Project importing existing web app into Eclipse [message #994959] |
Fri, 28 December 2012 18:28 |
Missing name Mising name Messages: 25 Registered: October 2010 |
I'm trying to debug an existing Web app in Eclipse. The Web App is written in Java using hibernate but wasn't initially developed in Eclipse. I can build the web app with an ant script with no problem, but I'm having trouble when I get into Eclipse.
I'm using Juno. I used "New" "Dynamic Web Project" to create a new project, and instead of creating a new project directory, I pointed to my already existing directory, pointing "SRC" to the "SRC" directory under the web app directory. The top level directories of my web app are layed out in a similar fashion to what Eclipse wants to create.
I want to debug using Tomcat 7. I have this installed and can create a server. However, I can't ever get the thing to run. The build seems fine, but when I do "Debug on server" I get the call stack below. The web app does not seem to be deployed - there is no "StoreFinder" directory created in C:\Users\owner\workspace_tomcat\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\wtpwebapps\StoreFinder, i.e. the direcory "StoreFinder" does not exist there.
I also notice that I can't export the project as a "WAR" - the export drop downs are empty.
I suspect this is a project setup issue. Can someone suggest where I need to start to debug this? Many many thanks!
George
Dec 28, 2012 12:22:17 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jre7\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files/Java/jre7/bin/client;C:/Program Files/Java/jre7/bin;C:/Program Files/Java/jre7/lib/i386;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Bitvise Tunnelier;C:\strawberry\c\bin;C:\strawberry\perl\site\bin;C:\strawberry\perl\bin;C:\Program Files\Common Files\Teleca Shared;C:\Program Files\Git\cmd;C:\eclipsejuno\eclipse;;.
Dec 28, 2012 12:22:18 PM org.apache.tomcat.util.digester.SetPropertiesRule begin
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:StoreFinder' did not find a matching property.
Dec 28, 2012 12:22:18 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-bio-8080"]
INFO: Initializing ProtocolHandler ["ajp-bio-8009"]
Dec 28, 2012 12:22:18 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1607 ms
Dec 28, 2012 12:22:18 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Dec 28, 2012 12:22:18 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.34
Dec 28, 2012 12:22:19 PM org.apache.catalina.core.StandardContext resourcesStart
SEVERE: Error starting static Resources
java.lang.IllegalArgumentException: Document base C:\Users\owner\workspace_tomcat\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\wtpwebapps\StoreFinder does not exist or is not a readable directory
at org.apache.naming.resources.FileDirContext.setDocBase(FileDirContext.java:138)
at org.apache.catalina.core.StandardContext.resourcesStart(StandardContext.java:4906)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5086)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1559)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1549)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Dec 28, 2012 12:22:19 PM org.apache.catalina.core.StandardContext startInternal
SEVERE: Error in resourceStart()
SEVERE: Error getConfigured
SEVERE: Context [/StoreFinder] startup failed due to previous errors
Dec 28, 2012 12:22:19 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
INFO: Starting ProtocolHandler ["ajp-bio-8009"]
Dec 28, 2012 12:22:19 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 570 ms
Re: Project importing existing web app into Eclipse [message #997503 is a reply to message #995277] |
Mon, 07 January 2013 20:26 |
Roberto Sanchez Herrera Messages: 36 Registered: January 2011 |
Member |
By looking at the properties page of the project, I see that several tabs are missing, for example, Deployment assembly and Java Build Path, among others. This suggests that important files like .classpath and other files inside the .settings folder (in .settings, there are really important files for web projects) are missing. These files and folders are located at the root of the project.
I suggest to check if the .classpath file exists, and to check which files exist under .settings (if you can, provide the list of files). I suspect .settings is not empty, because the file org.eclipse.wst.common.project.facet.core.xml, which has information for the project facets, lives in there, and you can see the project facets).
FUDForum. Page generated in 0.03727 seconds
