Eclipse Juno error [message #995737] |
Mon, 31 December 2012 01:44 |
Sihan goi Messages: 8 Registered: March 2012 |
I have Juno installed for Android development, and after updating my Android SDK, I was prompted by Eclipse to also update ADT, which I did. However, after updating it, when I tried to run eclipse, I get the error message:
An error has occurred. See the log file filename.log
The log contains the following output.
!SESSION 2012-12-28 15:21:35.019 -----------------------------------------------
eclipse.buildId=M20120914-1800
java.version=1.6.0_21
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_SG
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.equinox.ds 4 0 2012-12-28 15:21:35.691
!MESSAGE [SCR] Exception while activating instance org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngineManager@66941db6 of component org.eclipse.e4.ui.css.swt.theme
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Display
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2427)
at java.lang.Class.getDeclaredMethods(Class.java:1791)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.getMethod(ServiceComponent.java:126)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:213)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:347)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217)
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816)
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.widgets.Display
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
... 15 more
!STACK 0
... 15 more
!ENTRY org.eclipse.osgi 4 0 2012-12-28 15:21:35.890
!MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.workbench (342).
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:172)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2389)
at java.lang.Class.getConstructor0(Class.java:2699)
at java.lang.Class.newInstance0(Class.java:326)
at java.lang.Class.newInstance(Class.java:308)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:191)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:167)
... 37 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError
... 43 more
Root exception:
... 43 more
!ENTRY org.eclipse.osgi 4 0 2012-12-28 15:21:36.083
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.ui.ide.application" was unable to instantiate class "org.eclipse.ui.internal.ide.application.IDEApplication".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/ui/application/WorkbenchAdvisor
... 16 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.ui.workbench (342).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
... 22 more
Caused by: org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
... 31 more
... 37 more
... 43 more
!ENTRY org.eclipse.e4.ui.css.swt.theme 4 0 2012-12-28 15:21:36.232
!MESSAGE [SCR] Error while attempting to deactivate instance of component Component[
name = org.eclipse.e4.ui.css.swt.theme
activate = activate
deactivate = deactivate
modified =
configuration-policy = optional
factory = null
autoenable = true
immediate = true
implementation = org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngineManager
state = Disabled
properties =
serviceFactory = false
serviceInterface = [org.eclipse.e4.ui.css.swt.theme.IThemeManager]
references = null
located in bundle = org.eclipse.e4.ui.css.swt.theme_0.9.3.v20120806-170624 [293]
!STACK 0
at org.eclipse.equinox.internal.ds.model.ServiceComponent.deactivate(ServiceComponent.java:337)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.deactivate(ServiceComponentProp.java:161)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.dispose(ServiceComponentProp.java:389)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.dispose(ServiceComponentProp.java:102)
at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:366)
at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:306)
at org.eclipse.equinox.internal.ds.Resolver.disposeComponentConfigs(Resolver.java:717)
at org.eclipse.equinox.internal.ds.Resolver.disableComponents(Resolver.java:693)
at org.eclipse.equinox.internal.ds.SCRManager.stoppingBundle(SCRManager.java:554)
at org.eclipse.equinox.internal.ds.SCRManager.bundleChanged(SCRManager.java:233)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:847)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1568)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1504)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1499)
at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:506)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:566)
at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1206)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:592)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:257)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:215)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:284)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:692)
at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:600)
at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:399)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:199)
... 39 more
!ENTRY org.eclipse.e4.ui.css.swt.theme 4 0 2012-12-28 15:21:36.233
activate = activate
modified =
factory = null
autoenable = true
immediate = true
state = Disabled
properties =
references = null
!STACK 0
... 39 more
Does anyone know what's wrong?
FUDForum. Page generated in 0.03148 seconds
