Home » Language IDEs » Java Development Tools (JDT) » Standalone or plug-in project
Standalone or plug-in project [message #144046] Fri, 20 February 2004 11:15 Go to next message
We have a swing based mapping application which utlizes drag and drop and
other features. We are planning to move / rewrite this application to
Eclipse based framework so that we can take advantage of some of the other
plug-ins.
Assume that I am creating this application from scratch, what type the
application should be : 1) a standalone SWT application or 2) an Eclipse
plug-in.
If I choose 1, a standalone SWT application, would it be possible for that
application to access and use other Eclipse plug-ins?
If I choose 2, an Eclipse plug-in, how my plug-in will be activated? I
would like to launch my application (plug-in) by default, i.e. I do not
want to activate my application from within Eclipse through a menu item.
Any pointers ....
Srinivasan Sairam
Re: Standalone or plug-in project [message #144139 is a reply to message #144046] Fri, 20 February 2004 17:12 Go to previous message
Originally posted by: Jed.Anderson.EN.aclickinthedark.com
Srinivasan,
If you want to take advantage of other plug-ins you will want to write
your application as an Eclipse application.
Then you should supply your own extension to the
org.eclipse.core.runtime.applications extension-point.
For more information about what you are trying to do look at the Rich
Client Tutorials found here:
http://www.eclipsepowered.org/rcp.html
Hope this helps!
jkca
Srinivasan Sairamachandran wrote:
> Hello,
> plug-ins.
> plug-in.
> Any pointers ....
> Thanks
> Srinivasan Sairam
Previous Topic:3.0M6-7: Smart insert brace insertion/completion doesn't respect code formatter settings
Next Topic:Library management
Current Time: Sun Nov 02 21:33:58 EST 2025
Powered by FUDForum. Page generated in 0.56640 seconds
