02 August 2007 16:51 Go to previous messageGo to next message
This could be a bug in CanonicalConnectionEditPolicy. Could you please
investigate the problem a little bit deeper? I suspect that something goes
wrong in the edit policy mentioned above - it's responsible for refreshing
connections between nodes within compartments. Another class that maybe
involved in the issue is ConnectionRefreshMgr.
BTW, is your editor generated or developed based on the runtime component?
Alex
Re: Display collapsed compartments by default [message #145221 is a reply to message #145167] Fri, 03 August 2007 04:29 Go to previous message
--------------090901060303020609050001
Alex,
My diagram editor is generated with GMF. Unfortunately I'm not very
familiar with the GMF runtime. I tried debugging the code, but couldn't
really find something useful :-(
But I've managed to reproduce the problem by modifying the Mindmap
example from the GMF tutorial:
- threads can now have relationships between them (changes in both model
and diagram definition)
- the topic compartments stay collapsed when initializing the diagram (I
modified the
org.eclipse.gmf.examples.mindmap.diagram.view.factories.Topi cThreadCompartmentViewFactory.setupCompartmentCollapsed(View
view), line 67 ); this is the only modification in the generated diagram
editor code.
Please see the attached sampleMindmap.gif which exemplifies the supposed
bug (I still might have not made all the required modifications in the
code).
The model does contain relationships between the shown threads (thread11
-> thread12, thread21 -> thread22 and thread31 -> thread32). However,
after initializing the diagram and expanding the compartments, only the
link of the thread11 -> thread12 relationship gets shown. The other two
links do not show up in the diagram.
I attached the modified workspace projects to see this for yourself.
Robert
Alex Boyko wrote:
> goes wrong in the edit policy mentioned above - it's responsible for
> refreshing connections between nodes within compartments. Another class
> that maybe involved in the issue is ConnectionRefreshMgr.
> Cheers,
> Alex
Content-Type: image/gif;
name="sampleMindmap.gif"
Content-Disposition: inline;
filename="sampleMindmap.gif"
R0lGODlhYQLJAPf/AP///9zc+rCwsPr6vrSQPbCPPqyMQKeKQqKIQ52FRZeC RpF/SIx9Sod6
TIN3TX51TntzUPn6/Pf5+/X4+/L1+/D1++3y+urw+ebu+eTs+eHq+N/p+Nzn 93t0UPj5/Jqs
y/P2+6y81efu+aKzz3t0T/j5+5OmxvL2+6i40+7y+t3n93pzT4yfwoaavvP1 +/b4+9Syadq9
fODIj9/o99Wyad7o99SyaPD0+97o+KeLQo19Sn90TntzTwAAAImJaLm5ja+v hUxMOWZmTdzc
p8zMm6SkfHl5XJeXc+Tkrezss1aSwUaIvDyCuRRpqxBViuH2/0uJuOTZvd7V wMrBpsPDlMW+
qIyMjL29vbKysk1NTZqammhoaMfHx9DQ0Onp6fDw8Hx8fKenp+Hh4dTUoY+P j4KCgpWVlVpa
ZkJCTLu71MLC3GtrednZ2QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACwAAAAAYQLJAAAI/gABCBxIsKDB gwgTKlzIsKHD
hxAjSpxIsaLFixgzatzIsaPHjyBDihxJsqTJkyhTqlzJsqXLlzBjypxJs6bN mzhz6tzJs6fP
n0CDCh1KtKjRo0iTKl3KtKnTp1CjSp1KtarVq1izat3KtavXr2DDih1LtqzZ s2jTql3Ltq3b
gQHiyp1Lt67du3jz6t3Lt6/fv4AD1z0puLDhw4gTJyasuLHjx5Ahi4w7lIDl y5bNUp4c4CZm
zFo3hxSt8/NlsKQ1pgZKIILr1zAInF2dkbbM1q9dx95q+2Jvm7hz70bdWfXR KBKSS/DgIQYN
2Ra3dEl4hQvR4hux40SunLlz6BWl/h+8kqUHFpzaawflntz784viDWrpYd5n eor3gTrZP6G/
fxkx2GAAQVZcoVEYPRh4XXY67eeEf/8FOOBABWZkIBs9THdTfvjpxx+EEwAo IIEKXiQGABhq
yBOHD7HokxNPOAEFBQ5SYCMFORCU4EY7FuViizvBKCON+92Io44lZtTjhurp F+OMNd6Y40BL
KpnkTj8ulGWQ+1UAhZAVhFkBAlTS14NA82WhoXlW1AdAjwj2YJ1AVQq1JUN3 tuSgl2CKSSad
ZqLZg5p0YtHmeW8qGOecAHzRAxs55amQpDHt+WWMYo5ZJn2CEvqmoW7CSR+j XWTxxU+UFpSq
TVBIYYEF/g6++moCSKK5BQBc9ODFm2Dg2sOJO4axxam1+tikTq2+GqustFKp oBa35rprD73m
CqyBwhI7kLA6rWqQty4lC+t+slrQLJ3PRqsrr75eC0C2OsoJFLjg1gTFBfje ey++ChTb447/
GrhjFlcmelS9ACB80r4X6IvvBf06i+7EARtMcEFiPIqlb0Qx7DC//ioIsMgC G3hxQV38Om+H
RSnBRBMATAEFBjNjgIGDC4RMscjWjWxQnXZynJPLMMtMs80375ezxAYb/G/P JRe0hRYrCu0T
0THPXHPSTiw9cdM+vwl10wUB3S3LSDGQgYMZXOqEDjoiCq2vp/Zgha/TGgit /rZfG2uRwiap
zbbbcFMpt7p13y2twXsPpEUWPSEM+EqC79e2kIUXaivdbyq+7o6NC3Riyiei ijZRTcDcgAZC
QsH6flUQdMWgArUZXw/CetrjfBkCyqnfFU0eUuoArN76607EPtDskANg+5q5 r/ksfdOZafZM
kgdFvPFPIq+8QMzX3sPt0X/N+3Rtnmz6RMK/5MAGDm4gv/wOPHR9VNn39H78 829Qv0P3W9Df
iLK//fTPf/YrWFO81T6VLAFmAHgAByZIQQruIIFZyR9OHigQCVawghcEoAKN osGecDCCHwQh
BqXCQKVAoAMkWAEMY0gCCPBghVcpoU5eGMMZrqCG/jcU4QKtFhQeypAENLQh DqHSwrc8RYdO
lAkUo1g19lFxiAO8IvaIqMWNWbGLSZkiGFUixjHSpIlmBN7p0khGLrLxjGt8 4/qCJ8eVlLGO
LUEjHu3jxj1Opo9+ZAkDI0PIQhrykIX0DSIXychGHkaRjoykJCcJmDgGEj2A vGRH7qhJk+ix
k0zKIihBwslR/vGLprRJKVOJSkuyciSffCVMVilLIImyliSJJS4FmcldQoSW vrzlLzMigGIa
85jITKYyl8nMZjazLMBUiDOnSc1qWhOLdMSINbfJTW5m0JUREcAABmAay4zz nOhMpzrXyc52
tlMA0OzlQ8RJznK68574/sznOuHJlGgmhJ7lJIA+B0pQdvIzh+CECEBzoxuB FvShBD2oWPyJ
kIUyNDYQzWg+JRpGeTrEosJxqEZHus9vtrIi9CzAckqwnOY85549+AFJxxnT c/6ACui8KUdR
49GGpHSlLf0OTGU605r+IAg9AEJOqbDTg/WUIT/1AEvdI1J21rSoMj0CfZRq U6aaVCKAo6cB
JvABE7CgBS8QkQHU6QOiXpWkVy3CW+X6g6Z6haIHEStZzYpWtbLVrUSFq0xl OoYeEGGcdLWr
Gk9KEb2W9axpldBfaRrYkdZ0CAMo7GEHkNivRiSs4zwABUBwAhC4AASoBUEO 1HnVt1o2sK6N
/qliuYJXg9BTtKQ1bWpVy1rAznQAsYVtXbGZ0HmGdrSlPW1qV5vO1lZWo8E9 p2w9O0xtjhMB
FQgBCkbw2BbcAAHNNRNwgeCDHviApkUIwjjLe94BGIE+7U1CeX/w1uDOljdP XQg9satd7vL1
u+Glz3jZi171DoDA7oXvOOUb07cmoQdjkO5w+5lfaV43u9vtLoDRab0Bm7fA 6/1wgkXMYPoG
lghBSIKE7+sUXUqEngl4VQrKNave0lQIAxiCYYFrhHEe4QgDEAJXB4CEHR8B x0Sob2WnS5ba
FgTGMqaxuWwMXBzr+LA96PEAfhzkIRf5sEceQJIDWwQcr5i4jJ0I/pQtMGMa J4DKPbDyjrPs
YyAL+Zxf3jKSW9sDnJ4ZKy4O5zgVcIH+dhdicPYtnxWMBB8gVabOlTCHJzwW JxOEnoQ2NF8R
3VzfAhfSbjXTeRv96E9Tdpw6jvCfl2LpgWC60BnetAISfepFf5jUNY30OJOM WcqyGM22vAg9
F4ABERj72MVeAK1NretxCuEIDwb1qaft63gKs7HjJPaxkS0CZXd62rn2tLOh He5pP7vTv17Z
tdWc7WJvWwTJXna5TX3OZ0eb3tGtNqCL+9Fxqk3TZ82ADljL1Uhf9cgqpikQ dCxTI+CYCkqe
dLoRuu4X+zsDAG+BwAkObmnrOeHjZbh7/h9e0yMYWOLA/iwxL57xjTe34Iom KsKlu/CaOnwA
EJcpZnm9aqsEWqHjXJ0Ghk70oTdAnfRVr8GJ2ugeBOGwQGiwTJEghKfbmqaB anKF/xn0onv9
6OlMOr493vSnDyDqJiZy1ccMXDOF+nes3npFu+51ooM9p04fO73LDnWpq93q Mi1vEGCbdYqD
deUDeJ9/zzqDGuDAAb/97cR9Lve8jlPx3W384yM/08lHrvK2vfwGFt8CzUOe 8yP1PFJ+btwB
eFAFHIC9CmC/A9Sn3trZFPY4Xx/72NPe9hpVvRdzbxF68l72vwc+RIVPQn77 dJxG9CEQlb98
3DsfqtCH4RGT/sgD6j+U+ZEC/ZOz30Mk/tCG3i8o+AV4eOumH/Xrf6L4L/1+ +Ke8urqvf+Tj
H7Q0W1z/kmd9/idoANh59xdsxVeABrhvAwh0Cnh7WldxBPiAGcV/NdFqAkFP FFh9DNh++beB
3yeAHpiAIBiCFCaBDliCEUVdCIhSKqh+Iqhy7veC+mSBcISCrUeDG8WCDgFa OriDEUh8LviD
+GSDW4SD/UaE92SEfNSA89RNUBiFyhSD+Fd8UniFUniAPUhMWNiF3tSBMviB SmhQVNiC2DaG
76SFDeGDaFhSYFiFQ9iG6sSEHYWEzyeHc6iGeIJ4eIhOdFhFIxiHfThOf+hU doh9/oN4ToXo
EhgIABqYiIsYfk6YhIk4AJHIftenX5VIiHqoJXwIiTy4hp84iJc4FI34iKTY iZMyin1YiqqU
iRa2ia4YFKe4iZaoignBhqD4hmbIbrJYhls4g7sYd4eoib/Ii8EohqkYhLDI dcdIjEJ4hpU4
izcYiNI4jBM1f65mi9RIGNqYgdwYinsojMtYad/oiOF4gtHoi9Mojp5Ijq0I jKIIj3jYjZ50
jqgYj8g4j8qoj+ZYjLHYjurYjHP3jJQ3iXcokP+4jv+nkEpRiwZZFaxHidgY FhDpkHXIkBNY
kVQxkQnJkV9xkSDZfADpjBjZkQRpeRHJUyVZkCdpiBqZ/oIjiT8pGXorGZL4 mI7QWJPjd5Ms
xJOX5oVCSU3yOI7CNpRIyUy4iBBhlZROiUzuuIpEYY802ZLBpCrneJW5CJQw QZXyZ5VaKRCN
GJYH4ZE54ZUtlpW4NJZkiZUIqRNoOZBv2ZYEwZZ0KZZc2ZVjZJeyxJd0aZZw CUZ+yUqDSZaA
GZhaVJimpJhaeZhn2UWMCUqRGUyO+ZhXNJmahJm7VJmWGUWaGUifWUuciRNx CZN56Uuh2Zen
OROluVjWeJdSGZOwGYa0iRStiYlzCZup+Uqj2ZlusZt1BJyp1Ju+yRbC+UbH OUrESZpOlJxp
5JydtJzM+ZtqKZrVeZfSOZ3G/nmdvMmdbZmdN3Gbc7Saa+mdhkmeNiGenweW YQmdmYmeNaGe
gOhTHNVA3fmEbjmbGAGe2pkWqVJMcKGf/IifeCmgoGef8bkW3gKgCDqcjQVP Ddqe8JmeCmpM
jgigFpqhGGqhBjopGgpPH3qhIMqhHVqTEcqaarGgEFqiW6lmK8qiuVmXVSGf oaRQB3Wikvli
NwqjMRqgVEGjr0igPsqjMiqkBUqkvTigUgGk1TihhGmeEtqjU4kW7imYUNqY TtqfC5mli3ml
V8mfPcGkMVGlkOmllMml4akZZvqe7FmiYBqmRfmOSHqkaPqldZqmWyql59mm HfqmcJqnrwmj
ZOpH/n76pxa5ppc0qHtUqDwhpnmEqKAJqdapp7aZjXx6ppcqoIxqqHclqYvq qfcZqDN6qJm6
maD6pJSaFI6aEopKRa0anHe6E6vqjaV6lk95q8L3qiiBq7eqpzjaqDhZq6Q5 TgE1hrl6qjQB
UPakhMeaqkoxqyWhqxsBUrBRVTTYrLL5o8TKUBGAUUSIrbW5FdCaS8h6ElE1 VS5lrVQmWANw
VEk1Tu4KBODqrLY5TiolVUH1Uu7kWtCVVVsFr0glr74aFgc1rh4hrRrhWHwV WQIyWfTGroS1
YxFLBs76q7I6TmPVXQy7VunUVtT2WjmWWRIrshQrqnL6FfxksJtUriZx/lvI pVvLtWzsKmnS
VQYVi7LHlVvKhVrMNWkf268+W7MDS7AZGJVGCRX7hWGkt2HSJV5JhWA9kF4h 1l7vRWLz5WAQ
dk4PZgY36xVJm3FMi3UC9rQiFrUGhmBVG19Xe2IpprU9wLUmG5tgAaJGe7JP sWZtVi5v9m1V
lmNzpmVcdmfjlGdhxnaIZWaHO69xq60DEGNsJmV7G7Rx5rdYBrh25mVGtmeh 5meJO7Re62oq
yxEIi3iZFmtnxWmSG3Nie2uONm9XlWrnlGqKG65Z8WoZh7o0u3SrO2qt63Fv xXN+Owazq6Rc
gaGOuI9JuhTD5m7bFm98q7sPG2Tk5rtEdW71/gZkw5u8VrG87wZv3SZv1ItO 9ua6S1a92Ou5
c3uhyJuMSMtypqtxA/dyHUdvM6dwIndzObdlJ6e/nLi4dqsV9PRv7+tyHAZz tSZzQgBySXW/
JKdzYtYDmGVy/Uu7xOu1AGp4seoS9CR0dacBd2dTeQe9fHd2fkd1gNd29AFp ZmKz/iu34kp3
HfzB8BrCqktkgtd3aWfCbCd4b9cDLEzBR3u3vOqUdsSyJUFPmMdXpveD2cu+ L5x4o5d5jnd6
14q+d0usy/qtRSys4bl7EyR7vscBtaeDTVzBWGF8X9x7syfGTGzFTkGtDcWs W5ytR0FP0Wd+
00fGXdsVdqx90od+/nrcwt8yFeear+rKtzPbrn4Wr2g5uvQoh2UcxACsk3Co vaqKsXsFWX7V
seIGspx1VRM7xxncEvlYj3tcvJRsyS0aFS6rs7vVs7n7XBkVcRz2wyjhyP1o yoLMlDjrk//r
xG98YWALXhzmtORVtlJ7YCKWtgu2tjS7YG8rylYUQEZRypB8s9TMyqkMzNzM FHgLuXAmZ5Vb
Z12GZ5n7wMKFTmXWyCSictk8lds8oBUyTO98xb7swqpcx4MGa6SHu/PLbD3M u6XWbG8lu6Jc
zwGK0EFhzW0IrgqdMGRTu/Esyd2svO3Wvc6bugf8seMbvtR2btTYJneDBWcg Plkn0oWC/tKN
0iazYyBckAXN86xDnJQOgdIkbdK/o9JsYjcC8QUsvSMvHdMzOtNI6cZNEcAY N8DxW8Dze3AJ
THMMjHO0LMG3SBJaQDVbcB5owAVsADm7g9XnMT4o0jvQEgApIzCIYtH37Dhg DQBb3dVNc9UA
kNVvcispAgBlfdafItFrzcv0erEDwMF1J8PtSsMbbcNOh8M1pcNXZz22HBLW czdpkAVbACn/
YiZ3UzEJ0hk7AgZgUDrPOtFlg9kAMNmVDTakrdlXwNkG4tmgPaOijc8VHdpQ THpLHMgjUSVq
ANOWTTI6s9lNgyCvrc99HdG7nQW93TdgUzKsLRDCfRUMjYaR/uzX2ux6aYx8 bIzbIhE6AHAG
XPDSe43Xw8I0nb0FAZArJfLQcBnbjjPeAuHd4O0m3F0xYGDe6M00sF3cg/zX 6z0Ad8x9bUwS
XpA+XaAFayAQYKAF4TPgg1I9vu0FW4AGel0ed6PWL2kQDK4mBo7gCk47Ge7g EwPhEj4wPA3d
7E3dQEzbFw5LRkwS0W2sp/zEKy7bZmzhM3lKdFzNJ16WLf4SLy7Hu1yk1T3j o9HjIvHjWhzk
+83HO77kKX7J+r2yXJyeTZ6fozysUS7kT16vWc4gUx6fVa7l/F0USB7gW47i 9kzkpGTkIVHm
2p3PNG7iXU6nlXzURD2U0qzkCx3m/kN65V085xA95liu5h+ByyRI6E4u6EPh 5lWs54E+5Dde
5F+erHxO545u4+VY5zWu4pG+5pPOmpX+6H5O5YC+qTLB6C/Izp9+6qFu6G3e 6qOeEqiugqqe
42QO66seprh+6T4x6yVY67G+q3culDEOwMPuhUbtzaG+n2yemM3+qYpO6ogu 5baum8+OR6Ye
E74OgsAe7aha7Uia7V257NposYl67bDq7ZQO6Mye69GJ7nIk7j5O7nxq7pHq 7qgZ7OZK7+Ce
6ETq6s6u7qDO7uU+p30u8FiK8NrO71xp74QK78ip7y3L8MXOowB/mRJ/xBTP 66Ie7hDPRvKu
wcfehXl+/ub6efGumvGY2u/f+fHPqfL5ju/nLvPlqfAGivJxGucGb+WavvMm v8pzivPNCfOm
SvMPb/SqafOa6vLbifSh+vM+D/RKP/MsL6hEX/NVH6VZ76ZXP6lbb6dO/+1Q H/U8HvbxzvR7
2fVJ//Urr/bY7vZiP/X3zvZLL/fWbvYRj/fKSfdBfyz/7vdkL+ZjH/iWbvfp jvYBD/d73+4e
z/iEf/Ac3/fG8feT//gdr/hzX/lcL7qWLzy/Qfifjx8OD5kIGvp9ap+mH/Q4 mvp9ufqjH+8n
SkmyP/uzzxi0f/u4nxe2n/u83/t7YfnAH/zCP/zEX/zGf/zIn/zKv/zM3/zO HP/80B/90j/9
1F/91n/92J/92r/93N/93s8UAQEAOw==
Content-Type: application/x-zip-compressed;
name="mindmap-gmf-modified.zip"
filename="mindmap-gmf-modified.zip"
UEsDBBQACAAIAOlZAzc/HFeoowAAACwBAAArAAAAb3JnLmVjbGlwc2UuZ21m LmV4YW1wbGVz
Lm1pbmRtYXAvLmNsYXNzcGF0aJWPywrCMBBF1/YrQvamunPRByIVdFGl1LXU ZGijcRLzEP17
LVJ0o+Bu7uVwLpPkt7MiV7BOakzplE0oAeRaSGxTuquX4xnNsyjhqnHONL7L otE7AHp7JyeJ
IqXOckr68nXGX0GucQC1bRlwJY0DdhSeqSYg757TbF0V+8WmrOersqj+lxkB jGsLzMIlSAti
q0Ir0f0w6eBN8IPsILFnk/jj8QdQSwcIPxxXqKMAAAAsAQAAUEsDBBQACAAI AOlZAzeEgydn
7QAAAJkCAAApAAAAb3JnLmVjbGlwc2UuZ21mLmV4YW1wbGVzLm1pbmRtYXAv LnByb2plY3S9
ksFuAiEQhs/1KczehfbWA65J23izaaI+AIWRYhggwBof32F3NdXUpEmT3v5/ +IdvMiAWR3TT
A6Rsg583T+yxmYJXQVtv5s12s5w9N4t2ImIKe1DlDbJKNhYKt5MH4SVCG5Jh oJyNGZjBHYOj
xOggM7Reo4yC9zGKq4AIvrSCnxUVx5tz1fy7+eys0+sIiszoXqlNel0LP8D3 ujAVEgl5kH0e
0gVODTKZrlLzYPmVF/yW8Btk1MBW0tsd5PLyb8S1+gKUf+aNhXHFhCpdgiE6 6PvbHc4rus/d
aamzfrjOWP9+mz9Lwl1e/epznQBQSwcIhIMnZ+0AAACZAgAAUEsDBBQACAAI AOlZAzcm0VNW
hwAAAOEAAAAxAAAAb3JnLmVjbGlwc2UuZ21mLmV4YW1wbGVzLm1pbmRtYXAv YnVpbGQucHJv
cGVydGllc3WOsQoCMRBE+/2KwF2pmx84BQuFK87K0kaT5YzkbpdNAvr3RitF ne7Ng2Ea0zmW
u4bxktfQmM6+Yy3a3rcA5zBjmF0snpJZGVwcwXxmYk/RfvfD9rBZ9vvdDyWx jHX3NsW/TpSF
NAdKcD1pQseThEjI6kmfRyBxUUeIFZI6C1yylPzietrCA1BLBwgm0VNWhwAA AOEAAABQSwME
FAAIAAgA6VkDN7FRVZXxAAAAlAIAADIAAABvcmcuZWNsaXBzZS5nbWYuZXhh bXBsZXMubWlu
ZG1hcC9wbHVnaW4ucHJvcGVydGllc61QQW6DMBC884pREm4VuUdJpUgQKVKB iPABF2/AqrEt
IKH5fRfTSjn2gC9ez+7MjmeNfWXds1N1M7wHa+y3r08GNme5Cfg+LHBYprSo rCRIepC2jrod
g0BskeUlqkaYmjA0BNdN3UFRj08aRiLDsOqhlSEII6chT12FYYgki5GfUBbH 7PpxLJMYlyK/
JEV5Tq7ggZXnRZ6Qii9WgKHxb8kTRrT0BuEcTcrWO5hKe/PlTel56WzQy0y4 /wqP3/vZ9Ktm
tFRoy4X/n6QWc+30vVYm42BxQKqMbIVDyoHpgCN6KEndb3Mcx4i+Res0Rbar gx9QSwcIsVFV
lfEAAACUAgAAUEsDBBQACAAIAOlZAzeRG2lGFwEAAEECAAArAAAAb3JnLmVj bGlwc2UuZ21m
LmV4YW1wbGVzLm1pbmRtYXAvcGx1Z2luLnhtbJWRzWrEIBSF93kKK7ONtnRT ikl2A7MYKKVd
FzG3jox/qGkyb1+dSTIDLZS60aPn3nM/ZN1kNPqCEJWzDX4g9xiBFa5XVjb4 /W1bP+GurVgH
Qisf4Wp9zNb8UrG7uq4QE86fgpKH1GZBb1SFNrt+U9V18Xo9SGXLJWIwJbCl F/JO2dRgFySZ
YwiYz3x2AYgEC4En6D88F0cuAeeEvNgs0VnlNQSFGoQPKflnSsdxJDBx4zWQ 3JgaZXvDPV7t
QvMYS8FtrCyxl6pI5hKyv+wvc/zSIA+2dz3o0sOUw5JRRj5fYETbksfoyvov 9NWW0UOEcCUv
aiVJJw8N/h2w+RtvSEovjK8Q3RAEbLlILpx22VkgfjAwuvzkN1BLBwiRG2lG FwEAAEECAABQ
SwMEFAAIAAgA6VkDNzQFoS/tAAAAEwIAADUAAABvcmcuZWNsaXBzZS5nbWYu ZXhhbXBsZXMu
bWluZG1hcC9NRVRBLUlORi9NQU5JRkVTVC5NRo2Ry07DQAxF9/MVs2HXjKDL VN2AumtRRSX2
buIGi3nh8VRJv54moQ8QiC6te3x1LK/A0w6TFK/IiYIv9YO5V4/Z1xaL1Vd4 zqan5Bkclvou
2tyQ74dTsOncNliqRiBwY7CyFBOaxu0MtuCixWQc+dpBnOlEvrEox/K5cD7X XNtcfJ4spLQG
eSu1uZC+Dty7cNhTjXxtswwVWDqADF2jrVq0MbAUa6jeoblBcqL+RQwdx1u4 LGTVC35kYixG
ye8CVWA0nL2Qwx+F2Bf2+WxPibZkSbpyzojDPX/BpnX064JajGixhEO3EWAp 9fCCT1BLBwg0
BaEv7QAAABMCAABQSwMEFAAIAAgA6VkDN071T9GOBQAAbEEAADQAAABvcmcu ZWNsaXBzZS5n
bWYuZXhhbXBsZXMubWluZG1hcC9tb2RlbC9taW5kbWFwLmVjb3Jl7VxZb9s4 EH4v0P8gKM+x
cuwCCyNu0U0UrIH4gO203X2jJTrhRiK1JJXY/75DHbRk+XYjVV7nJag0GnK+ bzgHyfTm89T3
jFfMBWG0ZV42LkwDU4e5hD61zMfR/fkf5udPHz/cYIdx3LT7yHlBT9iY+qSp v7qCrz5+MOAH
lFHRhJct81nKoGlZb29vDeY/NRh/sr532mYqIvIib9eRxNXFxSWIPQydZ+yj c0KFRNTBOe3R
THIfY8cjgcCRBuxPlJYry1ZipkGRD8I+oa6PgkQPFY+Ddl7DFPmBF2tIZUGs z/GETOeff1Lf
3+BbDwlBJgTsN8CQppwFMEaCUPQyHfeOOaGPqRwwJuOv1fdfKGUSScBOGIKF 3JmbY0U2xPZE
tkRarVASz7KnElMXux0s0R2SKFUIKl14RDxhvOBZy1RDm8Yr8kLQa1orpF7A Ji3lkyl2teiN
lZ2invZQ8tCRIUfePUbwGy+x/ouUnIxDmUFeaTZCSv5TA02QJ+BdGASY/8lC 6rbM80sznaFh
4FFWm7JSPTC2IvvMsuxkZh0U2FTyWQain4/6WkSxhxXx34jnOoi7GRrW0tXM M7GKC2sJGTvx
NMATzLFaWglP085Ddxj7e0c5/5YMRd6+PT0wNQgsIxb/1izNtUuOqCAAXMsE K2B2DqOAFfUz
j8Ag5r3iPmdTgkXqU5UxjbTLb8lxHMaCCOsqmB624/D6wJxorBPZ70k28CHy cJdPuV9Y0Vdm
yi0w1dGZUf28Mg/m4+GUgQJLLubkFbv1IS2JxdtSptBaLyoC5Mzlz84k4k9Y dvWbvRmGN5ni
Yudyo5PWKGVXGZ0cZJup6FFv9jPKjYKncyi0Riwgjtgc1cDzI9EjdOEMDOVH G469eIitKBik
0s8kOEYmNBhVEBHDsS0RsfRRkpAC8e4kFBogSaSHCw3QXn3OtWqNlRywFRdV NSqEYhzKXwTy
mWPkZqPMlqmh8N2yhWHtmbZtGvrpDPucME7krJrUrUffkI4fiMSAvEgm/Y89 6M0/WXzb69p6
gMvVYqNvPS12tUbsr4E913e9WvC+9zjQcr+tkWt/nev7fW8S02W7SGRv/C92 pGmk21eRkm4k
AuzplQ3sNRzm+4w2FH0N5RMwS8l4tZ7QTOa/qqAbI4Fjs3dwoQMr29w6rASd 3Ay2q3X9YPOy
2iuneGiMvVNOSXAoP6ekhdJiI1Ef5BILKkjHUatcZ+gSCyqoJKOYu3zRLzRS UXieW+PiCQo9
+VUZkKTClnln9+3und29/VspFVhKNNa7PjWiQ5la4oZLtnIrQF55Zhpl0diu ksv4wcqCqd29
fXi8s4fbFHX29xHoGxYKu8Prq0VDa1pnLZqxc721C+EH111JpqgIqWKeKqHe KiQt5T3Q8+3S
OEJk7gUBE7A2Mk8tFMrnud/VILxq08vPd9iHOZ2q3ASH8vGPJ/G/hz/6RwWF 8s6nGAsBRz20
5juf9QFcHnhwcWDKS+J3JQkvGfuXOEoDR/J3yXhtkD/Cs4MYhvLXf1IpLDug yXCQW/KpgKWT
dn0WfWJu+VkO8JNgWCHTFRx9/5QXqa8PFRqR8skQYdLSvRsXtSs/UkiqTYdR cK8wJUbjV9wF
ronI9XGnyuLsmLmzUzcRw1A++qqK6Z8y3ZLarn9wtjs0wGbPP0qOrdHQv0S3 sdcW29E1GxXu
trkgn9wGf6/ocO8xJM3lp1EXmYFqfBqlUaxgu5S6p+ie2zdNADntnB71zmmx o8cABJW3TP1J
37suiCSg1TheLWJVAVvp5bFNNAHe+qLZ8hwS3UmsNRuLF+nK227c9674ih3I ZA+/PtBXeUVc
SMRPnVl+10tDUsHtvnC88+FbjZDV1lW7o7j8Ru8B1zH1vYvFNtE6THt832+D 9gIkN1b+f0yA
Rz8AUEsHCE71T9GOBQAAbEEAAFBLAwQUAAgACADpWQM3F946KasDAAC3GgAA NwAAAG9yZy5l
Y2xpcHNlLmdtZi5leGFtcGxlcy5taW5kbWFwL21vZGVsL21pbmRtYXAuZ2Vu bW9kZWzNWdGO
4jYUfV9p/yFKn4un81QhmFUFmRYJGARMO+2bSS7BbRxHtrMDf99rJwECG2Z2 8QA8keT6nOPr
Y1876XxZ88T7ClIxkXb9X1p3vgdpKCKWxl3/ef7486/+l4fPnzoxpFxEkLR/ h3Rk/nhrztrb
hvfY8PMnD3+Il6o2Puz6K62zNiGvr68tweOWkDF5GQ38MgRCIaEWBGHCMgU2 EPiS3N/d3ZPA
hNWwKylvt620+p5t0GcSQi3kpusTjNu2ifmyBWvKswRUi7M04jQjSoYlq207 SfKYpYN+13+r
ZUk2phx7N6ruMZ4JqUEeIqDWVvWsZVPiPxjazhL/srjQ/1BCFwEdUntmozEn Exr+R2NQXiZh
ydZ73AuqoHzaLN/3JCiRyxBjXkbDsu+eFzGVCUUXCUyk+MoikI+0TKKWOaBd jKYtfE3pT6To
TCEwSHOuPL3JYEaXYK56gmdUM8Tu+kuaqArNPDuCIhPJhGR6U2HuUIcMs4ft d63LO80g5J9g
+uQTJ1BP48AR0vwvV5rmf0wDV6oen56nrqAGf+5UdUjlCocumUKCwSJVK5bN EeUstxyCkX4w
Ccb9YNz7+7yEHAEPxr3hcz+YOYYNXuaod3Y65X2qqYkuGarL5mF8WvyLC+kO 9HswDiV+A6uX
UKUqJHtxDNMXYc4h1VMhdH2IH4HqXNp1UGQgNS5UY5GiaVKh2XKz9VAoMRB6 K5ZEdV+VAF3f
XrWD37SWbJFr8E6JIJytIToYPudaprAEiQX6DS3r0XA8m9g6MMIKcCOiZoNZ uAJOhyK0Fniv
rtBIQIKq4tSE7RWhH9TF9zJk50fpv+90pEn0tfqD3ERiX+YiY6G6Xl6tjmqC X1tGsZtplOFg
/hsezXQC1+2qXiFMtL+wKheG3gdscLaDHO6zkIQucLfekMx3LE9Vvme4n+6t BMPh/8G81mQV
Tro9XZrKGPQHGrzOZnZTTnxV5vMm0lloIaHgpiB85Gqx5cISyBpd7pIoxTPo jbi2VKTrBeoM
F83tone1ilvQE9yI80bPXDTFpSCa65WQH2iukicTSuMmv9Fe7phUfnBCONcz AxyzW1h7dmou
NWqWayGizWWYzOSYHPrknOEzi8f1Zrxhv0SdKIiiXJ48JDkjgjT66IlseU4V I2ck6IEQh8e8
MkrgAp3KqneSN1ECrKRLHHwKJoX7z5NF4Aq9x2rheo/xjnPQFerGNw4o5Zbo JgbjWGNxWDnQ
eDQ49kb1KcN8eCJHX57w7v9QSwcIF946KasDAAC3GgAAUEsDBBQACAAIAOlZ Azf3bfCiphIA
APbGAAA1AAAAb3JnLmVjbGlwc2UuZ21mLmV4YW1wbGVzLm1pbmRtYXAvbW9k ZWwvbWluZG1h
cC5nbWZnZW7tHWtz2zby+830P3DUmVbutKIedtokshvXUlLP2Y7Pdtpmbm4y sAhJuFAkS1J+
NNf/fguAD4AEKYoiY9mhJ6NIxGJ3sVgsdhcgMPz5bmFqN9j1iG3tt3qdbkvD 1sQ2iDXbb727
ev3DT62fD776x3C2mM6w9eINtsYG8W0XvmAXwRftbkFeRAj6gOCrf2jwB3gt 7wUU7rfmvu+8
0PXb29uOvZh1bHem/3F6LMN5MtztgIH1u90ewJ5cTuZ4gX4glucja4Klqpwz qTaemMTxMEMB
xRTNMx04PrUNbLYOaO0hWkI7vAOOaThBPp7ZLsEef0D/iLHfAgwRNsDUwXdo 4ZjY6yyIZSyQ
04rBLbTA+61T/lw7ZOiFYgN7E5c4PhNTJpSD/Pl+S9dfcfb0VzFjkWTpHy+W IN0l5aurpR71
WnrYTPYgyfLRPTRwornYRJQ7b04cDeQ9+ZjF/dWceJwD7ZaYJhT6eOJrHvGX HIN2O8culjGa
xProafZU8+dY84Cw5t87WJva7kJD2gR4wJ2WLHz2UHi2wJ6HZsDxIYfXbpEH CJaWoRFLouZp
19i/xdjS/Ftbu7IdaB828QJbvidSCaR7ny3ygxCYyS6uqWnXtgH1PGxOOxHp Hw6gPYem2XZ7
32tuX/ufprm9jo/cGfa1fXjS8eylO8EaAp5pCRUBe86+EdAtIMt+8zrfmP7L AwrJ6+1EXQkM
cRCRJRhFLyii/VY8XEf2AhFrzBt/xarEjQIsgVhENJo2d/F0vxXoeAcwLejI +VrXg0f6Kai+
wIrOeQnVTGd6lqt0Z2G3nMHPLEUbMcXyOCRoFfHn9tIHdaE4NA9aIiuMZfsU 0pJRxmoDuirr
guYBQtPQ5ugGq9FuriEUaccjf+H2jnagdbelB5kgivXhUBeM5dAgaOaiRVjv hnhLZB6P9ls/
Po/khgH8HLn+kYk874wbRuSMg6cRGPHx4hIMu+WTCSu0wRDdy5WOlTARCuhy NvR+I/j2NZrA
hJSoLxRElSbIsi0yQWYW0aM0QMz0xLbOXfuGGNg9dwmogQ+9fGLfRhA3yCQG 40oNF4o4kOTF
0roiC8w4iDuRd2Cno/N/jrmcEUtPzkfuEuQC+hWKQWfdrIc/xY6PQEacbDwr BAp0BXoX009p
4in2EcNF4YQRQvv6V2w62E33Nn8eU7qBzgDly6HymsyWLv6NwwlUpuz5v0DV yJRgQyAlisRw
0W3f6Lx2MaYTywm6F6kbbCAFzR8nR81aNm84mRPTOAMIocvioUD9loSIEsPh CsghIzUiCowJ
XnPFsFg1MDgS1dhYNTp4zbwBAhjshQOtYiaWGc5A08FyCiUdUURQ7MwpQirT HMJv1HAicQDz
8ZG9AOEYacbFUollywflAD82h2HR2OcO3jqHL224aLeVo3eN8ZsxgmMFTQxi 1TBWkDu2rABf
ejCDuGNCl6DBH+/PbB/zsZ+G+4XNo998fXf4Uv/uO/a/9p32asZDEGwET3T2 v7O8pt4sq6gl
cWv4zseWAX5o2mhcgKuBrJkZgn5i6MKP5xFp9iNNP3isxz8cl9xAsZbV6QHd Jelw4+Z1fgfl
PkHX2NSmnImYfyor/uylJjFWmjsup6SEwEn5FAOpPnzw/jvgJP2CJh9nLvW+ j2zTdttXvx5f
fvjl8OifrPrOywSWcFhaPh1KbbH87wqEfGMTQ0vS+JSQVI5UwQu38G2Zvgqb koOciusKVK/9
zZ9L239JnfpOp3PAf+0IDDLZIsNo5yDbefmNov//Tj+sRHmvbdvEyNIW9+88 fGKD4T2ybdcg
FhR6ILQpMj1cATWbevrYiOgt09QUqulif+lmMJcpnI34Y3oG3akg2M7hPc16 lkAVlQt0c3kD
UMY6QZiQrZ/Z3ZRn1JRNFL6uNvwenR8n4ChayJRa5d36ncC98DrMVmmRrVIM +zR421qa5vda
f68bfPSed8VRKEVjyPddcr30seQOKCbIS//exIcRdEsGn5I7bMQmdr/lu0tx 2qfhJv5zSVxs
nDPf4njkHaRnNQjjUlCFUSjVIQ/jUA88g/gJ8zjAx4wCS/4UfJGUy1QkaGVO iSyGwHOjPhB1
cV7DFAAKVSYa1sHZY45eggB19WtAPdQVwhmadIRJconDil05rMgJLC6X1/8F g6WILwpHGAGK
lYFGsVAjwKaOOLQwIXM8oWkfpupiD6zwtT+jt612fhWjG6QO7Tn0PDKzsKFy gTVqRn3scinl
mtSUbSgSCxc05nLjYo1c0b5gLDAUp1ElsdeCYR4AJjqs8FjXPa44MpvKkaPz oRMlsOIQPS9o
V2Xcjigcaxrr/owIv18kwqfDZ7Mov5JInyIpH+3T2vkRf9HwnWLaNIRn3GwS xos2lOnMONv6
fCFxfqim5WL9rKRd1aaq8X6CrqrDA+Lmlhqmiv0fNeIc7+dUOQkVnYLS/hGd ZWFgt5J9oJ6a
1ugGna7wSG1K8J8zF/m2c4Jv+AyjzCH3VueQqWdZanKhFTedVyiOUlMKrVhJ /ri73gRE6W4w
9zC2pWnnC5okQk2rORd8QWNdbDBy1WeD09hz88EcOkoLb0VCmPFeVy44LZ/c bHCYCD6yXUA/
ghZYdBOQ105mVIJ2zbANVte970SgbYh6TpFD7WV7pzM69+2T83a/u8NIfq/l le6ICeSQk9e2
i1Mp6ddvL8Zbn5JO9Gtl2egE3tKJ6ASeJgfd5KC3JQedUM2V6eekCX2AzDM1 SWtlnvvd8GPv
82SeY0vaZJ6V26WqCrtggtNd2/b5FrdKA69M1KUSz/2ViedwXJVMOofVN084 h5iaZLPwp0w2
J2zhl5lnZuszbM/o+jlmKYpfJ7RfkTy+wHzDb5noPqy7YYAfoikT44d1N00a h3jKh+0RJ19o
5C4qUh3Bu4nu7SXjer/1x/sPJ4fv3767ygzvA2ZqCO0lzOW3eVUSRku8qEPo wyhmPWECPEUW
mmE3K3T+4z0Ha++kgtgo9iWm2WaR0I5M4O3SN4mFlWUnUPA7Mfx5u5soOQfF xy74Wpd05/pm
Ef1ubkT/LBHRhxycojuyWC4ejj6xHpQ+I7wBum3MdihkODbZT22OkdFVBEUy mMQ2q6LK+/w6
Phx11YmfqE5y+yKvk9y/GIGX7I1+qjeE3ApDrkqlKAUFU979zLbYWyU5ggrA QkExaErt3CaW
v1KROZSyJYO8dvaey0r8mcj2d2siO3i+jWQfSMgPQ3bw7EGEvPvTg5DdG9Ql 5Fz7tNuviWzv
QRqbS7W2nu39+CB6nE+2tlGbK+MHolqXPV4h4ochm5xrmV/DaSt8oV/ejt5n +EJRnaQvxOso
3uUQnBdWebvWgWgqr1kGeuhloBoXT2K/vpLVkzqYW/ulgkE3/Njbq4+52Aps oeRic1OJ5Mot
io3wFC1NFudlLo3NMZnN/f3Ws+4Xvx4WJrnqWhIL0NewIqbAXHRBTLVXfHxH dxfyzDRf6Mhc
QhusWkILhcpW0RaImOWW0lJoNl5SS2EUFwUe+eJZ9ublGrcvV2I0qjcbKsNR wWqdXIsSiDbl
fur+rf37U+/v/ySApJ27FOiFBlBVrvuFOp1e+qsMM6ZDpapVRXaAkmo1cVBs o/Dl8pqdjuOV
3jEcYahi63CELGN9MW8bblQ36zUQF9PTeSx/Vf0LGW4b1gXHxqzUuuClgycE 7NRfDA1bHNyq
tzhoXpquQx3ZlgXxC/A4vnvML3TkizKwgzBk1ZsWRANTZicSfS3OL7avh40k EDcI3vNd8M58
SWbB8rBlyGzEp5sFZ5DZjmN7YCcAUiKZjR7MGjVZRezXyt0Q8dFu5XZExPU3 3hURo1rPcok1
17dbYu0nZLXW3s0gK0LNryOMkDfHBl0kf+tg69B1hUO+ItDymxYU6JU7F9Y3 rDXsalAwq8iC
iRsL2DbTtiID+iYM50+Oz8YfRoeXv+4kuWQfdLM6O5NuhCe2yzq+zUdX6vGO cjl704Sj8q0Q
0Hh0beKYuJbFU0o6Gcu1tPcEdMY0f3VXBpdWxMVMpDFdlawTHj7ZmZjalRXT cLn0R2yIakuB
BCRqSIEoMTPQ4FXoSzDgdGLLcgrCk0tFOVBRv3gx/uNqfDa6zEZ9bBGfOao4 gV2VXQkaeYn/
FKolokASl6RitRycvyFzianX3EpW4s3MbtqBXGE4VfXE2mqk+7LPzlDrYuM+ S7O/DWagb+tq
ppnaDZzTzsClTatO2oUtPyYk9lRpTX4yakUEOLJNt+Pvrs4lxjRZPqZsLjGB poJcYgJjk0vc
OJeYtcqhYJFVfzudgnOVuc6hafdUyZKD9AvKWFaaDcw1fsUygoUj6UHxSLq/ aSjdrzCW7pcP
pvubRdP9JxROK5KAIvxCjLblgxWYTnV6+iuBVBNXN3F1E1c3cbVqrDdx9WeO q4/Pjk7ejcZP
MrCO2va0I2tiTcylgZvQertD6721Q2uVJ10mtl7tUK8dXPeb6LqJrpvouqLo erd4dD3YNLoe
VBhdD8pH14PNoutBE1030XUTXTfRdRNda010vbXR9Wh8Pj4bjc+O3j/F+Fpo 3dOOsA3sNGvX
Wx9gP1s7wFY502UC7NU+9doB9qAJsJsAuwmwKwqw9/IDbH70/qbbwdNYKrlj pfzW8HT9Ei+2
pHA8oci71J0mn3mzeJpo9cfcZdHY3gA8i+OsY/GaOLqJo7c+jk4rdU3RtJ8i VH1cvZLGpiFK
WlpBoKK6zXHTcEVBjKNMEVN4LglHRbxsRuWv7BV78Ta4eDxGVvoF3BSmKl7E TSEtfalPCtOK
W36iO5ESd/xEz6Ubfnzim9E0KxARW4ux4V1xOHbcqSQJI5GUl96ylkiZxAvO ZQ3xbIHvlDww
uLl4Z6MZvbl4p7l4p7l4J1+QzcU7j+LEtebinebinW2JzYa66DWv4UkXuk1Z uAB4Q3c6G10l
uUAl5vIXMCvRbexd97K86wQhmVkYHyYCXVG42Gu535Kb/9T96/hW9+q96yTu 8rdfPIxrrbrx
vlr/OimhXO9acmyTJ+OyWURxMO72ObYqqVbm3aqQl3ZxVcgaP7fxc7fFz1Xp 50pnV2nUHsDj
XftU3b1u8NF7/nk83tjEPiWP10EmvXAvrkWb6EjiClwu5gJJgoHfE5c41CvZ b8meQuR7pa4t
BOIuWdkfVzB6xwB5n+iJ0P1jt1zKRRI3fF2aqZMKFkgoXM5kolWvnm+e3C/I uApYzbnko9bF
NvW212JdU9RYyX+vBv6jQ6CLcZ8BXkRpetLCDR9LBcYWXfvblrE1YnsTsTVJ lmeJK7MCEGMN
U71jMKihm8PjUgvynQGex3Udg+s4eNuyINcZ4Hlc92vgesxjt4JMq6HzeK7D DCiWw+tifzfb
Dgx1ec4dOuwKQxg/+BzNxDaqdhhfQlhsINc4lyqJKaVReqcjvkMLxwTzFC5I B9x2uPMmHgVv
sTTAKYfTRhxOSHswSw10c9MNRfhck1PkOBi5yEpYZc7uobrwI6G+mlCoP3w7 JtE2Jk/RkKOM
Ut4SsXQLmgJRKbij1kzRjnNVEW9EVLQFLXCXJna9Q8t44xJD0YwLVq4BgJaC 4K25kDBsQZMc
5M/ht0q5zlVFQaeERXpspGSrxJ4P9YAM/xUkNfkPmgu33eCHhW7IDMHvKLFO xXERYhRsHCsQ
LWjMQmYdh10jXmgzRgp9hq+5HrHsHRn59Lql6OWjzwpa6qJQTmb5FELnKgZi MyZPSZsJ35gV
HU/oFE3g0+N7oc5CjXtDizszMi3Zt2leCgg9Bo5GDX+51l76H4KXUZSNU5cl W8c3bVbWxLXU
Ny2PRBOJ9SEVLgktJNbEBiM101b2Ywh5ssX9uaKx6rJkd14Gd9RsZXeu0lgo n9mF+jOErLI/
izSut0V2pNfYkUx5PEY7UlV/PhE7ktOdj9+O9LfIjvQbO5Ipj8doR6rqzydi R3K68/HbkcEW
2ZFBY0cy5fEY7UhV/flE7EhOdz5+O7K7RXZkN5/hjGzcYzAixROJaUk8RgtS SU9uo/mosCM/
t+0Y6nICPdxs/M4xkI/DJLvj2g52/fvLOY7fDPXRdeEVRF79Cl0nlg9ResWs ErypDP9qpEdL
z7cXOSjtBSKW8JAd6EGXylzxZcgpMX35NCzlK9iA/zWDlHZVULDsvVjRXm26 s3qoc+D82nja
Cd8FUFSINtRdsRIQke+iSWzg6KaaoZ6Ailqq86ZGyzhUxIFOpfVlyMUHcmYv nodIsl5eDrUT
3zku9uj7edAxN8SIj5OiOskf5HfrOMJwbAG38IMKPa4TU1Bvw4DRnb7OU38V 3RGqKQ+1jN+j
Dr4njmNbr5ZwUJb+Sjxaq9OtClFPgahfqh05tdZrRylEqnYMSrUjp9Z67SiF iLUDLWHsgrLR
xWOmivRLuqDHv0QWXT1oYCDHg4KtoL7hA5tZ/v8DUEsHCPdt8KKmEgAA9sYA AFBLAwQUAAgA
CADpWQM31XAJqkoEAAAFGgAANwAAAG9yZy5lY2xpcHNlLmdtZi5leGFtcGxl cy5taW5kbWFw
L21vZGVsL21pbmRtYXAuZ21mZ3JhcGjtWU1z2zYQvWcm/0HDQ28R9WE7sSo6 ju0k9lRxO5Y7
TU8dCFxRGIMABwAjqb8+IClS/AAlU5Sml+pii1i8fYu32AWh8ceVTzs/QEjC mWP1uz2rAwxz
lzDPsf58/vLug/Xx6u2bsefPPYGCxegWsR9IdlY+GWXTBnra2zcd/dFoTI70 oGMtlApGtr1c
Lrvc97pcePb3bw9FO1m0Ww5js0Gv19e2kylegI/eESYVYhgKU1M+hfmAKQkk xCDaIAK6sL9G
ZgQjegdzwojSjK0OQz44lk+Y66PAuoqQx3PihQJk4qWzMdGTUEhVYlI10nQk Gal1oE2zJfqD
0zUlDO4Ac4Fih1v7BPb3ANgnIfjSslNkFyQWJFBcyLL1VBH8sn7kCr7E7lM2 ehbCKkQ0ebyd
ZqT1BFivo0fByhvu86B9zBB+8QQPmXvLKRf52WZHX29iQ6toKcDVqXLeKz32 BAAzDcxoqFH7
l71sjWI2eEGoK4DtpTFBM6AlzHK0j/r7JuKioYKVcqxfqPq12+1e5RiM7fyS 54XAIGVBvE4n
yRbHsu3rTeJ0e/Z1Tunoax7Pvk7D627DHtu5Ga9IlyeQPBT4ZMlSws8b8FBF me9Yc0RlcWhO
KDU9j+z/Iq7SW7lXSDuK1hpur8zf/57EhsUs8dGK+KE/Jf9CEcFdOdZZOdXc tWNdlPJMF4eW
CIGAOQid9i0wZGWqaaZh4qu3yWcaF03jRrkH5OY1iQogF1BbDJqUg7QgDMrB bEuCYSgpClGx
sIu8dhapQ3gN63kZhlJe52VeVQHNEsYiDkoi2qmKBykb9SGv0HyiT6LsDXfX /ytb4dVEWQV+
QJEyqTsYmtTtX7aGGJw1gBhengriCIG0hxhetA7k7ENriPNhk0CMu/5s0ACi 35qEEaHRSvTf
t9bDDNEoK4xxHAGhyf6oCaM9RKlWGDqB8SDa9Kj4zAOCp+FMRX9lmwNj+tJz yxnTZ0dS6js7
3B18zI1aArgxZqujboKz88RbdZU30q95DMTmEFva48nYPRBvoeLBvKo7W27T N6tKcalttuZW
e4w3q3iF/vOXquEJXqqeF0Ifhh/0Ro6jb5Nw1eXb5eJQwndILsCd6C25vWw4 3c42ectbRQC/
EabzdPLw+Pmfu0/T+8K4QsIDtb0xKcub/XuE9TiZgGYXhxK+QZLgk3GtoLfb GE9AY93kggQn
byP7ku0YyTS2N1bJN8bd8tVgXOsyv2lVMrQKux4iXrsKRuU2rh4hvYt51ENV LsWLmg0KzpbW
FFDWnStoO5p3PWY+L7RgLxVUk5Z7iVZSzpAuGe26/My8+AESygemjG5ut+Ov ETs1wZxSFEgy
o9pOifDV/qL6v8tnXXLQaC+bFI3acRPmadPd22E3vTnbRmYKcVBGDpVImjDo NWSQtdWaBDG3
XSNgIaeNkOZGkFoBhUjZBxxVpuRCdKe3ZBObPVXK+B4nY7v0S45+9hNQSwcI 1XAJqkoEAAAF
GgAAUEsDBBQACAAIAOlZAzeZu/jBSAYAADYqAAA1AAAAb3JnLmVjbGlwc2Uu Z21mLmV4YW1w
bGVzLm1pbmRtYXAvbW9kZWwvbWluZG1hcC5nbWZtYXDtWm1v2zYQ/l6g/4FQ gbUFVst2t2Hw
bLeB4wIBmqBo3KHDsA+KdLa5SqIq0nG6rv99R1KWSL06btKuRfzJpu6e4909 dzzJGj+7ikJy
CSmnLJ44g17fIRD7LKDxauK8Wbx48qvzbHr/3ngVLSMvGZ16SYKXyFVER7nW ELXu3yP4QbCY
j/DixFkLkYxcd7vd9li06rF05b49PbHluC23farEhv3+AGVfnvtriLwnNObC i32wVMFnKVjK
4Ic04aAQIFpKlKE7l2KWovajUXOlNX9xI+0oLysLxsIu7Z/dBUodw5LGVGCE nKkEGccsAD7V
eGOfxcKjcQSxeAGe2KSgL8jPOoXlxIloHOAuesrVB66LoXdTxsSCJdTnjrtD YtsYgtmahsF0
BzEOWITgpyC8eQjSRgHeBK9gc1TECL0LCLN8c1Mf0zYSHxIMf0aKzIGXhoIz LTTGAfVWqRep
6yZQeSsIh3LJ+oHay5kXgbEfxFlqO7wNw3LHjW2MsWs5VazLrDa6KC+OZika x1zKzDrN0czE
cQPPEy8EIcB9Lhd4r59/MTeUheYMqdEKasTFVPdl2lOITV2fRYmXCpn1iYP7 ULST5guiuM8N
IbkjM8ptzOyKN8IqSDtvNQzVzrextMUULnuBZaKNrpV87kFZMzc1tG1Lkdpc hbsKsJ6/XY66
fHPxN/ii7HADl9W1Mp8rMWjndK1/XbwelDfYwO3O4JVx6kguP/sRPVPevwC0 zY4i6EwaFRDx
KgUaSkHHq6scuoyeoM2Kya7SkJ+9yqNOEQIqXnnIhhTHgHIQtVOtRVT1qMQF 6ZLSrfGrtaL2
iZV7wYIPdQFrKS11va68KnHsLrFa77vKbFi34ZZS+4wQj92mzu3uyqpUqUZR Vao10zigVPP1
mjLNDV6zQ0uvZ4V2pbmarphnWV1IasLRGIrrhKF0LDe42upmvYu17lVcG7vF xHojwytwtkl9
uPnZ9XWGfHPjq6lwSWGbN7mP/U/kz4+DT39ZIlYflCIjgjKfNwTvnKrW5rUG 4R1MeRY+FAZv
yWj4f5upnx4+U+8ck+IFMVtrIaTxu7wWbDf3dnJfFwfV8SqnEm6jBdC4ZTjf XIjSXaP0QdZY
pX4LD1TqR/PXsARsR/kNeDNH9D0ArxrzsxjMGN7Lp1jdRk8d6/DP48BMljyZ Jw6HcEl+CMVv
U8KShHEcqlDOyFITMJIyz5Gdrpbu0kT8UJnga5oYKVAw5wn41AvpP0qiQCp2 35OhJBNioixw
aTSav13Mz47Py5An8pGBhIS0gVVGyzqH94Z80W7GtFjdq/f97oUbkN441SQ0 b72ml9itpMKl
IyFSerERUJqFukPvShyr7Zg+3o7nD+FKQBzwh1/W07DU8GtdHbsVvuSlXX/y Xe8euPG8amyj
hQflE6v2oLl2IOoPmoNnkcxOAf+lGvnTwxq5FWBUKFB0A73pZm5lojRe3crp YVe7l65gN7J+
A9385Gz28s3x/Jts5/nev/t+TmM/3OAYd9fQ7xr6zTX04V1D//4a+vH8Fc64 87PZH99iSzd2
/9039QCSuyH9rqffbE/v3/X0r9fT9aPr+s5+GJNEBfErcOqnA5/gVfY+Y3EM vnqz5Jb5VbWd
saz0T+3tPE6sGteMs4xbvMviWgrzzIsvPd4Z6GyhfN6fssBsrrV7rejsT/ZT 02JGnf1JlgfB
9HzsbQJa/O1Eg4nD0lX+phKi9ODKi5IQeG/n9E5Y/kswcU71KjlSQPlFvHXy U5oI9dZXSWbn
gm17Bzj7gMZ9khrJJP4a/HcGCyz0xZpyorDIloYhXhRIecKp2GgEsl0jj2xE xQTClkSsgXA0
TNR8t2RpRDzi4x6gZxiUgVGLxloEnHsr3PGRlidbjyPAJg4IjS1rnFyA2ALE RGwZUc++Ceic
855xRqeb0JpDjOkzh3syxT0eheGjdPAjSYfkX0LSQU+zHcfTdNjTZUc83Ie8 osdWXFffKOaS
Ale/tY5+aI6SWu+xedBrkda561ixOGPwQrd5c7yCuhcUuvktiaqt5+OCpks7 ec524VWv1TQQ
5lgRhGtJZAcVa7YRmHaJQTg6YCc+ZupfitiGLNKPnLNzSjgChgFZe5dgwnZl Wgr2OM5+jx6T
Kel/vUxU3h5ryYXxY+za737i0n9QSwcImbv4wUgGAAA2KgAAUEsDBBQACAAI AOlZAzfAYwfA
wgEAAEoMAAA2AAAAb3JnLmVjbGlwc2UuZ21mLmV4YW1wbGVzLm1pbmRtYXAv bW9kZWwvbWlu
ZG1hcC5nbWZ0b29s5Zffa9swEIDfC/0fhN4bpx2DYZz0Yd2GoRsjTWGvqnx1 xPQL6Twn//3O
duraWzYy2ocw+8Eg3Xen4zOW7Ox6azT7ASEqZxf8cjbnDKx0hbLlgt+vP168 49fL87OsNI/o
nE7XdFtBqSKGHdsalfa5V5R7fsboopI2phRc8A2iT5OkruuZM+XMhTL59jkf c3HM1W9a7Go+
vyT29k5uwIgLZSMKK2GUum9qlA5SKx+hrUHxps7bpOn6Bh6VVUi98mVTJPNC AyJ0BRlDhRoW
3ChbGOG/dsEOJbhZJz6htH5UKe488UMxn4KrPH+m9iW/uALiYJpGMiiPrbbB vHRaCx/VQ5OE
oepX/339Qx28DyCamk0nfIju21g7r+QoMGqkTQdmoWYduXxGs2iE1rl0dph+ qAmyLCqNuREl
8GRYQotQwgtKZEnr4HWVbAgojnPSoZORkiOYfxDDWn4CdlYQXRX6jejvbnr4 pMX8MnrJVner
7PcT2OpuwIMt6CDbHfWYBvhJP6jXkXNXPeDRR0EPT0BMbqWuxkf1n8X08ATE fNgivR/HeXli
J6ClO/lWoFsqbpT/fwwNR1my/1RufgSSQ38CFPgJUEsHCMBjB8DCAQAASgwA AFBLAwQUAAgA
CADpWQM3LFJQ6OgCAAB8DwAAMgAAAG9yZy5lY2xpcHNlLmdtZi5leGFtcGxl cy5taW5kbWFw
L21vZGVsL21pbmRtYXAueHNkzVdbb9owFH6v1P9g5X2k7V4mVNqHkmpILSAa tm5vJjmAp8TO
bKfAv58dG0gCiRJKtfahKsfn8p3v3Ojt/TqO0BtwQRjtOdedKwcBDVhI6KLn TP3HL9+c+7vL
i9u1CLsiWEKM0eUFUj8S8wXIIY5BJDiAnrOUMum67mq16sAax0kEHcYXbkxo GOPEMVYqGhVd
K2tlowAU9FdfM9Wbq6tr9/X56SXD5qC8CQSMl4AFEUmECQLxXFvfuJ5Wc1SS 2jZLFCKIgUpE
VXY9RyNBcpPoPw2w7rMSuXmLgGnwa19pWSutcmfQGPLgb6qYBSsrRYrxehQE KRc9J6UzltIQ
QgepcFupqovxyxmTPktIIMqgMmkG630BIMJSdcOB/8n2YUmSc4QRLOUBHAlj HnYhbt0j/GVR
sZSczFK55VwSGcHWX2ak3unCejJ+cpWqL6Ch8yNKqGJpi8MCLjng8IS89e/K tA9ssrHocpgD
147LDWR9inQmTZsV0xVEE2XpQyj3EhEhEZEQ+zsgmG6mk0G+WdyjPox4B7EO N0sSJlQUVW07
BZX57DrpoOU+S0oGVwIKFJUPWQvKQiXnEcOyqpDWmhPGidyUu2m8lddaC7XH ZR8Xo4b6c60Z
0LCNUQhznEYyNwNhyrNlUpVsy2Et7KY64BGeQXT2WbFtJqu65CSv5sI292qt lHbd5tak1XBc
w7DN8tyLaD/QuZPQkKHPtaDsaMSYtO6wPQk4lUvG6xgwV6J8S/4TCW2PqgH/ EVdV51RxUgfq
qdVZLRdlf7EbH5ttHdtNr7q6fyCQzdvH3gAm6pb4SUXKSGu5v85DwoyFm7YM 6OqP38HCvtmP
XJRsZ+ajq02lwgf6Hc2wKOIsNTJNYzC3Dr3hKFW6fW/sDfve8OHXwdfoQ+XB 8OFp2vdeGqh6
r77y+1Lq9BzWHA2F4a5mYfcl4nzZ//YmowbJjIZeAy3/ZxNf/veJ18Tb42g6 aaI2+OGdQrIV
Zv+pKsE/UEsHCCxSUOjoAgAAfA8AAFBLAwQUAAgACADpWQM3NWGNX7sDAADm EAAAVwAAAG9y
Zy5lY2xpcHNlLmdtZi5leGFtcGxlcy5taW5kbWFwL3NyYy9vcmcvZWNsaXBz ZS9nbWYvZXhh
bXBsZXMvbWluZG1hcC9Eb2N1bWVudFJvb3QuamF2Yd2X3W7bOBCFr+2nmFUK OAlqCehl1jay
QFMgQN0t6gDduwUtjRU2FKklKddGkXfvkJT8r7jZ+CK7AQJZFDlzhvwORSWX l124hEGqyqXm
+b0d+dtk6941vbnN3tA16ZYsfWA5gtJ5jKngpcE4L2YxLlhRCjRxwWVWsPL3 bpcXpdJ2qydS
z1QVhZJxZbmIb8ZP9cRUaYxv/px+w9Qe6+bjfUBmK40halIX91u/D1PMuexX BnU/Uyn0+77Q
P0BjqdGgtMxyJUHNwN4jFCpDAcrnhd4Ai9FgOnqv0qqgnvBFKTtIpqNBQg96 8SoHymw3g39W
+lx3FHemhFDfucxhFoQaYBrBVKUrDLMr378SfgDAQPDRj2vB5cPR6Y4bdU7c WY52zBeYgZPu
f3mtj4OEIr489l/jj58mnzXO+IJm2ifxTRDagBpPm29yO0nvsWAfVRrWyaec 3EJohqb9pFmb
0varGST1Eg2Sslnla4PHTRGPw/VzMJHLspn1/MJHCvThwhJQmI3RsvfMsmEk WYHDXg8eKMiw
V7hl7UV+RI4SNSOAgkWrqeApcGlRz1iKsJmjjmugthX86HacUToU5wsSk9J4 C8yZqLDxQ2OB
GqUGfWDWaj6tLILgxsY+iOPc3UGqSIC0AXEXaFkiHFiMVgvHN9Lq5WMI2+bi Tu0wd72t3YtM
Oo9til+bYFc1cCN7pFYg0299GBpEijUyIZZg7lUlMspMm0Kog0GGJtW89CS6 vnFca0xqIYe3
A/fkWvs5bpnidpUhwSkg+9snIdQ6a9Yqyf+pcBjNmDAYQUa43dFqDaOWHXm9 Rn6JIiiYXA4j
qyuMfNz6b5/hwC4KdHK+cpGlTGc9CGhfNUx3tqHuOKo766TQ7G/nF7TN/zq+ +5vUimQ3byt8
H3BJVOwy+43NWSyYzOMJrYzMHwMtTGYbGX952At5Prjf+jJeE8/tKk/I8/bb aBtsGvYkyGFJ
7lS4rnkmAsK43dWLQpVtD61m0nBS9gwzrIze2GBRCGmuSl9RmxluahvsFv88 Pxx6g/53LdFy
Hnh9rnhK6CmNsXts+j94w/Ars1XUUYfsz8KzTLL9nnCHGsal/w4g1xEWMsXT nFBW2+PBHK8J
4CNSNxA+M/4cfU7/Fyc8wexu8xsyariAPqlQD6P+u33wYK4EkSCwuc9Q8zlm zz/ANFSS1vDT
0Ocx3Z+dWaZJ9aemqQ3S5jCzu3VP0B5C8mSfMv8e5HZkSqZZUQt2aiV+fxk7 zcQcnrq54hms
8Qqp3CQ+QpJsffJ0fwJQSwcINWGNX7sDAADmEAAAUEsDBBQACAAIAOlZAzew ytVGbwMAAAgT
AABOAAAAb3JnLmVjbGlwc2UuZ21mLmV4YW1wbGVzLm1pbmRtYXAvc3JjL29y Zy9lY2xpcHNl
L2dtZi9leGFtcGxlcy9taW5kbWFwL01hcC5qYXZh1ZddT9swFIav219xVpAC aE3ut7Ri0rhA
GmKC3k9ucpp6OHbmOHwI8d93bCdtA+1oS4RGb1In9ntex8+xc6KTkz6cQJyo 4kHzbG7Grhm1
2vbW4Xl6SNeoX7DkhmUISmchJoIXJYZZPgvxnuWFwDLMuUxzVnzt93leKG1a PZF6JirPlQwr
w0V49oOXZnNXTJTG8Oxy+hsT2y2q7X4aDmGKGZfDqkQ9TFUCw6Gz/g00FhpL lIYZriSoGZg5
Qq5SFKCcEAQx5uN4Or5gRRxNx3FEzSBcKKNMn+u6Z4WLMCG1mRJC3XGZwQyZ qSgeMI1QVoWd
BqZfXP9KuAEAseDjx1PB5c2rry0kTwcZmiulzEQVPCnBmrVN8G3n9imOSHN/ dRTu7dTiTasb
6VJVOsFGum51IT3hRqCTdf86kZxrZOniBcxpgA/g7kPrwbN4cVSvbxwVDSKn Jb6eGeGFv/70
mWRtkJujYyfgOcV7QxBieoGGfWeGjQaS5TgKqF8ANzR8FKDAnCC/lOIhGLih GUrUjOjzeVpN
BU+AS4N6xhIEGlvrllBnFDz2ezalejT8ColjAsImyy0TFTaZ0yRLC8EmaSBR lGhcWiuUeTPU
KCmWoKwOnazNFttyHamTTxQr/VAgbLtaLuyTV9yU/L06Re31vE56ZNIm6epM nmfSv6YAvJQB
WRfI9GcnTDJkn9gQ4gHKuapESl5od/GTYpBimWheuK3H9g3D2nVUW1u/w9gn p9otwYYV2MW3
D/kGGH8ttx/isrcE067aaLDdeg1WHY4GRlc4cFr17yXkLbID8MzrhZXAD18B vWdJ77lDBFqb
5tExnRY7sL3cAd+Z7NUdpiPAW7v5h8F7a9cdwN3E2ovt1RXrCvFG8nXCl9Z3 BHxxDr874D5y
V3Cvfk98HLi3dd0F3HWsPeH2ozsDuzazBdgL2zuBXX8JLqBmxmg+rQx2gtvy O3NF+X8ia63B
FYgOyvqz+eiaHsrs+M18ebUWW5Xkfyqia8ZESeSkxMPkBW7Lcu4+F6HFMfSW tuJqMbeGLGNt
bKLKC0NTMrSRukazjqcuapHd8Nu85AXTLK/9WXMS7/ZZ++X817+mW8VTeAaI j7NjDq4tlt67
RHhRyXVz4mysBD/K4bPXBN5+Dq2prPcrJV7obDybNp8ua80Q408QRbYw7v8F UEsHCLDK1UZv
AwAACBMAAFBLAwQUAAgACADpWQM3qe408SECAACNCgAAWQAAAG9yZy5lY2xp cHNlLmdtZi5l
eGFtcGxlcy5taW5kbWFwL3NyYy9vcmcvZWNsaXBzZS9nbWYvZXhhbXBsZXMv bWluZG1hcC9N
aW5kbWFwRmFjdG9yeS5qYXZhvZZRjpswEIaf4RRTaaVtIwEHKI22ardSHnZV pbmAMQO4Bduy
TbtR1bvXBmcV4qAoacUT9vj3zHwzyHa2WsWwgpwKuVesbsx6mGaTuTPdbco7 +81iSegPUiMI
VadIWyY1pnVXpfhCOtmiTjvGy47I93HMOimUmSjRKalQmD5+IdQItbe6zCfx JkmgwJrxpNeo
klJQSJIhoV2DkBdrvyXPijVUQoGx5k6U2KZOtDEglfjJStRAgCokxi6jaUQ5 qJHQBrjgCSm0
UdYV0JZoDaI6cTQkgrwM0njQeBk8fRq/X8dCDftq5KhsOuVYwr5oGQXGDaqK UAS/w+MBvhgb
XcOhRPA7jlyNIl8JzXjdohHcutCGcOvBM1TjhnSQztUzmkWMprlGLtnoNLnN 87fdx+dPj/Dh
cinsH9CmUwcbZ2KcmbfvbOtfubZoesVd4zj+AlF8R9sfSzW26D7Hbv1Z0L5D bmArhMkza7n/
J1A1hLwpYlCkg9IJ/a93bLqa9YnIRQhP4oTNJ9Lj2NHVFFtsiWGC64YtgzMX MOA6FnrAY9MN
pFr0iuJClGGwM4Sj6JVunF5Ntmvs/nIRrjBUQHXxxBl9eOhxciOyvU+wW5A7 iBfAjzonm/A5
w/WMQjK6DN1ppJDLKQ5IbnxrxxY/by7EnengmcMnXDhfA3fJH15gupfufYUl FHu7wPR/uf49
9BWB5l4M/gEENZqpZUD7A1k2fRnEfwFQSwcIqe408SECAACNCgAAUEsDBBQA CAAIAOlZAzdz
Thk/1Q8AAL21AABZAAAAb3JnLmVjbGlwc2UuZ21mLmV4YW1wbGVzLm1pbmRt YXAvc3JjL29y
Zy9lY2xpcHNlL2dtZi9leGFtcGxlcy9taW5kbWFwL01pbmRtYXBQYWNrYWdl LmphdmHdXW1v
4zYS/pz8Cl6uQNqiG1/v/drsot7YvfUhjg1bAdpPhmIzia62ZUgKuoui//34 KpEUKYmURGXv
Ptw2tjycmWf48E3DGX399Tn4Glxv49OnJHp6zt6RP0fS3/ijL2a7L9C/o/NT uP0lfIIgTp6u
4HYfnVJ49XR4vIIfw8NpD9OrQ3TcHcLT9+fn0eEUJ5n0JMRPbuMEXk3HWZZE Dy8Z/L7mwZt9
mKZ1D03CLAw+nWqFTY8vh7pnltTEusdW8BEm8LhFD56PmB//8OYNeIBP0fHN SwqTN7t4C968
IT4NniG4fnjHZF+PHt6BxzgBGfr4EO/g/go/NMvANj5mYXRMQbjdwjSNk7R4 DmYhiB/+C7dZ
CrIYJPCUwBQeM9L0y560A8D1PnoHw+0z2GLHfXM9Qn8r3zzCMHtJEIiPoOZJ iPylfhEed/Rn
O+R0kCGv5w9cj5gaxBPwuCv54YcU1gfP1Zz++2O4zeLkE/kd8RL4BX3x9oIF 4QX54gkeYRJm
cEfj8+VhH21BdMxg8hhuIWCimOMB/JghtVLAUQa/nZ9h9M4YRjy+j+EBXpFP TaCeGc08k9U6
w3qdrVG4H58AvBvPp+AtuGCmXqDoMSqQnrAF96tZP5qsN0g01uU5y07fjUa/ /vorh+IKQTRq
rmJ/3lpvlqvpj7OfqlyWokf3MIuPCPY0C1GXxJGdFZp2qpoaULO7dTC+u8Gg 1sY1YpT9lSxg
hj+KjlH25VeqXUKHB9Eu54HL337YR8dfGrY2ibcvB0QSqzjOcFvgGh7e8Q8B /vR6hD75/ZKy
QCtXNerbWq1sf1/24R+fYCZK/fIrPXyIGcBkcXM/n94Fm9ViESDc/qR6nhOk 6HXsN8Tg8+gj
3GH+Jm67BCEfx8A+SrPuIg38ECc7NMAY9d5s5rOfphNL9X+a396twTKBj9FH MA9PgiXYuT7V
J6qw7r2Zj5fIkm9tLFnPwHr7DA8huI23YRbFxyGNWc8265sP0/l4c7u4GQez xR2y5882gSWB
weYBpJMmfKbhN7oIIn9RLUATggeYYIJNs+Rli6wJ99yslPPupZ5kuuAYSzN+ nI6D+9V0c7O4
v8Nd/a+9kCzCLudWgqN/RmUqdEOkSFgVf9p3VhwCIIhP0TatC3IPPIr039Dw CBbL2c3akkNX
cE/o5vWYMr0ljLO2RQWm8UuC1hmvx5D14n51M11bcmcQZXuoG5Q96BzMgtup jimr9H1OYLgD
eSA9o176WjAIPqym40kRUx9my7WOOJsPBJwRvdA/tkEl/b/1Qvoiejn7ix8O MQyoSnUzHohS
qwYGMWgsu/Bt+AD3/ruwqPFmczt+P721HA3WhEIFzT1N12TNKW9a8n8QJgjc oVUPxqt/TwNb
xifbTsNGS/DzUkv8zZmxxBZeKFKyws8Emc80BJ5MWb8ZgiMLZbriRyqxmhvz PmozVbiJD3ge
kOp6qYcpAdd6gwJkjpdVtpPl6SGMBuF1rjdaks9uLYnxLjwMwi5cZ7ZJbEWI 6uJqmCjJF1St
WFHgBk+MyPT3w4Z0+p9zIf1zCCYsFOmGB6m8KhakqwudZytie5bBw2tYH7Gl 0WYWTOe2PDh+
yZ7jxP9ci+s8vg8+LFaWPLiM0wxMkHj/ZMj1Xi7WwWYyDmz5cP1COulwiq/v 3/9nehO0o0KB
GrwQIVPeKw2izq1QIcCfDciHTKMuORHLrOdFwiy6DYvXSyxYY4FdbCjxfbz7 NFj/pHq/X0x+
tuREjCQYnhip/uT/KynSlmuKvueTcIgdKuuUeLMb1sET5YJw8F+DUA1XoyOW weIqCQZPzJFT
/95u7TnY1Aur77wInaCoVw6IffVWqvfkfsXPhG24ZnrcDcUyVO/p3cRl8jXM +pnpzBbPNpss
S4iWm0gCCnjU4Qb093KKVqF3AY7z5e2U+N1mobRMojiJsiFGVab/arZYzYKf LecwuoPIAdhF
PH604cl1FiaDTQeo6utgvMonAf+wWydlQ24dcf3v3+dbR/9sMYfJh3M/sxei vDpv+VePqyXt
oaPmOHm41VM/J5Bl2Q1WU8pxpFW3IHwE+Pp7oMWV7oxvk2+h2cyA6FHf67KH HvwV9pRmRtZr
l2HO03TGqZxQmj215QQ+1BMCKMZ92uvxa/v9d3reajc9nEur6tfC9KI0SLR1 qBg7+HS59DoH
oGfOPj2s6tSNp1WpTd/o4Afejcc3MTTBgu3Hkl6Zp458rlFKrWkSq5sF3wf+ tkTYVY4rhd5g
HvQThfUeLcWi4Fo8dhS+XUE0RBxTNW2KOJgMCM1pQcwpMOZOtMIgIcpW6Wp4 m/rKAgjRDL2H
aaIdKKVRfN/Qr/gzORnCzcnk/WOcZEHfpqbpFr16Wae53Lazq3NjeFxjCU1T VYocSRWVDZNp
gw1SzR0QkqtBs0bmSA72TjmTpHeQiAnGtluBJBvohFaeEFpCSxXuD7b1jKbI 8AwZipwuc8Yj
eIbm2+GnWto1hGX5Nijqt83d+ZH1QT/dzqC89Gp3K4LsvMNZ9TLLCYE/3wuj v5Of0Y/qhnpr
OjKf/1h5kEwAEVL0rTW61BJThAaK6WLsV7WxdbxsoBreFflVclSjBzeimKGg 4nN1eVH8GnCS
dHFCiUtoB1IhZTCM2BmK9H7168BI1MUNIyahJUa5FLdFjS0kJC2N7tDTBDWP y5hLuVkXr5Nf
23hcWq9gjzMJA/WI8plBajoueQ3dxKiWE3Zl21v1Ha28nmZY0s6XIanOw5yr fJhgg4P467pZ
mHys1TM3iY3hMCCJd8TNLAXPN0kVzTo7OLdDjfEmB4YybYm/2DCZNog4rO5U S9jZI/bNWkyS
6hMTZV0ntNsKlLWUFmWFikRBEipcqGdY2BEqoWqWOOkbFqHdVrBQOR3DwoV6 5q/8rE44nvM5
xeKttgNEOIbriLuoyN6G6LQgKSWX08vQnDoTFP1l/ZCctmIZuwkrbw3Dzl+6 Ja4t3sD1SDXF
lFRq3snPokXlAK/OmlW5hj69KcT1zjSFDSSNlUDCElp980zRrDMORIQ1CArD MBCYLI8I4HeK
CQD05WLf/s9bdXY/ltCR96ko38wkbNZ626fVLpQdt2XLtnTESLa7s5aDLdsY KKUKexhoxfxD
G1fT39UNsjxd2Pf+EG0XA04yi4lnWY7x4LtAhR4ODs9NUgO7OjFbDmv67IbJ 6XmRVehN8xgJ
Fjyl0ffySmjX0flUQgfe54J6HmALzXFGI85goO+TFumNvsdZuWlHGLgxlkBI gy0DohDlDQqW
uk43gHgau28cxIYdUWAiOgAhl9TrCEsye/VZ6N6GWiH91t7p+LfNxlyaju6F 23FT/xf8Lhui
j+qqNH8dz+Pn/XI9twIn3xMwaBa+b3rJW20BBJbhAIOGYAgMVJxXEPC/0sCr Xi7gGxZN+y0A
Es3rEChZbF9DAl7Tla4I8DEOFCmMVp7HP6slf3pLgPf1Fm52yL3NukWX+z5n ybRSnFddzKAM
CfhRf9ubuer8dgSa3pBfleCbe6SW3UDgIuxAkHmGgFAI8gXC9LjLR4Hi2gfv u8xiy24YMENa
Q5DL8YXAZ7nBLGnf2uf2+8ptHM5u3eCXbtCdh9JNHN43IHQauGGiGNganpI8 b0hVJBv7hEZs
2RESJcvYHYtckI9jmFz/4d7y7fjN3rJFrWdO/t7vzZUnN7/k47Z4D4z3/Tq5 bTcscnNadw9B
ktf+kV9nw3dP+eU2g/QPuX1HTLiM1v1DkNTrPmrp/V3z/TT+9lXbvc1bNqzZ Pqv7m73O+636
VzCFM2TlapthXi0Vm2+JhGqkfqfJ/uXG8u82cjODwEnfshRfCZBv9hnmldSO 4RSN7BFOuZmm
cOKrX7q5p6cvmKiG7WbM8rUpJdfiQspAmk/34z6rW3n696e+ZedXf4vbVIwO Ll/W09TR+Q0x
LYNVvHemPx8L2hqvDXKPX1o9mpcHJoP024vGMi6IEPY/WkEa7ubIAFx2/O0F rn789pI//B3V
+BI8hCnEiBVfXV4YwObly8Uexe/D6RHuZp1rEPyrbz9q39/cAkKV1Sgw1B9p AkR9pFGgmC5Q
MgXMI62mjv47zMAWjXkZpF9wL+RX6rGK9N0A7dRsyXJ2hxSrCE+yEqVPZLOr tJ7Ax+iIGt1H
GWphnxYXlBQRmVJtE3hKYAqP9Maka1zbnuJ9vY/ewXD7TNcZ31yP0N/qV/wy RmRc3aN4fCl9
Ex539Id5zyieuB5xXZreW0iv0ILJIy7XfstN/+38jPoM/yBQeiVzkON1pRPr uuOVwFXY2pwK
DKXHLQXorzNTbyxRIaAY8AWiWoE8ryJ/VRKF49oCJHbfZ3WZch6cbb2usa/Y CzJUKzeaKl5q
ZW9wdWHzHg0uFhn19c3NtuuuiHJwQl1N9EH8oC2NXuEK/VVLDn2gvqL6EP6o CwUX/LusVu6J
h+e8YHkn9MsuM6hmXY3nW3Q225rmXmJNU9pctbd0oZCD6VYV0D0aPi0KoZfN lq/ocbHaply6
T6uLsgUaq6VDMXurjbXVvUwipBLrJeOE+2UcDHMtwu4PWUMt9rIfTLez9DWE WNc+9zSolIsP
dDK6qLvN1cOMUnZAQqt8IGQfuMZS6V56pL5iutFI8Q4Ve1PNxdW9dEJDjXWz seLVJA6MZKzH
PoC1eVl2s7XijR8O1hpKuA8Qxexi+wpL8533/hi1YYV0b0wqFknviEWL7Oo6 BjX1tbRVB7up
K6buqZ9paqpr7VReBrc32Fh93VMnU4uw660ULpOwN9FUa86zhazqnN7A4r1a B5qsrs7lOWL1
q0rtTQh9MWWj6umeWFIsoN4JRxbvPFQzZF40ScJBfJXBPtKal1n3EnRqtXWN peIlBfb2misn
e7Uvr52sM1DMDbW3sLJMsReC1JVx19kp5/M5LBTM5d692llUfddZKeWx98yP Dcuq+yXKvLJ6
h2TJc0ibECYvsK4Bp0iJ/1yZRCnFbrCxJaWYirb77GVS7XaTmUU6t9tIWF3j 3b+5pVLvJsPL
6dG9MU19KXVf9FJUU++GWfi79TWkwoqqy1AUSdadrFCHnoaVKq+XrW29Tq0q 0O6nq5XqtGus
lLOCHVbjFeXcfVopVHXXWCkl3n5m63G5BLzGuDYr8SZV4n1aqSkWr7FYmzTq YHxFaXmvRhcl
YHXGSq+jd3PEOxznGg92tfmODoumyrr1PlGVytdrTFXSCZ3WhzVl7n0CK1a7 11krJ+r1u1B0
rSjvdeHY07muPpeo0UKy6pDXlPvnev5ZUbbd5/qyuhp9jQc0uXOuB6Sv0h1q Mfs6d5Rzz3ro
5k2KxPffj4tUnE46rXiFgwkskj1lmio4TxJ6LSXfPw7lTJhO8NCVk6/ERVdT 3nj07nTybswg
k8qmf7aRzzN9zH7O84TKVei1XWHhti9dn6nl2eGeQtwCgIqi9ZUxLyLy+/n5 72A0knU7/x9Q
SwcIc04ZP9UPAAC9tQAAUEsDBBQACAAIAOpZAzcSK5JKmAQAABQYAABTAAAA b3JnLmVjbGlw
c2UuZ21mLmV4YW1wbGVzLm1pbmRtYXAvc3JjL29yZy9lY2xpcHNlL2dtZi9l eGFtcGxlcy9t
aW5kbWFwL1ByaW9yaXR5LmphdmHFWG1v2zYQ/iz/Cs4tYCeN5b1+mZ1g3uZh AdKmcNMOW1EU
tHS22VKURlJJgyH/fXfUi+nEStrajj8kNMnTc/c8R91J6h8ettghG0Zpdq3F fGFP3LS/Mqel
p6fxUxz7rYxHH/kcWKrnIURSZAbCeTIL4RNPMgkmTISKE54NWi2RZKm27AO/ 5GFuhQxHWvNr
M7i78VsqJURWpGrd7pkwdgnnOwZ0HKVJkqrSwdRYzSM7VnkCmttU43X9kuM3 vR6bwlyoXm5A
9+I0Yr2e4ztiGjINBpTlFARLZ8wugElhEUWaag4lLJl0hpCcDKcnL7VItbDX w/70ZNjHtc4R
QXIVMwoJd1gCdpHGhs1Sza5S/VGoObsSdkGYSVjHBiq+E9kvBh6WOnxejC+L 1DyZg62i6h44
lCSNQTL4ZNEHxM/B8t+55cdtxRM47lTGnbYznoMikhAX+c6nUkRsJhSXLJLc GFbZl4CG3ZWd
/dcKSPcAAS9QuUqtf8aT86VSlcDsksscQmfdlCa3lxXjaZGOBLgiLTE7D+Cn 0w94vJgwqmOR
BHB95IAQRQMmn0t5zcwizWWMvlmS4iqichaDibTIXMbJNgzLKPtlKOszF1Sp e0IBvT87vRhP
RmfFsstF8XOptJumOkYXbtJvBaXwho5kpb9QlhEiO2bf4sleK/H5i/EuFV4P vz+BMZ7t6ouA
KO93TfJe/LXTA7wefn/yYjzblRcBUd7vG+X9czLe6fltcrBHiSmiLYtMkCjz D00y/3H+erJL
lRvw9ycyBbRdjQkRJf6xUeLTNzs9yA34e5QYA9qyxIiIEv/UJPG93f4zNP6M 3v2V0dePSH7/
RyoKruq9Lu0dsTYN7Wo8+LK2vi2qiL4pU68R3yaKW8gP/7fLoZHlfe1vc5aI vilLrx/eZolb
SA//t8uhmeW9PWgLPAl/Y6Z+W7rDlTaJJo3t+kcj43v7weaECX5Tvn6HuE2X 9pAkDe1qbOZ6
X2HeAleE35irV6rvcMU94ohDuxpXuI4U4/Qi79qGlK4/Nb8N1y/NqTYbkV9h SwS1uMTpeoZv
37E3o7PX41fvR5PJ6G923AoCnyXu4xtqEPjl+YgWvCrm5t79Xsz9u8Kt+Oem WPDEpYWbFfFY
mRjsxHEvVdiMpTB231quOSz01aUUEY+I94UmzBU2djETfCqBrLrFd52QGzfz hT9YOTkTsLlW
5iGW1R1TfSNhJoMI/UH8xU9RXytBfafMwXZfWU3PXqXvA3dy6FtOl55RhHsX x2G4cuJCCWpu
FwP27JkorghqTA0mlxav8y94K94NyErMWLcwCG1aeO4ehPBvzqXpViGUiIF2 gpaA7vKbVvFX
7qhcSly/2WoS6KvRI2n/6/ULdFZlgBw/nvzo3jmv1Xfu9ys9UoY56Mc9/6Sz c1hwNxhXtGBd
bymIuAH3rPszK+n7lXVQm2B5rS28Urs0wHpbG3i11zOgArw08cvx0ohqcm3j F2jPBKv00sQr
2YMH03hOVdsuhCm/h0ZcsQgLo9U5vXnhD64i2E23q9t0nZQj5t0d9WSlWJk8 A90trQuzar+g
dsP6/Qq59T9QSwcIEiuSSpgEAAAUGAAAUEsDBBQACAAIAOpZAzdgXXKl2AMA AIoVAABXAAAA
b3JnLmVjbGlwc2UuZ21mLmV4YW1wbGVzLm1pbmRtYXAvc3JjL29yZy9lY2xp cHNlL2dtZi9l
eGFtcGxlcy9taW5kbWFwL1JlbGF0aW9uc2hpcC5qYXZh1VhNb9s4ED3bv4Lr FJATrKX7Vjay
aHIosO0WTXroqaCkscyGIrUk1SQo8t+XX7JpVYrXjhNkc4hlinzzNHxvNHRy djZGZyjNeX0v
SLlSC/s12fpuht68L97oz2Rc4/wGl4C4KGPIKaklxGW1jOEOVzUFGVeEFRWu 347HpKq5UFsz
wczMuYD48u/sO+RKT0s8h99mM5RBSdiskSBmBc/RbGb5/IkE1AIkMIUV4Qzx JVIrQBUvgCJu
gVCUQrVIs8VnoHaSXJE6TbJFmujxKF6HAFZ0A9h7tQ11rWGXnFJ+S1iJloBV owMjLADJpjbP
A8Ufdn5D7QKEUkoWP88pYTc7kxKH5E5KUH/hTD+BYW6vLNeHNNGIT8e+4o3I wYK7y6OiX2Oh
/1t0d3lc9PvaMTcXHeQ08alPk7rdvXMJuyUZf3Cfn5yETZww7vTUIjlRwZ3S QoHiAyh8gRWe
TxiuYB6FCyJ0owHnEVS1uo8mdnUJDATWInFmaTJKckSYArHEejPC5T6GRN4K 6Od4ZLww0jif
QeuOSavyH5g20Eq+VbmXSytvhJUSJGsUxHb9kJlGXunm8703EWBmtB4G2Igx QEZEskihnAIW
v1sEPV/7QgCm9B7JFW9ooYNqWwrLF6MCZC5IbT1r5saxp5d4Dv2ONHfOhU3B QAZ6CTpsK4UT
6b01vdI3WXm6ufVElXxzsB7QiaVh5J8G5pMlphImqNB6MbqdT/pL311FY6Xv x47bxEL5v191
5zS2fsgIOSFSQyNyawPVjYzsRg4YtQVmeqrL7FpbV6D6hHXUErafIIdFUGOB K0/UsGRwe4ga
Nonoz9cPTgrUkYyLs5W5na5s6+zalgKWWvYsP44tgzIeQL8mX/Yz7BjTTZpe 85rkRzSmh91y
5n+2k7SLh/xkqaL1O/VZ/TTw2t5PS0911O59DJLxuKfC3T7EU2138UyeCpqX V+qpfoYdT7lJ
R/eUhz3MU8ou3umpNsYzemqgWX1ZT+3exyAZj3sq3O2DPGW76qHm0ZyBClji hiq/nEhzRCxg
Mbm4/HT58eLy47uvE3NK1EObNZToNle3QPa0tBS8sjGBNZV5COOLQ/bPcH04 jtXbs8QrbWr7
+MV7eLmbtUBZRF65Q9U0KA4nDZM9o+1YF+6YZSWI6YqK19s8FFi3r7Z0Fc6o HlKigcMaZ9N5
D9Wk7iOjss3PcxanX8+6L9s+vxLdldtjg7WvT5s9RfCLCfI/2adHclXu79De zAU573tV3K7A
FL4XS5d5pWhCT8qaL6bD1B8p+pvge0jykORnnOt3C0PB7ur8P6Ak2foxaPwv UEsHCGBdcqXY
AwAAihUAAFBLAwQUAAgACADqWQM3MC0YJQYEAAAHEgAAWwAAAG9yZy5lY2xp cHNlLmdtZi5l
eGFtcGxlcy5taW5kbWFwL3NyYy9vcmcvZWNsaXBzZS9nbWYvZXhhbXBsZXMv bWluZG1hcC9S
ZWxhdGlvbnNoaXBUeXBlLmphdmHNV21v2zYQ/iz/iptbwE4aS9s+zk4wL/GH AG5WpOmwoSgG
WjrbbClSI6mkxpD/viNF+U1x46VJ0w+G+XK8Oz7P3fGUHB624BAGqSoWms/m 9sRPk425W3p5
nr2k/6RVsPQTmyEoPYsxFbwwGM/yaYyfWV4INHHOZZazot9q8bxQ2sJHds3i 0nIRD7VmC9Nv
bpwqITC1XMm7dsfc2JW6dcNIhlOV50oGAxNjNUvtSJY5amaVpnNJuOMPvR5M cMZlrzSoe5lK
odfz9x2CxkKjQWmZcwLUFOwcQXBLWoSp5xjUOpHOAPOTweTkEoVfMHNewNWi wEEyORkktNk5
crqZzMD5xu0CcrRzlRmYKg03Sn/icgY33M6d8jxeOokya7j4q8H7MY9fV/9v Ko5ezNCuu+e8
6x54bbnKUAB+tmQLs9do2Rmz7LgtWY7Hne1DnbY/NEPpbo9ZFQjlRPAUplwy AalgxsD2uWDA
QJMX+LcVOWIiUnxF0NZwno3ejC7ORhenf61wrHmAayZKjP2ZXWz6vaL6P69Y y5FJhzSRuJcV
NflIsQjcyI6liyHTR14d6dJIkcKEWICZq1Jk5AHkilZJN4MMTap54cPDycZx 8DUJDt3NblTT
+2Ll1t/j86vR5XBcbXq2quGKAz9VOiNDfpK0okCJcVFcM8OlhZVeOIYfKSXu hP784nT87mz0
9imB/4KN54O9dupxQa+1EuQ/7YJ89OcVEfOkiO828XyAB58eF++glOD+eRfc e6T9HpDvncQP
vEyjijbLAl1S4k1DsruSPIL2atLenB08oAI8Fjq1icfCZjt3dyFTyxES9bC9 Pt6JyX358/WQ
BAuPhchWcu0CJIgRBmHUXhtuoDGUwFzj5pNfCF9o9uh+lt2S0uarQNqAxKGg +TVNvwzD+w/w
x3D8jgJjeHk5pHevFUV34UBy1IlEUTPHjtzydnj5xS2E3drtBmAQiKIamvWU pDIqqIX9bvC7
I4pcix0Ao4BZa8fjUlJh5lPOJgKdVLdq4mNm/Gwd5IONsLlEW2pp9r5unVZ1 QwymwJQMY/a/
H8WHYtHIJWqgu2+tdk9q8OHAh4tr4Lvu0eG+oaK/wUa4xQLlzM778OoVr05E Dd30vVEKS+fX
D77nH/pOmk+hWwnEVlUedA9i/Kekr5Fu7UrQHGmPdFDoj9+2ql/YkaUQtH77 NOy4b4ZvTMpv
iwsyWlPjHPj2vJAb3oklLd6N74QTwgBnqJ8nYxwB3nAFhiH/0jl015ailJn1 vuYXCKg0y3B/
KV7X4qXwdnFeiYYKvZTcqtj9e6n43RVtO+cmfNmmTEJK17S6dC0zDZhM8Wne tcZTvcTzCNYi
fjnZqEymLFB3g3QlVu9XV7yFJNm20PoPUEsHCDAtGCUGBAAABxIAAFBLAwQU AAgACADqWQM3
EWEFKYIDAACCEQAAUwAAAG9yZy5lY2xpcHNlLmdtZi5leGFtcGxlcy5taW5k bWFwL3NyYy9v
cmcvZWNsaXBzZS9nbWYvZXhhbXBsZXMvbWluZG1hcC9SZXNvdXJjZS5qYXZh zVdNU9swED0n
v2IbOmNgGvveOhmYlgMz/Rrg3lHsjaMiS64ktzAd/ntXkh1MSAgJgZJDYsfS 26fd96R1cnjY
h0NIM1Vda17M7NjfJnfu3V9vT/O39Jv0K5ZdsgJB6SLGTPDKYFyU0xivWFkJ NHHJZV6y6kO/
z8tKaXtnJNLITJWlknFtuYhPPnNjVw/FTGmMT75NfmLmhiUN3TfDIUyw4HJY G9TDXGUwHHrq
x6Cx0mhQWma5kqCmYGcIpcpRgPJAEKVYjtPJ+AyNqnWGaTIZpwn9F8VzeJT5 Irh/VvkwFwQ5
VUKoP1wWMEVmawoKTCOYunJrwfy9H18LPwEgFXz890hwebk2d3FLbK9A+5HS Rasx4Ei3N57t
TZoQ5tPQT0rGhYf2VzvD/cpK9LDuYmeoF6riWchEuFxATpMm3WlStRU7Mrhe rfGX8Ps9qNvF
auPuH3iUICC8siQMzL+gZZ+YZaOBpPWNonZwBJcENIqwrOx1NPAzC5SoGQki +KeeCJ4Blxb1
lGUI7dQG20Ajd/jb7zm99wjjDElf0ngl/2aixlbWrZJvddEqmXwwRY2SgAV5 LPY4TrbuDjJF
8Z2onGId1nWF8NiKXMw0svwmQJ5a4AYmPOeaSJPjmAAmc+AErsgJhlt0I6LN 0F0Fjms7U9pX
O1yGakch8KpNoNe41JNrzI9MOp92k3bHSYvZIsIyoiwJZPqdR6J5lCliJsQ1 mJmqRU7BaVsJ
+WOQo8k0r/ye48bGcUMzabgs31XckyPty7uiug8SDTGeKvEfbQzS+uPxFgsV pgafOD2NBo+E
GMyFMhowDzXwWM3nvueCx5i1mk9qS6YLJsyaVURhesd4Pee8nj9soLOl7h/Q mfJ4kzU75Nxh
cwI7EeTt/ttBfk1CXEqwI8A90xwn++f0UBabaOkBbQbIg666asl/1SSWKRMG B5CTKC7uCe62
f7gqRewEGQde24kLHY1VygrA0J6nd3V1jnaZqHZ2Wm8mxNXFr5hmZUPSMZT4 ZxsV3CZhea5+
K57DglRCnM3cGBqLZzLjvGt5pV5cxm/Bim7Ibp3oEf+7Ed33eh8Grs9kwyXN 7cuacF355wl4
2IIdiWzjwLYFf4mW04V6to7TgXeVHt4w5ne7bDs7ry2vuel8gOaOWs4QYbOG 816dtmk5HUi3
49Qt2HbbkfXrWNtytsslg91Akszf+vr/AFBLBwgRYQUpggMAAIIRAABQSwME FAAIAAgA6lkD
N051hiLTAwAAShIAAFEAAABvcmcuZWNsaXBzZS5nbWYuZXhhbXBsZXMubWlu ZG1hcC9zcmMv
b3JnL2VjbGlwc2UvZ21mL2V4YW1wbGVzL21pbmRtYXAvVGhyZWFkLmphdmHN l9Fv2joUxp/h
rzhjk0KrS/K+Aeq0O02VVm1a+3DfrkxyCF4dO7OdrtXU/33HdgKBEgYtncoL hDifPx//PsdO
Tk/7cArjVJV3mucLO/WXydq1++vNefaGvpN+ydJrliMonceYCl4ajPNiHuMt K0qBJi64zApW
vuv3eVEqbeE7u2G38W0h4oxZZu9KjP+7+PxJY640Z/IDEygzpt817dvKSMqp Kgol48pyEX/8
zI1dSW82xVRpjD9+mX3H1DVL6uG9Go1ghjmXo8qgHmUqhdHID/U9aCw1GpRk jSsJag52gVCo
DAUoLwTRGIvpeDa9Wmhk2TiZTccJ/RPFS3Eawaa0v1f6Tq5IcK6EUD+5zGGO zFbUJTCNYKrS
jQSzt759JfwDAGPBp7/OBJfXf6x0HGy9ztGeWywMOLf+l3d5P05I6ymq7yu7 UNrLhp9H0v2q
jP2XWfTK7gLc1ZHEL6swd067/r2hPE7qao+TspmwM4N/Rju+CN9fQxRcb6Hf 4YnXCOzgrSUq
MLtAy2hcbDKQrMBJFJpGcE0ikwgFFsTeFynuooF/OkeJmuqQhbhVM8FT4NKi nrMUITxeqxuo
WYdf/Z6DvUcK35DwksZjfMNEhQ3TDcY1Gw3FkCqCn0vng9IwR42SOhKUtNgL OnzdlW9IjQK5
TpSyDIdNjev7Psh2pbJXB8d9n9dpRCZddNoDWRG+awTAjYzIuUCm//GSJEDu yYsQd2AWqhIZ
uaDAhzExyNCkmpd+NXBt47j2m9Smtife3TnTvvYdpd/PcejsaSD+77siHHsr Ht1kTQYHTNOg
bXIysLrCgResPw8BX0M6gsA7d1ai8GQL7p6ju+fXc2hWruEJrdn7c9wsRkuQ l4UMNTx3sw8z
nnFNEaHpZAKYzIATwYqWXUPWXItoX4S/oVGVTn2hP9BbyWfBmWkuwgoTHYXv 1lLbGtlL4nm7
wxa/r03z8hg2pTs5Bt215iFa26aunY6Gh8kgre/uxTqzVvNZZbGhnXlrXbg3 LmD5Vl1H/hLt
Nt6P9sp+ME07Ge3GomSaFbVJ51Diz0fx0SrD9oLdKJ7BQ4pCZ4etFq0NxnLB WE7fURK7voVp
qb+k0Haa3MhtszkbbturHyXFyx7WXlOV5D8qiuGcCYMDcEeGqwdvrtVe3x0r /JHCKT0usmXt
oyu02woAre3rM0V41+74MHKfmuO9kFkryO4w70TrMdFe7u+fKdjt88MLjXWH xY1Q162Gl3Rb
5kdJcSN5lBAHX4+LsQlGulIcpGF1Mnym2HaeO/9uZvfgoV2K3YFdx2aV0HtI kvpA2v8NUEsH
CE51hiLTAwAAShIAAFBLAwQUAAgACADqWQM3DgC1QyYDAABrDgAAVQAAAG9y Zy5lY2xpcHNl
LmdtZi5leGFtcGxlcy5taW5kbWFwL3NyYy9vcmcvZWNsaXBzZS9nbWYvZXhh bXBsZXMvbWlu
ZG1hcC9UaHJlYWRJdGVtLmphdmHNVltP2zAUfm5/xVmZlILW5H2kFeyiCWlo CHjY2+Qkp6nB
sTPbgVaI/z7buTQtKeVSJvLixJfvfDn+PvsEBwd9OIAwFvlC0nSmJ+4zWPm2 XR9Pko+mDfo5
ia9JiiBk6mPMaK7QT7Opj3OS5QyVn1GeZCQ/7Pdplgup4YrckLk/z5ifEE30 Ikf/9+nPHxJT
ISnhXwlDnhB5WM9vI6NFjoVE//uv6ApjbWCDivOH0QgiTCkfFQrlKBExjEaO /zFIzCUq5CYe
FRzEFPQMIRMJMhAOCLwQs0kYTS5nEkkCJxqzMIgmYWC6Pb+JYLit47ux3EW6 NKhTwZi4pTyF
KRJdmLhAJIIqcvs7mHx28wvmFgCEjE7ujhjl11tz6JfcLLW9FPVxoWdCguVd vjqu92FgEF+L
/UUkC4dsX3aIa9szofQ3otHh2w6wPWC71iKFQZWmMMjrTB8p3K42/7Rsz0p1 2shLHsN9h1Pu
Ps612VJMTlETw4CMB5xkOPaW0z24NmBjD7NcL7yBW5siR2n4JqUHiojRGCjX KKckRlgurvAV
VHqFu37PCrZnUM7RqIMrJ8UbwgqsdVlLsd7VWoVGxlOUyGP0HcAmyfcqQdr2 pJI6Em4l2Y7Q
Ek0LGqjinoaYIZGfHIRZYPRr/oixBaiZKFhiohr3SMeYQIIqljR31rJzfb/i F1Qkup1jR46k
S8KGHHQzLMGdDvZUbYPhOSpRyBj3l6OvUsmfCrfC26SWUhtEa0mjQqMHpXyI W2zU0luVS8/q
pVdzhcbFw31zkjXKuEDdJYudHhPPU9PmDcyJJFlF1LLkePuinWylojtpN4Im 8HC/y2Ar6dtq
rPJQa2zV7N5ObNWcmC3g92SqLn5rlrJThhdmjKc7s5PDXDFTwenfAseDKWEK B2CrgUtTDYwH
3Te+rRhctVASK61VPU/2ZWRYbHJliQvV7feGjuy4XJ8nwte6cZsEmhQ87sSW TF7iwvWr/438
2FFhvFNnPs50zaPtSmrYVUDvzLkrkXbiYIv0Mv/SFpdNPu5KBqzVnm/o7ieV uP/X708X1oM0
PX4CbBXh8ly4hyBoFcb9f1BLBwgOALVDJgMAAGsOAABQSwMEFAAIAAgA6lkD N1zhHK9hAgAA
/QoAAF0AAABvcmcuZWNsaXBzZS5nbWYuZXhhbXBsZXMubWluZG1hcC9zcmMv b3JnL2VjbGlw
c2UvZ21mL2V4YW1wbGVzL21pbmRtYXAvVGhyZWFkUmVsYXRpb25zaGlwLmph dmHNlslu2zAQ
hs8WoHeYwgG8oJLurWC4hx5yKFokvhe0NJLZUCRBSlkQ5N1LkVIsyfHS1El7 sWUuM/8Mv59y
NJ/7HswhToR8UDTflAv3O+oP2MGLy/Sifoh8T5LkhuQIQuUhJoxKjWFeZCHe k0Iy1GFBeVoQ
+dn3fI8WUqiytxbrtYlQGH79vv6FSWkXRq2aD0EAa8wpDyqNKkhFAkHglH0B hVKhRl6SkgoO
IoNyg1CIFBkIGwwmMRaLeL1YbRSSFK6Q2bV6Q2UcrRdxZKYn4TYX8nQnk5uV LuvKZMgEY+KO
8hwyJGVlNABRCLqSdXmYfnI7Kua2AMSMLh6XjPKbo30KndKu0HGO5bWoVIJN FXVNbgDciC3j
KY5MmrNlXBFVf24zuoE9GeOorTaO5LZrS43H0Qi/ue8fDqXxc9qupOnMBbSn 6x5z5KiI6XeL
YrVmNAHKS1QZeW5ONwrgfWmOWEMDGzz63sjCNjIRr9AcJteWolvCKmyRaika NL3lx4CYoUKe
YOgC7cV21JJUP1w2vCLhNUvdXLun20kCVPNJCQlDoj66UGajAdAsZuwB9EZU LDX5jRWUrYFA
ijpRVFqf1GvDsJUatXL28F9PLZXtzJ7GHBTbpLEgjHUf5OmJaM46Mc4C08+e ijZ8g9ZowNbI
wjU6USsMzDqd2QttC9k1li8R9vbXw59iegAHSRQpmgJq9Rzv/oqLnZ7tPYVb QVN4JUZO4vA8
jpp+cO+9nel3L9j/2PQHxQ5N332X/DvT91Sc3fT96O9h+lPe0O9u+tO52OnZ UdO/BqOu6Z8g
il74U+B7vwFQSwcIXOEcr2ECAAD9CgAAUEsDBBQACAAIAOpZAzejyH3UMQYA AC0wAABQAAAA
eGFtcGxlcy9taW5kbWFwL1RvcGljLmphdmHVWllv3DYQfrZ/BbsJsI5Ra/vc rA0XiVsEiOMg
doGiLwVXmpWZUKRKUT4Q+L+Xl7SSVpfXkrL1g1fUMRzOfDPf8FgcHx+iY7T0 efwoSHgrz0xz
UWrrW68/BK/V7+Iwxv43HALiIvTApyROwAujtQcPOIopJF5EWBDh+O3hIYli LiT6iu/wg/cQ
US/AEsvHGLy/Lj/+ISDkgmD2DlNgARZvs/eLkkFJ9nkUcealklDv4iNJ5EZ0 9VXwuQDv4mr1
FXz92sIN76eTE7SCkLCTNAFxEnAfnZyYof6GBMQCEmBKNcIZ4mskbwFFPACK uBGE5kuIzpar
sxseE3+5WJ0tF+rG3MtlqwFUJZtnsenjRslbc0r5PWEhWgOWqeoRYQEoSWM9 EAh+Ne+n1HyA
0JKSs+/nlLBvnYb2jFavQpDvlKHUOBKk1c0aRtWn5UIJfIHo96mw5tGis8Yw oi9Y8B5LMJLV
NdKNYSR/wpEVqy+GEfkZhK+sqoyrnjul3T2U3RyoJ0FUeMhH24VrDCP6CyQ8 VTpboOStYYRf
Syxk7lDTGtCl1+lK6muret6qCF8uXCAtF3EWi+cJdCct79L+frZJTvdouj56 Y0TYpAAPUsU7
BJcgsRoZPp0xha/TuXlzjr4pEadzoKDD74rRx/nMfBwCAxU3ENg0mq4o8RFh EsQa+4DM1052
glwKQ98PD3QOO1ACvoBKGywx2ekO0xSyVJVlp03EZwkK+VylNcL0bZXn1iCA qa6oyqGekakz
k26ZF03q0ElJy1VZGvX2zq0AHDxZkU259sDlQ/37weVYwExnxOI4SmmrbQCI JGyuFKeAxc9G
qpKhlFeqUPqIklue0kApojK5HRJGASS+ILHJY/pdz3MqL5xe9blcPzkXxvoN xu+ttO3vRVD8
J+tMYfJgA0rtsNNZT1fNiiqezqRIYWaEub9thJdAPUcW8L7TZG4/LiD8QEP8 wJA1KhDT0RvF
yf0BveGZHNBYSkFWqYQNfgNY45RKJ4IkupgJ4Gz2y0yXMepqEFyWOK+gxz7B sEnHAupekeR6
w+YZhMyTlCUNT4r315Rj+WYAGFd7sjB2zjxV3kMpI/+mCtRrTBPQTaWHxCsK DrFIl5M3W7jf
1IG65DTl5u9a6V4Iz22WYTxwajZh3NgDhUXLFTGujF0H8CHrry1HtyK9GVox FjhyemolGdxP
iLFw+37V1HecBGgLi1bHktH/1L38X8zeYbEau7TGZK3RKmavS8L3t6AT13RG 05laafUi27ls
2Kx7R+beKLADPJ/lhhXniiEYqjj6WXS4mRw10eELOa40+9pTjmvS0Ss7xU0q j+oWGoZgr0x+
ibwqhNWbnrSk3dgJrBpN5FQ3erSZco9DVc3z+WmZqg9SirZoJ502QNVQUGcw 2yWJkQI5X+/Y
0yCu068SwPqVo2v1jIVDxKsRN0iwWp12C1f9vylWrVzklq3GCc2aBbFpY7LL 8fno24OxAI5d
Ym97wW6kOKxdGdzTmOzSdavAryyFbtf5bS/UPB5sZtnQb23Y/5hJZVzWsHNu uTWiMZJD/6Xt
aXPGtMCss3Z7MqrF8aiz0uk91c+4zbbrE/PNM9dW+I8wgd3JvpPNZ3uQSu28 djrPlSa7vZzX
TNX5xtcuS8B/X3y5Kq8C2w0PqdSldq9jLXhkegSWRuAWLvoiJtNumK2P0ibf vlYJDTo+Z2Mj
k7GVWtz9moRd96R4P7sYpHyodFZZmDaY6iwjdisLXM9N9UC+JRwWTTJKLdC8 +Twx+e8P3sLt
+40lQRWX45YD4zurw2g1pukK0Ra2r0X2GDTfy27T8Xpz+q/n85E8UWbvVmc0 0nbhTEnO2+Od
P8h6czT8QZ8NQCsSEAG+pkBMEWYBIko8j2OeEGvU3ojJ5OccYU+f3BSOnswH qQDKR3GqJtun
OqBd0yGOOeQ9HD2H1LddVSTxnockMiGzHC6K1Y2w3XhdZEPpPChRGPSz4q14 zGqktazKSa49
rU+btaysL+fH1EbbItr08IM3iZJMkeduExVGMEaR2X5ScNo6sx9uyjZprwHb AbbLsnXhtOME
pGrcNMzEtnxMc59prV3TIWgt72G343v60x2zQNZxJwkVVFT4fEKLhT2cevgf UEsHCKPIfdQx
BgAALTAAAFBLAwQUAAgACADqWQM3crGR/J8FAACjHgAAYAAAAG9yZy5lY2xp cHNlLmdtZi5l
eGFtcGxlcy5taW5kbWFwL3NyYy9vcmcvZWNsaXBzZS9nbWYvZXhhbXBsZXMv bWluZG1hcC9p
bXBsL0RvY3VtZW50Um9vdEltcGwuamF2Yc1Y227bOBB9tr9i2i1qpUjk98QN kiZqV0AcB7G7
230yZGnsaCuJgi6JgyL/vrzpRkmxHVvFvpgWOeTMGZ6ZITn89KkPn2Bkk/A5 clcPyTn/HFa+
WdcH0/lA22E/tOyf1gqBRCsdbc8NY9RX/lLHteWHHsa67waOb4W6Sz/P+n3a kCipiCMVt4nv
k0APSOIun/Vb1ri2lbgkuHqw3GDjxDRxPd0YW2G7JNokQt248qw4PtsgNE2i 1E7SyPK+okVb
3DSB/d4JV2wQNYMEo8DyjMniX7STTfYyt+lS1uQu3EKcmu8GqxkRLfWKESTR s/nqDoj53I9f
rNi1JXDu0s1TuAOMLYV3Wzp32I0bt7irkXDXxE59DJJ7QpJGPY2z2oxqFhZt vvH9oYyfdycn
sMCVG5ykMUYnDrHh5ITH0mUAbI+QWcb5DWQJyQOCTxz0gPCNhsEI/fPR4jzD AAzEaLg4Hw3p
wEDPlWDg1FSMQt7M6KJL4nnkiXIAlsLnMVgRFhagc8pnpB6fAjDy3PNfF54b /NwuoiteZgT7
Y4XJ2F2jAwwC/8dtfhkN6dIHVPJjfHM7vYtw6a7pnnFtvAtEH9DOjhRPzan9 gL51Q0SGErqn
JohuyPq7UZ+BreMbDeU2joZhlqcvVhhgZNGNFtk6XXiuDTbLgaCuDrhOKJ9i KKWbgipVefjV
7zGy9yTRbItid+DR8lLMGD2QWHNKaEcqKQZgJTRHLdIEwaPhrfMF28Kn18p6 NnIRI5Z1ic4C
P/8kkYOR+Bj2e2FEEgqUGl6kJPDZdBrLO+GrslECbebjANj+HgKoqnQnxCxZ w7qyws6g1UjI
cLfFwgGh11W/Ab26SNkBbzSwor+iUg036iwaRL04DTHSjs76vZcutYtzD+CU VR2bf0gDIqTM
D6Bay/Qbl1Zdy4v168nV97FxO5vfTyazjqwUWakUg6WMwUx0l6DxsITPnyFI PU9092QfBPgE
yqFFSx7c+FhFVQEzn4/NH8Y1cz1FlTtCxn+HQA0JsZY0MqzVsFRAq4McfX7+ 0spH0WIXjens
3rz9Np9N5vLf+PJuTj1x/88xvHJe1HmpOIZtvMnhzO/uja/mD7a86lg12fwO DzdkqNzJtTqu
+Lk+/v9x9dScT6/+NMaX85vJ1eXMnNzWvF1Pbh06PAvanMbSCo32HBXRrNO/ 2laZZs68Rp0R
pdhVbhSW1+6asGCZZCrAMFx002lz3CDpx6u4ClcrMlB+cSnhP9L54peOs5MX Mgu4vk698Uhc
B2IVu8C4GVy84+7K1X/z/qIZPGIU4z365BE15UIOhB5zIiNwjsGlFy95bzKv X9//+MlN7AfQ
cnGZRGwrxm2K0CkTLlhUufPW+SMtLyzNiLGVQjVPb9KtlqnDGFHPYBvtqCfz g5iiuqAc/6we
lJYr5Vd+btMVLhUWlHjTfdRK5uI3Gn8KaReEeGgFQK/+xHvEooPVrtlziIfk LyurxbrSUQV7
z6obvCmb0P9/R1aYHY/34HabXSqzhYHoUTXtQrqfi+7D81ab6ixvNqsut5tl Ku2z8t3Mc0at
Eq1yOuUQui9LOK3TWzKfFpK/2C31kGTertzlmsvk3o+tmlZ/f9Yp9oQeGJvz 8f6GtLF0oy1N
OXlvc3JXyJMIP0W2rviS3aJ1zpASO8pTuibn9yBW6XlINpbO0DbN35F2QMI1 Jbl9lLSRqSVr
7aGqmSjsDvcKScROFdvRKTmycotmXEtfHRwdxYvIO3GRhY8f4R3v0d3Y8MPk ed9C2niTr6ir
Dr1B74ZzYf1WXtGuju5uQFtZzPS0HAPj6e/jlHg7gEQ+IpTeNKgddxFZU7j5 kUIYWMiyN86e
+PiSLpcYsVqeeol83SiPaOpc7kQhrrODWeBo7+XL3Cm8bxjlQw39g6OB7OU2 ysGykcx9LzAc
qq+m/f8AUEsHCHKxkfyfBQAAox4AAFBLAwQUAAgACADqWQM3C8z9cPwFAABR IgAAVwAAAG9y
bXBsZXMvbWluZG1hcC9pbXBsL01hcEltcGwuamF2Yc1ZW3PaOBR+hl9x0u0U 00nMe0Kzzabe
LTNpkwF3XzPCPoBaYXltkzbTyX+vbrblC+USyOxLHN3O9dP5JDF4+7YLb2EY 8PgxofNFdqma
g0pbdr0eha/Fd9CNSfCNzBF4MncxYDRO0Z0vZy7+IMuYYeouaRQuSexS0bzo dsWHJxl8JQ/E
XWWUudecMQwyyqNy1BaGQljAl0seuRHP6OzR/Sw/NCB6zc5LrheEbtalbPNu aJqtn4oBT9D1
rhlJ07WG6EmjKMMkIsy7nX4V3m6SKYPlerbVIxW+LRZpBaNKtNvnaxf1/Gse ZSIsS4wy4/Tm
pYVP66PUioRPJG4V3z5Zf+80zLZfN0am4pYu6A7axpjyVRLsoMdfJEjC/bT5 PKaBCNzA7LqT
szOY4pxGZ6sUk7OQB3B2pnbgVQQyuyjzoxQBn0G2QFjyEBlwlUPoDXF5OZxe igAPB9PL4UA0
e24hGqOwIXgYq48vRM3ERuTfaTSHGZJslWAKJMFSL4bnasWKqSUAQ0Yvf75n NPq23e6XiZe4
/GOO2ZjzTLmfgjRaNkG3ldVPw4EQfgA1eV60lrx1YB0aM7kO0zqoDp9mDJV8 9d9hZTcQrD3R
/VAZqCkeDgwYhoM4Z4b3c4wwIQIumh9WU0YDCGSNBKMV8EcmwJiCVaxKnKlp 8LPbkduiY8AZ
kGCBITwQtsIc+z3jcRVPTr8dUT0IyhoHCc4wwShAYKJ4uUrPuv3XWbuB5Mj7 FLFhgh4pI6Ga
PAmFTtUYdDtxwjPhu3BK1U9IiuWiIuzme56h3PUqzI/veKl/H7/z1bu7bXZa 4XZl572A24X+
vdw2q+tuhzgjK5at91tVAOOzVQ16QLIsodNVhgdxz6jZybVUklMAMypOBTAR 1ggy8Uf+jXfv
ffD+vvpy48M7iFaM7Zrr/7HPxs1MVeh3NXd39rNZi3Ov11bjowO91ag9IJ81 5djx2dPKigkV
rYZtRAAFmXTSVYyJ07/odp6OqVTfBgAnaiuohjEgQXGoiqB6oHVvqDhEE5a6 n67ujmSbZmCd
gzpVSsPoDJySfeCd3qJ6rGMPQITfYc2FwVGTXMXzpyLVVPytuSo8vL8f3976 9/7t3eh6InMh
HC4iYzPgiwTC4s0iDsWBsRaGsv+3UbDRvUUwvJsrf3T7uRmKkhRfJhIllZaR yI+19UgU/Rsi
oedtE4XJ7ZfxtdcShYIjjxgFU8AtlrF2qyrrR1X/wKkgzly5MUYEVrW1LaaT s9A3LJOb1clp
J19wYbKH9tvBGP9bUVGXnX5fZlCPPToqe/U3Bkfnye52J57fnjlFdqeFYafa rv6ximwNte1k
meO3hW1qSG6d8fsa11ixGd3+x7F39aHc6h9Hdw2gtzLjEUPYeA4DHEUPmKQ4 xiV/QKf2XAVc
HFQSLwpPgYozhnkfGH04bZG0TOepYdzvNAsW4BTTTdwDkuImbjiXE/PwOE7l qalfI7G+OyUp
DYzppanKkovfa8yzslFfyRXPUmcq3WZ1RUF+hro26G3S3LqpNtpgYVmds9wa nsolFnby1cfD
uUEv/oOZUwPulHOGRHMMe8CyQ75v+o8xHhjDNczuA8sqDPdBWhVZG8Aja3t9 tWHIZ8JuHcza
kSSTZyWuSFiRqOPTM06aADLYEnTxr7zNHQouNZwIfkGSmIg3BkkYXjHmOOVv KP3Cngsr4juh
rQqzpgHW2KH0V7BaBWmL/nLsMPotpBfnMHMQ20vcWvivw33Dx/ZZu3j7lN94 XYVdC7f2kmNv
my9RWt84L7JPDoz6A4N4X0xWn5ZeEJGtsNK5LRN4VDjl5IyjtFGKD0zU1oPH ib4uwJs3cFJ2
uzT1lnH2uB+Jlw8JFel57/bC2/i9vJtXhZvebYU3qb/+iGuk/2mePXNt53BS nemKmydhqaPv
hc88NrTd12w/W8arHrecUtPJy4E4fynm+h/rrirsuEv4D2FmHyoGlnPlS6l5 CPhrNZthIpMt
fyfQN1Z7xKmvVc7r6S6JY2G08wp0Ts7hVctoma5qf6/fM7053OSgbaQM3xMM BubttfsLUEsH
CAvM/XD8BQAAUSIAAFBLAwQUAAgACADqWQM3Y2CuzU8FAADVIAAAYgAAAG9y Zy5lY2xpcHNl
ZG1hcC9pbXBsL01pbmRtYXBGYWN0b3J5SW1wbC5qYXZh7Vlbb9s2FH62fwVr FKiSzfK7c9k8
R0U1NLHhqAP6FCgSLXOTJYGi4wRF/vt4k01SF1tJ1A7FHgxJ1Dnk95HfOTyU R6enfXAKzoM0
e8IoWpFL/jjSnlnTezd8T6+jfuYH//gRBCmObBjEKMuhHa2XNnz011kMc3uN knDtZzaij2f9
Pr2kmGjmkJkHKYa2M439PD87YHTlE997yuAhu9n93zAgh6zmgsAhaAy+7Xz0 A5LiJ/cILlm8
iVBiO+xhzu+rPSon6yoNNmuYkEWaVhOo9Lr2sxbG4ioZtfbbTduxfnOMUoxI i5EWMPYJSpN8
hVrwUr1qVVLjmacbHLTw8FYY+qFL4Lqtz8u4eWmGAiqjkQzTd8MhuIdUWsNN DvEwTAMwHPKQ
nSSAKRYyEfGBQLoEZAXBOg1hDM7vL+XCn4/uL+1dZzAJS139HsEEYp/AUAT8 5j5GAQhYpAJd
RCwsAHwktJccqLGyx2K6gG/9HmPTowNN6cQQmHOYIVz6m5iApTTTydjcvo5+ r5ZNT6fTY3x6
klDOug5MeChBxDphKHtEoO31DBMK12i5AJbeclJkGaqxCOW0J9u9ufUmN1PH jiAppsoarAjJ
xqPRdrstFt+mohjJ9R+cnAEGAC2BVR713QVINnEswPZ6GJINTsroztjb5774 BT4JVsByHgOY
cZXA4k52o6SvPeQ4jay94ZnsSw6YwG2FLCxm9twvL7ZPhZrQuU8CWEhUrnkX i1wFjBPNNxnE
JZBvO7jckEDAqVtiswOQXySKLeLrIdqYNPgNWiKI3SvrRC5K4OcQ6HnYvppN v1w7N97dYjbz
xkAuhhhK3U04x+ouridzw5FuKA32C+fzxHNnN7efXNNRTW+NPdzOviymTslb JOIGT+/Twplc
GX4itR70unM957rSlWXyJvfZ3J2ajiwlHx6yYa7KG4LsTubAMQ9nssLplgeX G8cw8uMJjvii
7mLXGng0eERe/jAAv4C9im78NZ1M2jT4AFAOkpQAHzz4MQqFPRfYoIjk7iJA C4CPOF3fEoyS
yNqVdAAWd78C8Y5nYOTHf/nxBhpRUti2CpT5wp0tXO/rWM2SAlFRoijIFDwa kKOC4s77Oncq
xjFLlNeMV9C5m/3xpzP1GliJyX9TbvWDmhTbDf4i5Ye0Q8I0JMSviuO/on8p 6SBNHiAmXtok
fxkrxebYsf4FokIqO2TaKqlAXqp/MY6pjleM16h/nZWY0bfk1jBodQAcOfjP qn+1EKmsTbhs
1SZ+eghVtws+FaaN2DLlEoTa6blDPrQ+Uisljp7ecdBUNxKrbNEgrtlRvUNk qvwqazKOVW3i
oLHqJtCbNhoNrB1jO+UjSsJShSh5iEfJQZoW+PfvDOzFcb9D3Ed+DjAKWE5K lqSMEhFGgtC+
XaMjbDolsy+SK6pmFTNtUHBzBw27fF+BX3xL6ZIDq9f12l0gZ/cCNLeQeItW Har4DNP5TFcE
cdVhQZn5UkCTckfqSjQGd9m3U87FNl1fjLc7Juz6o4HOPiVd7EZgW6JVqjrZ V5XCtPiUcuze
+8B6ERuv2m/ljgsT2gPln2L2waNxsx4Y+Ypi63QJ9Pq0VA22rFMlbu1NMbXg N3EZ669tUozV
7acYszo7fDBrp71S/zsNmm/+1+JRWqw9Mfw8mqzJf6WTczslHvrAYRxxPiNC scX57lxVPp5/
7/RjnJxetuB1Ke0Y+sbx7IdnpbdUREPGq5ua0in4x0nkwCH7VVKpzTit5uW7 aUdHBWju1lss
jaNB4oT9CbUzfBucIcwwDAqgR/7tpsCvxG3MPSz+khKQn8FoVP6Hp/8vUEsH CGNgrs1PBQAA
1SAAAFBLAwQUAAgACADqWQM3HiwEjwYRAABChwAAYgAAAG9yZy5lY2xpcHNl LmdtZi5leGFt
cGxlcy5taW5kbWFwL3NyYy9vcmcvZWNsaXBzZS9nbWYvZXhhbXBsZXMvbWlu ZG1hcC9pbXBs
L01pbmRtYXBQYWNrYWdlSW1wbC5qYXZh1V1tc9s2Ev7s/ApUuZnKHVlqe6/j vFwViWl4I0s+
iW6T3txoaAm2eZFIDUkldjv577d4IQiAoEjKFK18iU0QCzy72F0swN249913 z9B36OUi2DyE
3u1d/Jo+9pRn0vQne/kn+Nl7tnEXH91bjILwtosXK28T4e7t+qaL7931ZoWj 7trzl2t30/Xg
8cWzZ/AjCGOlOybdF0GIu1Y/jkPvehvjFwUdBys3ioo6Dd3YdR42hYNZ/nZd 1OeS8VnUbYpv
cIj9BS5ilYhDjGqXkM39etWNgZnu+4sRYUoAMpEZV2AYLLZr7MfTIIiNfBip LtxNhc7s51t3
EQfhQ2W6XUI20l2GXhB6cYWZpnjlxl7gR3deBb5kqlyNyqGMgm24qEDh3IXY XdoxNuvkDpr9
eHOCjbcANepx2//m7Axd41vPP9tGODxbBgt0dkb9QN9HRG0xUSI6EQpuUHyH 0TpY4hV6ef2a
L+DL3vXrrhgM+8vMUD/dYh+HboyXzItsr1feAi2IVSNVGYhtIHwfwygRkg0m xaKToD+enRBu
Tnawc5KL7kSFd0LwnWxC7xM8IuZ40FIyJd70CvnbFbHiA08NbDY8YyipVeNT M+tpeNqYmtOT
TErsvumJiQN4EmanT6FZZLdHG75xsKeGJg21XaSpyZM4SHA9uf4fXsRpe4MQ dBkUQxmApsQ4
Qi7sPn4UuxBc7dp3OjDFrRfFEIYt0WcvvqOD/PHTyvM/FgR3sFkTyvABZVq+ oOsHOiWPd+mg
Previous Topic:How can I set the location of the node on mouseUp event?
Next Topic:Collapsible compartment
Current Time: Sun Nov 09 18:36:26 EST 2025
Powered by FUDForum. Page generated in 0.03740 seconds
