| No more handles [gtk_init_check() failed] [message #998978] |
Thu, 10 January 2013 23:32  |
We have created an eclipse application which is intended to run in the headless mode, , i.e. from the command-line without the usage of the Eclipse GUI. We are using Eclipse Indigo (3.7.2)
On Windows it is working fine, but on Linux, it fails with the following exception:
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.start() of bundle org.eclipse.ui.ide.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
... 48 more
Caused by: org.eclipse.swt.SWTError: No more handles [gtk_init_check() failed]
at org.eclipse.swt.SWT.error(SWT.java:4308)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:909)
at org.eclipse.swt.widgets.Display.create(Display.java:897)
at org.eclipse.swt.graphics.Device.<init>(Device.java:157)
at org.eclipse.swt.widgets.Display.<init>(Display.java:500)
at org.eclipse.swt.widgets.Display.<init>(Display.java:491)
at org.eclipse.swt.widgets.Display.getDefault(Display.java:1681)
at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.createProblemsViews(IDEWorkbenchPlugin.java:394)
at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.start(IDEWorkbenchPlugin.java:351)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 54 more
The same application when run on Eclipse Helios (3.6.2) works fine on both Windows and Linux.
Is there any work around or a way in which we can run the application in headless mode.
FUDForum. Page generated in 0.03469 seconds
