Home » Newcomers » Newcomers » Eclipse fails on startup
Eclipse fails on startup [message #999135] Fri, 11 January 2013 07:21 Go to next message
I'm using Eclipse Juno version 4.2.0 with CDT in Windows 7.
Eclipse worked fine yesterday but failed to startup today. Here's the log file. What may have caused this error and how do I fix it?
!SESSION 2013-01-11 21:36:38.886 -----------------------------------------------
eclipse.buildId=M20120914-1800
java.version=1.6.0_17
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_AU
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.cpp.product
!ENTRY org.eclipse.osgi 4 0 2013-01-11 21:36:40.290
!MESSAGE Application error
!STACK 1
java.lang.ClassFormatError: Illegal UTF8 string in constant pool in class file org/eclipse/jface/viewers/ColumnViewer
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClassHoldingLock(ClasspathManager.java:632)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:614)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:568)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:492)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:465)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at org.eclipse.jface.resource.JFaceResources.initializeDefaultImages(JFaceResources.java:442)
at org.eclipse.jface.resource.JFaceResources.getImageRegistry(JFaceResources.java:405)
at org.eclipse.jface.resource.JFaceResources.getImage(JFaceResources.java:389)
at org.eclipse.jface.dialogs.TitleAreaDialog.createTitleArea(TitleAreaDialog.java:241)
at org.eclipse.jface.dialogs.TitleAreaDialog.createContents(TitleAreaDialog.java:149)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.prompt(ChooseWorkspaceDialog.java:91)
at org.eclipse.ui.internal.ide.application.IDEApplication.promptForWorkspace(IDEApplication.java:297)
at org.eclipse.ui.internal.ide.application.IDEApplication.checkInstanceLocation(IDEApplication.java:238)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Re: Eclipse fails on startup [message #1001235 is a reply to message #999135] Wed, 16 January 2013 04:44 Go to previous messageGo to next message
From what I've seen it seems that the issue comes from an "incompatibility" between your JRE and the jar or a corrupted jar.
Does this issue occurs with another bundle of Eclipse? If yes, does it still occurs if you use another version of the JRE?
Did you update your version of Java or change anything in the eclipse.ini file?
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
Re: Eclipse fails on startup [message #1001612 is a reply to message #1001235] Wed, 16 January 2013 22:52 Go to previous message
No i didn't update the jre or change the ini file. Deleting the eclipse install and reinstalling it removed the problem.
Previous Topic:New to BIRT need a local guru
Next Topic:Simple way to save the list of files opened in editor?
Current Time: Thu Nov 06 22:45:08 EST 2025
Powered by FUDForum. Page generated in 0.08901 seconds
