Re: [ANN] Build for Eclipse 3.4 RC2 [message #144936 is a reply to message #144927] |
Thu, 29 May 2008 07:51 |
Originally posted by: emailmuell.posur.com
Sorry, does not work for me.
With all projects, VE stops at loading 25%
Even a new project with new visual class gives a parsing error.
"Yves YANG" <yves.yang@soyatec.com> schrieb im Newsbeitrag
news:g1kmbm$s1p$1@build.eclipse.org...
> Hi all,
> I have made a build of VE for Eclipse 3.4 RC2. Ombredanne and me are
> contacting EMO to publish it in Eclipse update system.
> You can find the build on my ftp:
> http://www.soyatec.org/update/Ganymede/org.eclipse.ve_1.4.0. v20080528.zip
> This build doesn't contain any new features. It is just a porting from the
> build for Eclipse 3.2.
> It depends on the following plugins:
> emf-sdo-xsd-SDK-2.4.0RC2.zip
> GEF-SDK-3.4.0RC1.zip
> Any feedbacks are welcome.
> Best regards
> Yves YANG
Re: [ANN] Build for Eclipse 3.4 RC2 [message #144973 is a reply to message #144927] |
Fri, 06 June 2008 15:10 |
Originally posted by: matthew.leah.pdgm.nospam.com
I have managed to get the latest VE version up and running with Eclipse
3.4 RC3, but there are a few quirks with regard to the GridBagLayout.
Firstly, if the default constructor is used to create the
GridBagConstraints object, setting any of its attributes has no effect
on the layout in the UI. The only way to ensure that the correct
constraints are used is to pass all of the desired values into the
constructor when the object is created.
The second is that the Customise Layout option no longer opens the
dialog used for editing layout attributes for a component.
Other than the above, the new version seems to be working well. Many
thanks to Yves and everyone working on the VE upgrades for Eclispe 3.4!!
Best Regards,
Matt
Yves YANG wrote:
> Hi all,
> the build for Eclipse 3.2.
> Best regards
> Yves YANG
Re: [ANN] Build for Eclipse 3.4 RC2 [message #145278 is a reply to message #144927] |
Sat, 02 August 2008 02:42 |
Originally posted by: president.runiter.org
It does get installed on my eclipse 3.4. When I use Software Updates and
Add Archieve org.eclipse.ve_1.4.0.v20080528.zip it give the following
error msg:
No repository found at
jar:file:C:\Users\Saeid\Downloads\org.eclipse.ve_1.4.0.v2008 0528.zip!/
How do I make it install? Simply unziping the zip file directly inside the
eclipse folder didn't work either.
Saeid
www.runiter.com
Re: [ANN] Build for Eclipse 3.4 RC2 [message #145282 is a reply to message #144927] |
Tue, 05 August 2008 11:22 |
Originally posted by: formatzeh.gmx.de
I copied your VE-version into my Eclipse-directory but it doesn't appear
in the list of plugins neither I can create a new visual class.
Anybody some ideas where to look at?
Re: [ANN] Build for Eclipse 3.4 RC2 [message #617210 is a reply to message #144927] |
> Hi all,
> Best regards
> Yves YANG
Re: [ANN] Build for Eclipse 3.4 RC2 [message #617254 is a reply to message #144927] |
error msg:
Saeid
www.runiter.com
Re: [ANN] Build for Eclipse 3.4 RC2 [message #617256 is a reply to message #144927] |
FUDForum. Page generated in 0.03622 seconds
