Home » Eclipse Projects » Nebula » Complex table structure using Nebula (Complex table structure using Nebula )
Complex table structure using Nebula [message #993962] Tue, 25 December 2012 21:18 Go to next message
I have a table with multiple rows which will be dynamic. In between these rows i will have summary row to count Sub Total Amount and Final row will be Summary row to populate Total Amount. Each row will contain Amount of particular Item.
For example
Category1 -Item1 -100 USD,
-Item2 -200 USD.
Subtoatal to Category 1 - 300 USD.
Category2 -Item1 -300 USD,
-Item2 -100 USD.
Subtoatal to Category 1 - 400 USD.
Now total Amount row will add subtotal amount of each category i.e 700 USD.
Is there any option to achieve this using Nebulla. Basically i am trying to replicate Webpage Table to SWT/Jface . Attached is the screenshot. Also please note that values in table will be populated from Database
  • Attachment: Table1.png
    (Size: 34.31KB, Downloaded 535 times)
[Updated on: Tue, 25 December 2012 22:31] by Moderator
Re: Complex table structure using Nebula [message #994909 is a reply to message #993962] Fri, 28 December 2012 11:03 Go to previous messageGo to next message
Hi Prashant,
I answered your question on the NatTable forum here: http://www.eclipse.org/forums/index.php/t/443734/
Edwin
Re: Complex table structure using Nebula [message #994961 is a reply to message #993962] Fri, 28 December 2012 13:26 Go to previous messageGo to next message
Grid also support col and rowspan!
Tom
Am 26.12.12 03:18, schrieb Prashant p:
> For example
> -Item2 -200 USD.
> -Item2 -100 USD.
> Is there any option to achieve this using Nat Table. Basically i am trying to replicate Webpage Table to SWT/Jface . Attached is the screenshot. Also please note that values in table will be populated from Database
Re: Complex table structure using Nebula [message #995721 is a reply to message #994961] Sun, 30 December 2012 19:28 Go to previous messageGo to next message
Thanks Edwin and Thomas. Do you mean Jface Grid Thomas? Also is it possible to populate DB values in Nat Table? 'coz my main intention is to populate table with DB values. And I should be able to add new row on ADD button click and insert values to DB. And also should be able to edit. Why i am asking this is Nat table is like Virtual table.
[Updated on: Sun, 30 December 2012 19:41] by Moderator
Re: Complex table structure using Nebula [message #1000673 is a reply to message #995721] Tue, 15 January 2013 03:19 Go to previous messageGo to next message
quite late reply, but that's because of my vacation AND I mostly check the NatTable forum for NatTable related questions. Wink
Where the data is stored that should be showed in NatTable is not a matter of the NatTable. You need to implement an IDataProvider that knows about retrieving and writing the data handled in your NatTable. So yes, it is possible to populate DB values in a NatTable. You just need to implement it. Wink
Yes NatTable is like a virtual table in design. Why should this be an issue?
Greez,
Dirk
Re: Complex table structure using Nebula [message #1001668 is a reply to message #1000673] Thu, 17 January 2013 02:05 Go to previous messageGo to next message
Hi... Attached is the look n feel of Table i am looking for. I am trying to get this in Nat table but not able to achieve this.
    (Size: 34.31KB, Downloaded 504 times)
Re: Complex table structure using Nebula [message #1001675 is a reply to message #1001668] Thu, 17 January 2013 02:20 Go to previous messageGo to next message
Why not? This should be an easy one. If it's only about styling, you need to override the styling configuration of the ColumnHeaderLayer and the body layer stack you are using.
Have a look here on how to configure styling http://eclipse.org/nattable/documentation.php?page=styling
Re: Complex table structure using Nebula [message #1002112 is a reply to message #1001675] Thu, 17 January 2013 19:32 Go to previous messageGo to next message
Thanks Dirk... Smile. Is there any proper code sample available? 'coz i searched i din fine any accept for Nebula. Also i have one more Question.. will Nattable support Jface data binding. 'coz my application is completly SWT/JFace based, just for this table purpose i am using Nattable. Values in Table will be mapped to Form Field on click of any row item in table, this require databinding between Table and Form field.And table should be editable as well.
[Updated on: Thu, 17 January 2013 19:44] by Moderator
Re: Complex table structure using Nebula [message #1002126 is a reply to message #1002112] Thu, 17 January 2013 20:31 Go to previous messageGo to next message
Hi Dirk, I have attached sample application screenshot of SWT/JFACE which i am trying to achieve with Nattable as i said in above explaination
  • Attachment: Example.png
    (Size: 45.19KB, Downloaded 1039 times)
Re: Complex table structure using Nebula [message #1002219 is a reply to message #1002126] Fri, 18 January 2013 02:44 Go to previous messageGo to next message
There are a lot of code samples and examples out there. Have a look at the examples provided by us in the examples project (click the Try it button).
There are more examples linked here http://eclipse.org/nattable/documentation.php?page=articles ... while the articles are written in German, the corresponding examples are documented in code in English.
Will Nattable support JFace data binding?
No ... and yes. If you like to add databinding to the NatTable like you do it with a JFace table, then definitely no. This is because the main concepts differ to much. I talked about this on the EclipseCon Europe 2012. You can find a video showing my slides together with the voice record here http://www.youtube.com/watch?v=ws9TdGwZkKc ... hope my English isn't too bad to understand.
But looking at your example screenshot, what you need to do is use JFace databinding for mapping your form fields to your datamodel. And link your datamodel to your NatTable. The only thing you need to do as we didn't support that easily out of the box, is to attach some PropertyChangeListeners so the NatTable gets updated if you change a value in the back. If you use GlazedLists than there is some implementation, but you need to have a closer look. E.g. the BlinkLayer is a good start.
Re: Complex table structure using Nebula [message #1003037 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous messageGo to next message
Thanks Dirk again for you explanation and patience Smile. The thing is that my deadline is very short Sad n i have to do invest more time don know if i will be successful in achieving this. Smile
Re: Complex table structure using Nebula [message #1003039 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous messageGo to next message
Thanks Dirk again for you explanation and patience :). The thing is that my deadline is very short :( n i have to do invest more time don know if i will be successful in achieving this. :)
Re: Complex table structure using Nebula [message #1003041 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous messageGo to next message
Re: Complex table structure using Nebula [message #1003043 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous messageGo to next message
Re: Complex table structure using Nebula [message #1003045 is a reply to message #1002219] Sun, 20 January 2013 01:14 Go to previous message
Thanks Dirk for your support and patience. Smile My deadline is very short don't know if this R&D will work for me Smile but will try out my best. As you know itz very hard to migrate web based solution to desktop based application on certain aspects.
Re: Complex table structure using Nebula [message #1003046 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous message
Re: Complex table structure using Nebula [message #1003048 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous message
Re: Complex table structure using Nebula [message #1003049 is a reply to message #1002219] Sun, 20 January 2013 01:14 Go to previous message
Thanks Dirk for your support and patience. :) My deadline is very short don't know if this R&D will work for me :) but will try out my best. As you know itz very hard to migrate web based solution to desktop based application on certain aspects.
Re: Complex table structure using Nebula [message #1003051 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous message
Re: Complex table structure using Nebula [message #1003052 is a reply to message #1002219] Sun, 20 January 2013 01:14 Go to previous message
Re: Complex table structure using Nebula [message #1003054 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous message
Re: Complex table structure using Nebula [message #1003055 is a reply to message #1002219] Sun, 20 January 2013 01:14 Go to previous message
Re: Complex table structure using Nebula [message #1003057 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous message
Re: Complex table structure using Nebula [message #1003058 is a reply to message #1002219] Sun, 20 January 2013 01:14 Go to previous message
Re: Complex table structure using Nebula [message #1003060 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous message
Re: Complex table structure using Nebula [message #1003061 is a reply to message #1002219] Sun, 20 January 2013 01:14 Go to previous message
Re: Complex table structure using Nebula [message #1003063 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous message
Re: Complex table structure using Nebula [message #1003064 is a reply to message #1002219] Sun, 20 January 2013 01:14 Go to previous message
Re: Complex table structure using Nebula [message #1003066 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous message
Re: Complex table structure using Nebula [message #1003067 is a reply to message #1002219] Sun, 20 January 2013 01:14 Go to previous message
Re: Complex table structure using Nebula [message #1003071 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous message
Re: Complex table structure using Nebula [message #1003072 is a reply to message #1002219] Sun, 20 January 2013 01:14 Go to previous message
Re: Complex table structure using Nebula [message #1003074 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous message
Re: Complex table structure using Nebula [message #1003075 is a reply to message #1002219] Sun, 20 January 2013 01:14 Go to previous message
Re: Complex table structure using Nebula [message #1003077 is a reply to message #1002219] Sun, 20 January 2013 00:55 Go to previous message
Re: Complex table structure using Nebula [message #1003078 is a reply to message #1002219] Sun, 20 January 2013 01:14 Go to previous message
Re: Complex table structure using Nebula [message #1003081 is a reply to message #1002219] Sun, 20 January 2013 01:14 Go to previous message
Previous Topic:Using GridViewer with checkboxes
Next Topic:Non Working Days in Gantt chart
Current Time: Mon Sep 22 01:04:00 EDT 2025
Powered by FUDForum. Page generated in 0.08999 seconds
