Adding Xtext nature to Xtext project from existing ecore [message #999111] |
Fri, 11 January 2013 11:12 |
Hi everyone,
I've created new Xtext project from my ecore model. After some problems I've generated correctly Xtext Artifacts. Now, as usual, I've launched an Eclipse instance and I've created a new project. But when I create a new file with my extension will not appear dialog for adding Xtext nature to the project.
Why is this happening?
Re: Adding Xtext nature to Xtext project from existing ecore [message #999162 is a reply to message #999117] |
Fri, 11 January 2013 13:38 |
Christian Dietrich wrote on Fri, 11 January 2013 12:21I think there is still something wrong generated. As a first step I
would compare plugin.XML and plugin.xml-gen
Then I would have a look at the OSGi console and check if your
languages ui plugin is correctly started
How can't I see that? There isn't a generated plugin!
When I create the project no plugin.xml was create automatically, so I've written the plugin, but there isn't generated one.
Doesn't it like my plugin?
<?eclipse version="3.0"?>
<plugin>
<extension point="org.eclipse.emf.ecore.generated_package">
<package
uri = "http://www.rcpvision.it/ats/suitetest/CoreLanguage"
class = "it.rcpvision.ats.suitetest.corelanguage.LanguagePackage"
genModel = "it/rcpvision/ats/suitetest/CoreLanguage.genmodel" />
</extension>
</plugin>
Re: Adding Xtext nature to Xtext project from existing ecore [message #999173 is a reply to message #999171] |
Fri, 11 January 2013 14:09 |
Plugin e plugin_gen in ui project are identical.
Console says:
0 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering platform uri 'E:\Workspaces\PrototipoAts'
511 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'com.egicon.ats.sequence.model.sequenceruntime.AtsSequenceRuntimePackage'
511 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'com.egicon.ats.sequence.model.atsvariable.AtsvariablePackage'
511 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'com.egicon.ats.sequence.model.typesystem.AtstypesystemPackage'
512 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'com.egicon.ats.sequence.model.sequenceedit.AtssequenceeditPackage'
717 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://com/egicon/ats/sequenceruntime' from 'platform:/resource/com.egicon.ats.sequence.model/model/AtsSequenceRuntime.genmodel'
717 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://com/egicon/ats/sequenceedit' from 'platform:/resource/com.egicon.ats.sequence.model/model/AtsSequenceEdit.genmodel'
717 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://com/egicon/ats/typesystem' from 'platform:/resource/com.egicon.ats.sequence.model/model/AtsSequenceEdit.genmodel'
717 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://com/egicon/ats/variable' from 'platform:/resource/com.egicon.ats.sequence.model/model/AtsSequenceEdit.genmodel'
717 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://configuration' from 'platform:/resource/com.egicon.ats.devices.model/model/configuration.genmodel'
1161 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning E:\Workspaces\PrototipoAts\it.rcpvision.ats.suitetest.corelanguage\..\it.rcpvision.ats.suitetest.corelanguage\src-gen
1169 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning E:\Workspaces\PrototipoAts\it.rcpvision.ats.suitetest.corelanguage\..\it.rcpvision.ats.suitetest.corelanguage.ui\src-gen
1293 [main] INFO ipse.xtext.generator.LanguageConfig - generating infrastructure for it.rcpvision.ats.suitetest.CoreLanguage with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, ParseTreeConstructorFragment, ResourceFactoryFragment, XtextAntlrGeneratorFragment, Ecore2XtextValueConverterServiceFragment, JavaValidatorFragment, ImportURIScopingFragment, SimpleNamesFragment, FormatterFragment, LabelProviderFragment, OutlineTreeProviderFragment, QuickOutlineFragment, JavaBasedContentAssistFragment, XtextAntlrUiGeneratorFragment, CompareFragment, BuilderIntegrationFragment, QuickfixProviderFragment
3566 [main] INFO or.validation.JavaValidatorFragment - generating Java-based EValidator API
4520 [main] INFO text.generator.junit.Junit4Fragment - generating Compare Framework infrastructure
4607 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
Re: Adding Xtext nature to Xtext project from existing ecore [message #999191 is a reply to message #999180] |
Fri, 11 January 2013 14:40 |
Thanks for replies.
Yes, I've got fragment = builder.BuilderIntegrationFragment {} in my .mwe2
The editor doesn't work: I see the file with the default editor, no editor for my language is avaible.
But now I've got following exception:
!SESSION 2013-01-11 15:36:37.826 -----------------------------------------------
eclipse.buildId=I20120608-1400
java.version=1.6.0_38
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Framework arguments: -product org.eclipse.sdk.ide
Command-line arguments: -product org.eclipse.sdk.ide -data E:\Workspaces\PrototipoAts/../runtime-EclipseApplication -dev file:E:/Workspaces/PrototipoAts/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.jdt.core 4 4 2013-01-11 15:36:51.390
!MESSAGE Exception while initializing all containers
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Resource '/.org.eclipse.jdt.core.external.folders/.link4' already exists.
at org.eclipse.core.internal.resources.Resource.checkDoesNotExist(Resource.java:320)
at org.eclipse.core.internal.resources.Resource.assertLinkRequirements(Resource.java:176)
at org.eclipse.core.internal.resources.Resource.createLink(Resource.java:673)
at org.eclipse.core.internal.resources.Resource.createLink(Resource.java:647)
at org.eclipse.jdt.internal.core.ExternalFoldersManager.createLinkFolder(ExternalFoldersManager.java:166)
at org.eclipse.jdt.internal.core.ExternalFoldersManager.createLinkFolder(ExternalFoldersManager.java:157)
at org.eclipse.jdt.internal.core.ExternalFolderChange.updateExternalFoldersIfNecessary(ExternalFolderChange.java:48)
at org.eclipse.jdt.internal.core.ChangeClasspathOperation.classpathChanged(ChangeClasspathOperation.java:62)
at org.eclipse.jdt.internal.core.SetContainerOperation.executeOperation(SetContainerOperation.java:110)
at org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaModelOperation.java:728)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.jdt.internal.core.JavaModelOperation.runOperation(JavaModelOperation.java:793)
at org.eclipse.jdt.internal.core.JavaModelManager$11.run(JavaModelManager.java:2773)
at org.eclipse.jdt.internal.core.JavaModelManager.initializeAllContainers(JavaModelManager.java:2789)
at org.eclipse.jdt.internal.core.JavaModelManager.getClasspathContainer(JavaModelManager.java:1873)
at org.eclipse.jdt.core.JavaCore.getClasspathContainer(JavaCore.java:3128)
at org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(JavaProject.java:2691)
at org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(JavaProject.java:2855)
at org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspath(JavaProject.java:1960)
at org.eclipse.jdt.internal.core.JavaProject.buildStructure(JavaProject.java:463)
at org.eclipse.jdt.internal.core.Openable.generateInfos(Openable.java:258)
at org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(JavaElement.java:518)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:255)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:241)
at org.eclipse.jdt.internal.core.JavaElement.getChildren(JavaElement.java:196)
at org.eclipse.jdt.internal.core.JavaProject.getPackageFragmentRoots(JavaProject.java:1848)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerContentProvider.getPackageFragmentRoots(PackageExplorerContentProvider.java:323)
at org.eclipse.jdt.ui.StandardJavaElementContentProvider.getChildren(StandardJavaElementContentProvider.java:183)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerContentProvider.getChildren(PackageExplorerContentProvider.java:307)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1374)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:391)
at org.eclipse.jdt.internal.ui.viewsupport.ProblemTreeViewer.getFilteredChildren(ProblemTreeViewer.java:274)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:620)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:820)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:797)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:644)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:768)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpand(AbstractTreeViewer.java:1500)
at org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeViewer.java:952)
at org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded(AbstractTreeViewer.java:1511)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:132)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:7565)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:5534)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:1896)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:5086)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4584)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2440)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1534)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:6435)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4564)
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5958)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2546)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3756)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
!SUBENTRY 1 org.eclipse.core.resources 4 367 2013-01-11 15:36:51.393
!MESSAGE Resource '/.org.eclipse.jdt.core.external.folders/.link4' already exists.
!ENTRY org.eclipse.ui 2 2 2013-01-11 15:37:28.842
!MESSAGE Invalid property category path: ValidationPropertiesPage (bundle: org.eclipse.wst.xml.ui, propertyPage: org.eclipse.wst.xml.ui.propertyPage.project.validation)
Re: Adding Xtext nature to Xtext project from existing ecore [message #999233 is a reply to message #999218] |
Fri, 11 January 2013 15:56 |
And why doesn't it start.
I've tryed with library example and it works.
So, here what I've done from the begin:
1) I have an ecore model
2) I've created new Xtext project from my existing ecore
3) I've changed imports with right strings (see below)
4) Generated Xtext Artifact
5) Run Eclipse Application
6) Create new java project and new .myextension file
With library it works, with my ecore plugin doesn't start.
import "platform:/resource/com.egicon.ats.sequence.model/model/AtsVariable.ecore"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
import "platform:/resource/com.egicon.ats.sequence.model/model/AtsTypeSystem.ecore" as typesystem
import "platform:/resource/com.egicon.ats.sequence.model/model/AtsSequenceEdit.ecore" as sequenceedit
import "platform:/resource/com.egicon.ats.devices.model/model/configuration.ecore" as configuration
FUDForum. Page generated in 0.04442 seconds
