Home » Language IDEs » ServerTools (WTP) » error in a ejb project(ejb error)
error in a ejb project [message #997303] Sat, 05 January 2013 07:54 Go to next message
i m using jboss 4.2.3 and eclipse 3.7 indigo
while building the EJB project i gave the ejb version 2.1 instead of version 3.0
it gave me an error that your project should have atlest one enterprise mean...can anybody tell me what exactly the problem is ? is it with server?
thanks
Dishant
Re: error in a ejb project [message #997487 is a reply to message #997303] Mon, 07 January 2013 13:36 Go to previous messageGo to next message
Hello Dishant,
Did you just created the ejb project? if the message you see is this: "An EJB module must contain one or more enterprise beans", then this is working as designed, and this message should go away once you add an EJB to the ejb-jar-xml deployment descriptor.
Hope this helps.
Re: error in a ejb project [message #997537 is a reply to message #997487] Tue, 08 January 2013 03:18 Go to previous message
i created a ejb as well , and i am not sure if this is due to jboss when i switch to ejb 3.0 it's work just fine ,
thanks for ur reply
Dishant
Previous Topic:Project importing existing web app into Eclipse
Next Topic:Adding Preemptive Basic Auth to Web Service Client
Current Time: Fri Sep 26 15:16:22 EDT 2025
Powered by FUDForum. Page generated in 0.08807 seconds
